Question about Zojirushi BBCC-V20 Home Bakery Traditional Bread Maker
Need new paddles
The top of one of my paddles is rounded out, no longer rectangular, so the spindle spins, but the paddle stays still.
Looking for a source of replacement paddles.
  • rholl Sep 03, 2008
    Thanks!
Your best source is directly from Zojirushi. I ordered a replacement set of paddles when the teflon started flaking off mine.
The price was reasonable and delivery was quick. The zojirushi website is http://www.zojirushi.com go tot he Zojirushi Store! link to order parts. The blades currently list for $6.50 each.
Posted on Sep 03, 2008
I need a paddle for a Welbilt ABM6200, please.
Can you send me a digital photo of the interior of your pan showing the spindle in the bottom? I may be able to tell if I have a paddle for your machine by looking at that photo. Send the photo to me at my email daryl441@msn.com
Apr 13, 2013 | Welbilt Kitchen Appliances - Others
The paddle in my new 1.5 L ice cream maker is not turning - is this normal?
Hello Maryo803,
It is not normal for the paddle not to move in these units. First we have to determine weather the paddle is striped or the gear is stripped. At the bottom of the paddle there is a hole that attaches to the turning gear on the machine. Look and see if it still matches the sprocket in the bottom of the ice cream maker. If it does not still match I would suggest buying a new paddle. You can purchase a new paddle from Cuisinart for $8.00 and here is a link to the page. http://www.cuisinart.com/parts/ice_cream/ice-20.html
However, if it is not the paddle please post back to this thread and I will see if it is worth changing out the bottom gear.
Thank you for choosing FIxYa.com
Justin
Mar 11, 2011 | Cuisinart ICE-20 Automatic Frozen Yogurt...
The kneeding paddle is no longer smooth.where can
If the paddle is sticking it could be the sealed bearing on the bottom of the pan is sticking. Either that or the belt is loose and not allowing the paddle to spin freely.
Hank
Feb 08, 2010 | Breadman TR2200C Ultimate Bread Maker
Bread Maker stir paddle does not spin
Either contact the manufacturer, or remold the interior of the paddle hole yourself. How? Using something like JB WELD. Place a peice of plastic wrap over the metal spindle, spreading it not only around the spindle but 2-3 inches outward like a skirt. Mix the epoxy (I recommend JB Weld) and place a small blob over the spindle. Pack the hole in the paddle with it. Now, place the paddle back over the spindle and let the epoxy set-up overnight.
Because of the plastic, the paddle should lift up off the spindle. Using a carving tool, a hand grinder, or sandpaper and elbow grease, remove the excess hardened epoxy. The interior of the spindle hole should be good-as-new.
OR, find A STORE that sells breadmakers, and find a paddle that will work on yours, and 'borrow it' (a your own risk, shoplifting is a crime).
Feb 03, 2010 | Breadman TR850 Plus Bread Maker
Kneading paddle is baked into bottom of bread loaf. Is this normal?
Yes, this is a common occurrence.
Nothing to worry about unless you chow down and forget to remove the paddle(s). :)
Since the paddle(s) stays in the pan after the kneading and through the baking process. The bread can trap the paddle(s) as the batter cooks.
We have gone through 3 different bread machines and over time all eventually did this. A little wear on the spindle will loosen the paddle(s).
Hope this helps!
Dec 26, 2009 | Sunbeam 5833 ExpressBake Bread Maker
How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washihg paddle won't stay in
There is more than one version of drum paddles, assuming you have got the right one, then locate the paddle in the slots in the drum, and push firmly into place, you should feel it click in to place, to check, pull the paddle lightly back towards you, it should remain fixed in place.
Also make sure you have got it the right way round.
Please rate my solutrion.
Thankyou.
Jan 28, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Bread not rising enough
We had exactly the same problem. We contacted Panasonic who supplied bogus "advice" about changing the type of flour and using more water. We eventually discovered the reason for the problems: the mixing paddle was now a loose fit to the spindle. Part way through the baking process it would stick. We also have a solution. You jam tin foil in the gap between the spindle and the paddle, it works a treat. Don't waste you money on a new paddle, this won't be a tight enough fit.
Oct 24, 2007 | Kitchen Appliances - Others
Zojirushi BBCC-V20 Home Bakery Traditional Bread Maker Logo
233 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
