My Sampo 50" Plasma tv has started blinking whenever the image is bright. Lowering the resolution did not work Using the reset button allowed about ten minutes before is started blinking again
  • 4 more comments
  • Carrington D. Ash Sep 01, 2008
    I tried the solution and it took about an hour to start blinling again
    (Typo)
    It started blinking again after 1 hour
  • Carrington D. Ash Sep 02, 2008
    Its a SAMPO PME 50X7
  • Carrington D. Ash Sep 03, 2008
    My SAMPO PME 50X7 BLINKS ABOUT EVERY THREE SECONDS. UNPLUGGING IT AFTER PRESSING THE RESET SWITCH AND WAITING TWENTY MINUTES BEFORE RESTARTING IT DID NOT WORK
  • Carrington D. Ash Sep 04, 2008
    again
    Top Expert:
  • Televison & ... Master
  • 70,374 Answers
You have a part failing in the high voltage circuits that supply the Plasma display, this will most likely require a entire new circuit board, in short it will end up being cheaper to replace the TV, the new LCD"s are cheap and very reliable.
Posted on Sep 04, 2008
  • 4,234 Answers
Ohms was on the right track. A brighter picture will require more power. There is a problem within the power supply and the protection circuits are kicking in to prevent further damage. Since this works for a while before the problem shows up, I'd be looking for either connection problems or a heat related component failure. This is not likely to be diagnosed remotely. A service tech will need to reproduce the problem and then use a "freeze spray" to locate the offending component. Since there are high voltages inside and the panel is very fragile, I would suggest that a service center be used for this repair.
Dan
  • 1,879 Answers
When it's BRIGHT, more power is needed (by default screen color is DARK so low or no power is needed).
Internal electronics issue. Got the know-how to look at electronics ?
Posted on Sep 03, 2008
  • 10,594 Answers
Kindly mention exact model number of your TV to understand its problem.
Posted on Sep 01, 2008
  • Shahid Electronics
    Shahid Electronics Sep 03, 2008
    You TV requires qualified TV tech person because plasma tv has complicated digital technology and its not advisable to resolve at your own.
    Shahid Electronics Sep 04, 2008
    My suggestion remain same :)
    Sergeant:
  • 241 Answers
YOU HAVE THE MANUAL LOOK IN THE TROUBLE SHOOTIN GUIDE... Or the on screen menu has a reset back to FACTORY DEFAULT setting (VIDEO) section of the menu
But try to unplug from the wall wait a few minute plug back in
TRy to see if you rvideo connection are all connected in the slots
If the TV is covered by the Warenty call 1-800 number SURE WISH YOU LUCK AND ALL THIS GREAT TECH WILL FUTHER AID YOU
  • Jayson Brollini
    Jayson Brollini Sep 01, 2008
    HI WAS THE PROBLEM SOLVED
  • Jayson Brollini
    Jayson Brollini Sep 02, 2008
    OK I am going to suggest that you go in to the menu settings and (lower) the>Brightnes< & >Contrast< 50%
    See if the TV starts to have the same problem
    IF this continues THERE is an internal problem with the board or power module...... PLEASE bring ot to a Autorized Repiar man>
    Most TV specialist will not charge you not look at it and what ever the fee is (small) they will apply that to the repair cost so you are not charged EXTRA
    I sure hope this help you narrow out the problems
    Plese don't forget to
    Rate the Advise from FixYa ExpertKindofcheap
    President:
  • 1,263 Answers
You need to go into your set up menu and adjust the convergance this should fix the problem. if the problem persists unplug the set wait 20 minutes and plug back in and use the master reset...... please rate this
Cannot get my playstation 3 to work,the sound works but no picther.i have it hooked on hdmi.its not the cabel because it works on my other tv
The only thing that comes to mind is maybe you need to reset it?? If your other tv can display high resolution than the newer one it might be blacking out. When the ps3 is on, hold down on the power button for a few seconds until it beeps. This should reset it and allow you to change your display to suit the new tv.
Aug 31, 2011 | LG 50PC3D 50 in. Plasma Television
Trying to connect my 50 inch 50PC3D plasma tv, to my playstation 3 using HDMI cable. The tv is giving me an invalid format, is there an explanation/solution to this?
The PS3 video resolution setting is too high for the TV to work, please see your PS3 user manual on how to lower the resolution to the native resolution of this TV.
Jun 29, 2011 | LG 50PC3D 50 in. Plasma Television
Hi, remote not working and unable to change channels using tv buttons. other buttons on tv - volume etc are working fine
if your remote is for cable, then you have to push the cable button, then change channels. volume will work only on tv mode.
Oct 06, 2009 | Sampo PME-50X7 50 in. HD-Ready Plasma...
50" plasma wont turn on!!
To reset a TV you simply unplug it for an hour. Your TV needs to be repaired. If you're under warranty the repair will be covered. If you're out of warranty you need to be prepared to pay at least a couple of hundred out-of-pocket.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 03, 2009 | Philips 50PFP5332D 50 in. Plasma...
Technika Pro 19" LCD TV/DVD LCD19B-M3
when i watch a dvd on my technika it is green how to i reset the settings so that the colour is normal?
Dec 28, 2008 | Sampo PME-50X7 50 in. HD-Ready Plasma...
In my solution I suggested part-store where you can find boards for your tv. I'm not sure what board is defective as TV isn't in front of me and in my opinion you need qualified tech person to identify what board is required to resolve the TV issue.
Thank you.
Sep 03, 2008 | Televison & Video
Sampo TV parts are available HERE on cheaper price.. Please ask for required parts.
Sep 02, 2008 | Televison & Video
Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Dec 24, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
