Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 bottom bulbs
Both of the bulbs located under the above unit (to provide light over the stove) burned out and I put them on the counter to match up with a replacement. They got thrown out by accident. The place where you insert them is at the front edge of the opening under the unit, and it's impossible to even see how wide apart the prongs should be. I tried a bulb from another halogen appliance, it didn't fit. Do you have any idea what the number of the bulbs would be?
  • 1 more comment
  • ddunat Sep 01, 2008
    I'm sorry, but the kind of bulb I need is tiny with two prongs that plug in. I think I've found a replacement number now, I'll have to buy one and see if the info is correct. Thanks for your help!
  • ddunat Sep 02, 2008
    I'm pretty sure I did, it was right from the GE website and I used the model number of the microwave.
    Yes, I have a pair of cotton gloves on the shelf just for that purpose! Thanks again!
  • prothroast Feb 21, 2009
    I have the same exact issue
  • 706 Answers
Here is a link to the replacement light bulb.. Hope this helps
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=259682&PPStack=1
Posted on Sep 01, 2008
  • Rick Gelin
    Rick Gelin Sep 01, 2008
    Hope you found the right one.. if they are quartz/halogen ..remember to wear gloves so as not to leave skin oil on the quartz which will cause premature bulb failure...
Light bulb above stove under microwave hood
According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
Sep 25, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
I have the GE profile spacemaker microwave oven installed over my stove. One of the lights burned out on the left lower portion of the unit. I removed the screw, lowered the metal cover, and tried to...
You could try the potato trick. Take a small to medium potato. Cut off an end of the potato. Press the cut end into the broken lightbulb and unscrew the rest of the bulb out.
May 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE profile spacemaker XL1800 undercabinet microwave - how do you change the 2 lightbults under the microwave. I can't get the bulbs out.
There are several screws on the bottom panel that can be removed. After you remove them, the metal plate can be removed or just lowered at an angle. Using a flashlight, you will see the two bulbs that probably need replacing. Pull the wire down, and they can be easily removed and replaced.
Hope this helps.
Nov 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker XL 1800 undercabnet microwave
hold down the clear/off button for 3 seconds and it will unlock..
Jan 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Dec 23, 2007 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
2,148 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
