Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Cannot connect to my network
I have the 1310 Router and I am connected perfectly with my desktop computer, my other desktop that I installed the D-link DA-1320 wireless adapter can connect to another persons wireless network but although mine shows available it says "windows unable to connect, the network maybe to far out of range, please refresh and try again". It has sometimes 3-5 bars while the other one is one bar. What is wrong?
  • legolott Sep 02, 2008
    i am having the same problem. my laptop will find and connect to my neighbors unconnected network but not mine, even when it shows three bars.
  • 2189 Oct 20, 2008
    I forgot my password.
    Scholar:
  • 65 Answers
If it happens to be a Dell, I think they have a specific configuration or something that has to be changed. For that I'm pretty sure you have to contact Dell, or look on their website.
The way that some routers are set up you have to have a certain pass phrase to access the wireless connection. And make sure, by opening the wireless network monitor, the icon should be in the lower right hand corner by the clock. That you are connecting to the correct user account on the router. Some router configurations require a different user account for each wireless device connecting to it. Or the computer trying to connect you may have to manually select from that menu in the wireless network monitor..
Posted on Nov 27, 2008
How to connect to desktop
In my experience, you very rarely actually need the disk for the router to connect another computer.
If you're using an ethernet connection (since you say desktop) you should just be able to run it to the computer. Make sure your computer has its NIC drivers installed (in all likelihood that's not a problem) and give the computer a good reboot and that's that.
If you're connecting wirelessly, using Windows you can open your network connections via the control panel. Right click your wireless adapter and connect using windows. If you need the wireless SSID/Security Key or anything else, you can get that using any computer already working with the router by logging into the DLink
If you're using a USB connector to connect, you'll want the CD for that.
Jan 16, 2012 | D-Link 802.11g Wireless Router WBR-1310...
Laptop cannot aquire network address from wireless router
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Make sure that the DHCP server on the router is enabled
Click Here for step by step solution
Apr 30, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Do i need to install the d-link wbr-1310 to my new laptop to get it operational. it indicates that there is a wireless connection but is requesting additional information.
I think you have windows vista on your computer. When you try to connect to the wireless network it will ask you for additional log on information. I believe you wireless network is secured. You don't need to install the router on your wireless laptop. All you need to do is connect to the wireless network. First check the wireless settings of the router. Once you get the wireless settings on the router, add the wireless network manually.
Mar 04, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How to secure connection on WBR-1310 d link
To secure the wireless network, you will need to access the router set up.
Is there any computer connected to the router ?
If not then you will need to connect the router to the computer .
Then check the IP address of the computer and open the router set up.
Click Here for step by step solution on how to secure the network
Nov 21, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I just installed the Dlink wbr-1310 wireless router on my computer. I have a dell dimension desktop that is hard-wired (cat5 or 6 cable) directly into the router's #1 port. Previously, the broadband...
Get rid of AOL network magic. I'm not familiar with either but I do know it's designed to help people who have no idea how to setup a home network. Log on to the routers cofiguration page and look at the router status to determine what the issue is. i.e is the router dropping the internet connection or is the router not connecting properly to your computers? If your using static IP addresses then you will need to re-configure these for the new router. Start by switching back to dynamic IP on all devices connecting to the router. It may always be a firmware issue with the router. If these steps don't work try updating the firmware (there should be an option in the config page (192.168.1.1)
Jul 19, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Connect Additional Computers to my network
ok
first install your wi fi network adapter driver in computer also if you have laptop then there is switch for wi fi on it.
Then go to my ntwork polaces there you see your wi fi network.
Also check your wi fi enabled in router .
Let me know
Jun 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
WIFI & WBR 1310
Fix your router again. If the wifi is fine, you just have to let the nintendo search for the wireless network and connect to it. You don't have to do anything on the router to let your nintendo to connect.
Feb 16, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Connection of D-Link 02.11g/2.4GHz Wireless Router
Connection can either be wired, or wireless.
If wired, connect a cable from one of the ports of the new PC to one of the ports on the back of the router.
If wireless, you will need a wireless card for the new PC. Install the card, set up security, and you will be connected.
Jan 20, 2009 | D-Link 802.11g Wireless Router WBR-1310...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
121 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
