Question about Refrigerators
FRIGIDAIRE FRT21PRH Not Freezing
Frig not cooling very well and freezer not freezing at all (everything is melting). Compressor is hot, but condenser coils on back of fridge are cool and clean of dust. Took back cover off inside freezer, top right hand corner of coils frozen and the copper tube where the Cold-Control snaps in place is frozen as well. So I melted that with a blowdryer and restarted frig. Waiting to see if that fixes it. My theory is that either the cold control is bad, or some relay involved with the defrost mode is bad. I could probably just replace both with minimal costs. Any chance it could be the compressor? and how can I eliminate the compressor as a suspect?
Thanks
  • 1 more comment
  • natack Sep 01, 2008
    Additional info: The compressor motor seems to run continuously and the fan motor inside the freezer compartment also runs continuously. Even although there was some ice on the corner portion of the coils in the freezer, i would consider the amount fairly small. It's not like the entire coil system was covered in 3 inches of ice or anything like that. It only took me a few minutes to melt all the ice with the blow dryer.
    No timer under the kick plate on this one. Fan blows continuously. No frozen water in sight in the freezer. The air coming out of the ducks in the freezer just is not cold enough. Barely cool. Everything works or is running. The fridge cuts off for defrost, the compressor runs, and the fan in the freezer runs. Maybe I have lost freon by some freak reason?
    Unless there is more frozen spots in places i can't see. The selector that turns on the heater for between the doors so moisture does not occur is active and working.......gets warm when I turn the switch on.
  • jjcrist Sep 02, 2008
    This sounds just like my problem, but I do not understand what the solution was. Can you clarify what fixed the problem?
    "if you have an ice ball on the evapator you have a leak...ice not frost"
    What does these mean? "you have a leak" - does this mean a Freon leak?
    One thing that may be different in my situation is the frig door is leaking water (in addition to all the other simptoms you describe).
  • 725 Answers
If the evaporator has a full frost pattern it is not your compresser... First I could check your fan motor is it running...if the frost blocks the air flow it will stop cooling.. Next it could be a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help
Posted on Sep 01, 2008
  • Franklin Ouchida
    Franklin Ouchida Sep 01, 2008
    your timer is inside the refer in top shelf if you have an ice ball on the evapator you have a leak...ice not frost
Stopped cooling
My refrgerator a Kenmore, model 106-71182101, with ice maker stopped cooling and freezing.I vacuumed the condenser coils, and
fan in the rear bottom, along with any other debris. I unplugged the frig because the compressor was very HOT!.Question? Could the compressor have a Locked-Rotor? If so what can I do to loosen it.
Apr 08, 2013 | Kenmore 18.3 cu. ft. Top Freezer...
My Frigidaire fridge model # FRS6LF7FW3 has stopped cooling and freezing, water has leaked out and everything has/is melting in the freezer. The light bulbs work but the freezer and fridge temp window...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 21, 2011 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
Cooling but not freezing
Clean and inspect the coils around the compressor area. Check for a functioning condenser fan and feel the compressor if it is very hot to the touch the relay is probably fried.
Mar 17, 2010 | Frigidaire Freezers
Frigidaire refrigerator does not seem to be cooling or freezing completely. Frigidaire refrigerator does not make any noise and does not seem to be cooling or freezing. I have checked the back of the unit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
nmnm
Sep 24, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
May 30, 2009 | Refrigerators
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Freezer not freezing frig not cold
the compressor with a picture of an Indian, its a techumseh. Is the compressor running? If not, could be stuck in defrost mode. Since you have looked at the compressor, there is two lines that go to it. If there is an oil cooler, then 4. Follow the line, smaller of the two that goes to the condensor, rad. With the fridge running, use your hand to feel how hot it is, if you find it hot enough that you can't leave you hand on that line, then its an inneficient compressor.
Feb 09, 2009 | Frigidaire FRS3R4E Side by Side...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, you can try turning freezer to Warmer freezer allowing MORE air to refrigertor side.
Sep 05, 2007 | Frigidaire FRT17G4B Top Freezer...
Refrigerators Logo
566 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
