Do not use test button. It test the functions of the board only. You have another issue. Need to know the number of beeps. Usually beeps a certain number of times, then hesitates,then beeps again.
The beeping in ice machine is a code. Take off the electrical panel cover. Carefully look for and press the small reset button on the board. This will restart the machine. If it shuts off again call a service company out.
3 beeps means the machine has ran two 1 hour cycles back to back to make ice an average timeframe for ice making is 25-30 min. Could be several issues, float switch dirty, water valve leaking by, dirty spray tubes, dirty evap., then go to refrigeration Expansion valve, compressor, charge, Hot gas valve leaking by,,,,,
If you take the front cover off and look on the flip side of it, there should be a chart telling you exactly what the beeps mean. If it is not there or if you can't find it, let me know and I will clarify it for you. It may help to let me know how many times it beeps. It should beep from 1 to 7 times and then repeats. Also on the board, there is a very small reset button. Usually either black or white. You have to look very close, but it should be there. I would not reset it at this time, untill you find out what the beeps are trying to tell you. There is a reason the machine shut down on it's safety device.
Good Luck and let me know if I can help
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
the beeping is a fault code i need to know how many beeps it does before it starts over Also you can shut down the pwr this will reset it but if you dont fix the fault it will return
How many beeps at a time?
