Question about Canon PIXMA iP1600 Printer
Canon Pixma iP1600- Service Error 5202
I just got my ink cartridges refilled, and my printer was fine before. Now, I keep getting the Service Error 5202. I tried running the cartridges in warm water, soaking it, and ink does come out.
What should I do?
Thank you very much! :)
  • 1 more comment
  • Anonymous Oct 12, 2008
    The following ink cartridge can not be recognised-color.
    Whenever I try to print, I get the above error message, though there is no error number.I started getting this error message in middle of a job.Pl. help.Thanks
  • joycewny Apr 14, 2009
    Canon Pixma iP1700- Service Error 5202
  • JDTec
    JDTec May 11, 2010
    does it give text error message with the error 5202?
Silly as it my sound. But you did take the protective plastic cover off, didn't you?
Posted on Sep 30, 2008
Waste ink absorber is almost full.
pls solve this problem.
Posted on Oct 12, 2008
I refilled my black cartridge of Pixma iP 1600. I have done it 3 times before and it worked perfectly until yesterday. Now when I refilled it the 4th time, the yellow LED blinks 5 times and then the green...
The manual for the PIXMA iP1600 says the following concerning the 5 blinks:
The ink cartridges are not properly installed, or a non-supported ink cartridge is installed (the ink cartridge EEPROM data is abnormal). Install the ink cartridges properly. Or, confirm that the supported ink cartridges are installed.
If you haven't already I would take a look at the electrical contacts on the cartridge to make sure they are clean (free of dust and ink) and then reinstall them in the printer. If the printer gives the same error, it's time to buy a new cartridge. 3 refills from a cartridge is not bad at all.
Hope this helps,
Steve
Feb 10, 2011 | Canon PIXMA iP1600 Printer
Refilled the ink cartridges on my Canon PIXMA iP1600, as I have often have. Now it will not print in color very bright / the font size has been reduced considerably / I have chosen the three options of...
Ink cartridges can't be refilled more than a few times before they lose vacuum or can hold pressure which can affect performance.
Try to use only genuine new Canon cartridges for max. performance and quality.
Feb 03, 2011 | Canon PIXMA iP1600 Printer
The error number 1660, how do i reset the printer to take refilled cartridges
You don't reset the printer, you reset the cartridges. If the inks have a little circuit board on them you go online and buy a chip resetter, or you buy refilled cartridges that have a new chip on them already. There is nothing in the printer to make it take refilled inks.
Jan 29, 2010 | Canon PIXMA iP1600 Printer
I have been purchasing the less expensive ink cartridges (#30 and #31) for my pixma ip1600 and they have worked fine. I just put a #30 in my printer and it won't work. What happened?
Was the replacement cartridge Canon brand on a refill? Either way that style Canon printers are designed to not accept refiled printer cartridges for the 30s, 40s or 50s. It is likely that the printer deemed your cartridge not an un-used original and turned it into an inky paper weight. I would return the cartridge to where ever you purchased it and be sure to only purchase new Canon brand for that machine.
Jan 18, 2010 | Canon PIXMA iP1600 Printer
After refilling the colored cartridge, error message say that the colored cartridge is empty what do i do?
There is no way to reset the ink levels on these cartridges. If the printer will print, just print until the ink runs out. You can also tell your printer to "ignore ink levels" so you don't get the low ink message every time you print.
Dec 30, 2009 | Canon PIXMA iP1600 Printer
I bought a refilled black ink cartridge for my
Replace color cartridge.Printer can't print without color cartridge.In your case the color cartridge is failed.
Nov 24, 2009 | Canon PIXMA iP1600 Printer
My refilled canon ip1600 ink jets are reading as empty
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Jun 09, 2009 | Canon PIXMA iP1600 Printer
How to refill canon pixma ip1600 ink colour? the hole is too small.
IF YOU HAVE BUY THE INKS THEN YOU GET NIDLE AND SIRING THEN YOU WILL USE THE TECHNIC DOCTOR USE TO SWAP THE LIQUID FROM THE CONTAINER AND INJECT IT IN THE BODY YOU WILL USE THE SAME TECHNICS GET THE INK IN TO THE SIRING AND PUT IT IN THE CARTRIDGE BUT MIND YOU LOOK AT THE HOLES VERY WELL RED HOLE WILL BE MARK RED, BLUE WILL BE MARK BLUE WHILE YELOW WILL BE MARK YELOW SO ALL YOU NEED TO DO IS FOR YOU TO PUT THE INK IN THE RIGHT HOLE IN SOME CARTRIDGE THE HOLES WILL GUIDE BY A OBJECT REMOVE CAREFULLY THEN AS YOU FINISH REFILLING EACH HOLE PUT THE OBJECT BACK.
Nov 13, 2008 | Canon PIXMA iP1600 Printer
Refilled cartridges
Most manufactures put small chips in the ink cartridges. The driver software knows when you have inserted a re-filled "same cartridge". Hence you get an error.
Theres one way around this wall.
Keep at least two emptied cartridges. (Prefered three).
Go ahead & refill them & store them standing up so the nozzle does not dry out. Rotate your replacements.
Nov 07, 2008 | Canon PIXMA iP1600 Printer
Printer wont recognise new colour cartridge
most common, is there is a tiny piece of lint or paper shred, has worked its way between the ink cartridge and the print carrieage connectors,
take the cartridges out and wipe down the connectors on the cartridge and carriage with a lint free cloth or lens brush
Isopropyl alcohol is a good residue free cleaning fluid,
if no all the connectors answer, the printer assumes a wrong cartridge
not a guarantee, just something to try
Sep 03, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
2,932 people viewed this question
old marine
old marine
