Question about Konica Minolta DiMAGE F300 Digital Camera
Ripples in the edges
Hello, I recently purchased a Minolta F300 5MP digital camera and I am just learning how to take proper digital pictures. I noticed that at the 640 x 480 Standard and Fine settings, some of the images have a noticeable 'ripple' along any of the straight edges of objects like a wooden shelf, the front of a TV, that sort of thing. Any idea what might cause this? Is this 'noise'? Any help would be greatly appreciated. If you think I should return the camera, is the Fuji F700 a better model? Thanks in advance
    Sergeant:
  • 255 Answers
The "ripples" to which you refer are called commonly called "jaggies". It is a phenomenon present on most cameras but on some it is more pronounced. Another problem is visible moir? patterns on repeat detail. These are usually the result of a problem with the CFA interpolation or sharpening algorithm in the camera's software. In any case, the result is noticeable "steps" on diagonals which shouldn't be there. The problem of moir? patterns is usuall more visible in finer details such as hair (as shown in the examples below) or repeat areas of an image (such as railings / fence posts into the distance). There is really nothing you can do about it, except to keep your file size and resolution settings on high for critical photos.
Posted on Sep 13, 2005
    Sergeant:
  • 255 Answers
It's an inevitable consequence of using a low resolution jpeg. Try setting your computer monitor to VGA resolution (640x480) and you'll make a similar mess of images it displays - only worse, because the large screen blows up the image. You should use a higher resolution setting and invest in a bigger memory card for the camera if need be.
Minolta card says locked. What do I do?
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 11, 2012 | Konica Minolta DiMAGE Z1 Digital Camera
Konica minolta dimage z6 card locked. how do i unlock it
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 19, 2011 | Konica Minolta DiMAGE Z6 Digital Camera
The display says the card is protected. I cannot erase a picture or add one. How can I solve this?
Oct 31, 2010 | Konica Minolta DiMAGE G530 Digital Camera
Hello I can not download picture to my computer ....it does not seem to pick up that anything is plugged in? please help
1. you want to purchase the data cable for your konica digital camera.
2.Then connect the one end to the camera.
3.Connect the other end to the computer's usb port.
4.Your camera will detected by the computer then you can access the pictures and import it to the computer.
5.Install your Driver CD which Came with the camera install it for better result.
Sep 12, 2010 | Konica Minolta DiMAGE Z3 Digital Camera
Yellow edge to preview screen
hello. you may be involved in a recall. please read this http://www.nikonusa.com/Service-And-Support/Service-Advisories/COOLPIX-Service-Advisory.page
please rate my answer as very helpful thank you. joe
Feb 15, 2010 | Nikon Coolpix S203 Digital Camera
What does it mean my memory card is protected cause now I can't seem to take any pictures. How do I fix that?
Hello,Please remove your memory card and check to see if the small lock tab is in the locked position.If so unlock it.This tab will be on the upper lefthand edge as you look at it ,it's very small.
Jan 09, 2010 | Konica Minolta DiMAGE G500 Digital Camera
Cam cannot mak any pictures. ''Error 2''
I have already answer to this problem. To try on solve it you need to remove the metal front cover and check if the socket of the large flat coming fron the back of camera is complete inserted on his shell, or if you damage the cable because the camera drop down
Apr 11, 2009 | Konica Minolta DiMAGE E50 Digital Camera
Sony Cybershot W55 digital camera- needs proper USB connector.
Hello Voyager2Lcat,
You need Multi-Use Terminal Cable for DSC-W55 and its Sony Part Number is 1-829-866-51
Picture is attached as reference.
May 27, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Left side of Image Blurred
Yes, this can be the lens. If the cleaning of the outside does not help please contact the nearest Sony Service. If you need more info please advice.
Jan 10, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
Konica Minolta DiMAGE F300 Digital Camera Logo
49 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
