Question about Protron PD-DVR100 DVD Recorder
The timer the clock keeps fouling up after it hits 12 am or pm it doesnt go to 1 am or pm instead it goes to 13 and 14 ectra how to straighten this out i have to reset it too much
Set the clock 1:00 AM then as the it gets to noon 1:00 PM it will read 14:00 then13:00 and so on, at 12:00 PM it will read 24:00 then back to 1:00 AM.
Posted on Oct 05, 2008
    Problem Solver:
Non whats so yet im waiting on a another person who had the same experience to aid me in solution protron went out of buisness thier product is a low price legtatmite multi region recoder but due to the small video converter it cant autyomaticly detect individual regions only pal encoded all regions disk so as a result this requires a change on the region itself to get it to detect individual regions for some reason they didnt put am or pm and im beging to believe that their clock is of millitary time and cant be change im waiting on some one with same experience
Posted on Sep 02, 2008
I dont no how to set the timer to 24 hr clock
change to 12 clock
however a 24 hour clock has the same times up to midday -- midnight to midday --- the hours are 1 to 12 oclock after midday you take 2 off the reading and it is the same time as a 12 hour clock
so 1300 is 1 o'clock, 1400 is 2 oclock ,1500 is 3 o'clock
1800 is 6 o'clock 2400 is midnight
the minutes are the same regardless so 1.30 is 1.30 after midnight or 1330 after midday or 1.30 after midday now for example --if you want the timer to start at 6am you set the timer to start at 6 am to switch off at 8 am set switch of at 8 am
it you want the timer to start at 6 pm set it at 1800 and switch off at 10pm set it at 2200 hrs
Jan 22, 2017 | Hardware & Accessories
How do you change the time from a 24hr clock to a 12hr clock. For example clock says 19:50 instead of 7:50 pm on a Brookstone 5-in-1 Sensor Clock.
Selecting 12- or 24- Hour Mode While in the Time screen, press or to select either 12- or 24-hour mode. If 12-hour mode is selected, PM displays for the afternoon/evening hours. AM does not display for the morning hours http://origin-www.brookstone.com/webassets/pdf/740687p_manual.pdf
Apr 06, 2016 | Brookstone Audio Players & Recorders
How do I get the clock to keep the daylight savings time and not revert when I restart the car?
set the time 1 hour fast as if you are setting the clock . So instead of setting it on 12 midday set it at 1 pm even though it is midday.. clocks do not know any different.
Jan 15, 2015 | Cars & Trucks
How to set the clock using 24 hr and 12 hr clock
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#oval
Add comment and describe timer in detail.
Usually if a timer offers choice between 24-hour clock with 1-thru-24 displaying for current time, vrs 12 hour am- 12 hour pm, then the choice is first thing you set before programming. The choice is made before setting current time, and usually this is accomplished with single button push that toggles between 12 and 24 on the display.
The product manual has specific steps.
Not every timer offers 12-24 choice.
Again, add comment and describe timer in detail, or attach photo for best available resources.
Gene
h
Aug 08, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
Mod 57880 am setting ok pm setting wont come on ?
Is this new timer?
Or timer that worked before and stopped working?
Check outlet with circuit analyzer for correct polarity and grounding.
Reset timer and re-program, being careful to avoid conflicts and/or overlaps. Each ON time must also have OFF time with consistent days for each. If selected time is 12:00, then use 11:59 instead to avoid possible problems with am and pm conflict.
product comes with 1 year limited warranty.
Orbit digital 57880 sprinkler timer manual is 19 pages long, which is good argument for using analog timers with 1 page manual.
Troubleshoot appears on page 18 of manual, and includes Tech service number.
http://waterheatertimer.org/pdf/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Oct 04, 2012 | Orbit Hardware & Accessories
Just installed the programmable timer and had programmed the clock and on off times. Then realized that it was set for AM instead of PM. Hit reset and now can't set the clock or program. Just blinks...
I test timers.
Some arrive defective, and some go bad quickly.
Industry standard is 1 year limited warranty.
All these timers have reset button that should restore functionality.
You posted under Woods digital programmable.
Open link to download on-line manual and read ez wiring steps.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
This timer is reset by pushing reset button, without pushing any other button.
Some timers require on-off button to be pushed while pushing reset button.
I suggest turning off power to timer and see if that 'resets' timer.
Otherwise open link below and run through troubleshoot checklist, and also double check wiring.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
If timer will not function correctly, then exchange for new timer.
Resourceful do-it-yourselfer can buy similar timer at Home Depot located near light fixtures and doorbells.
GE15086 -or- GE15071 with daylight savings time.
Advantage is ez exchange if problem occurs, and you give yourself extended warranty.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 20, 2011 | Woods InWall 7 Day Digital Programmable...
Need 12 hour setting instead of 24 hour
I owned mine for years. This seems to happen when the power goes out. Push the mode button twice to get into the time set section. Once you are there, just keep pushing the mode button until the "pm" notification shows up on the digital display in the upper left corner. Once you get that use the 1-4 keys to set the clock. Good luck.
Nov 07, 2010 | Sharper Image SI686 Clock Radio
Resetting clcok on Microwave Oven..
I have a Magic Chef microwave oven, The model # is MCD1311ST.
After I reset the clock when daylight savings time ended, it displays 1:00 PM as 13:00, 2:00 PM as 14:00, etc. How do I get it back on a 12/12 cycle instead?
Warren.
Nov 08, 2008 | Magic Chef Microwave Ovens
12 hour vs 24 hour read on clock
Push the "mode" button twice to enter the time change function. Once the display is blinking keep pushing the mode button until you see the "pm" icon on the LCD display. When that happens set the clock as you normally would using the 1-4 keys.
Remember to check if the 12 hour clock is set to AM or PM.
Good luck.
Sep 09, 2008 | Sharper Image SI686 Clock Radio
Clock doesn't keep time anymore
go into settings an reset dafault
Jan 04, 2008 | SanDisk Sansa e250 MP3 Player
Protron PD-DVR100 DVD Recorder Logo
130 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
