Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
19"electric mower I cleaned out my mower, change the old blade with a new one. Started the mower and made a back sound like the blades were hiting the rubber cover. So, the blade was loose, so I did it again and the blade was good to go. So, I started it back again and sounded great, within 3sec.a puff of black smoke came out of the starting handle. I waited awhile, and started it back again and sparks came out of the starting handle. Did I burn the engine?
    Champion:
  • 313 Answers
Contact on switch are possible gone or worn.you can replace be yourself as long as yuo follow the old connection
Posted on Sep 05, 2008
How do you change a blade on a black and decker Rota-twin GR101 mower
my search shows that up as a
black and decker /flymo electric mower type
no picture on the parts list
of the rotating part being metal
two types of blade sets ...says its plastic and just clips on
is that for real ....plastic clip on mower blades
will this work
pull to the larger slot to release the old blade and back to the smaller slot to hold the new blade in place
Jun 15, 2016 | Cars & Trucks
I have a black and decker lawn hog mower with a 19 inch cut that i am trying to change out the blade. My problem is i cant get the mounting nut off becausethe shaft keeps turning. I have tried everything,...
are you turning nut the right way ! on a lot of mowers, the nut turns off the opposite way the blade turns, to keep it tight. good-day ! Loosen the nut in the center of the blade with a wrench by turning the nut counterclockwise.
Jul 14, 2011 | Black & Decker 19" Electric Lawnhog...
Hit a rock and warped the blade, bought a new blade but I can't get the old one off
I don't know for sure on your mower but on many the bolt at the center of the blade is reverse threaded, so it's righty-loosey. So you will turn it clockwise to get it off. Use a piece of 2x4 to hold the blade while you turn it, try WD-40 also. Be careful because if you were turning it the wrong way you will have to push hard, and if it breaks, or the wrench slips off you can damage yourself.
Jul 10, 2011 | Black & Decker 19" Electric Lawnhog...
Shaft turns when I try to tighten the mower blade
Remove the bolt, washer and blade. Use a wire brush or sandpaper to clean the end of the shaft and the blade where they make contact. Clean both sides of the washer. Clean the underside of the bolt head and the bolt threads (with a wire brush). Put just a little oil on the bolt threads and on the underside of the bolt head. Reassemble.
Jun 17, 2010 | Black & Decker 19" Electric Lawnhog...
Too much noice & vibrations on my electric lawn mower of late
The blade is most likely unbalanced. Have you tried cleaning the blade? If caked on grass & dirt is not the problem, you should replace the blade.
May 25, 2010 | Black & Decker 19" Electric Lawnhog...
Can't chnge blade on Black and Decker 19"Electric
if you can try to pull up on blade as you try to loosen bolt see what happens that will sometimes help get past stripped threads
Jun 13, 2009 | Black & Decker 19" Electric Lawnhog...
Electric mower will not work
the shear pin has broke on the drive shaft put a new one in.
Apr 28, 2009 | Black & Decker 19" Electric Lawnhog...
Black & Decker MM875 blade
You can pick up a blade at almost any hardware store.
Sep 26, 2008 | Black & Decker 19" Electric Lawnhog...
Put on mower blade for black and decker lawwn mower
Hi, unplug the spark plug wire.turn the mower on its side, in the middle of the blade there is a bolt. Unscrew the bolt on blade to take it off, and to put it back on, put blade on first and bolt it back together.
If this doesn’t work for you, please write back.
Thanks
Sep 22, 2008 | Black & Decker 19" Electric Lawnhog...
New black and decker lawn mower, MM875 starts but I cannot get it to cut, what am I doing wrong?
did you sharpened the blade. checked the blade if not installed reverse.B&D clean the blade. info in the blade say's facing the grass
Aug 17, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
