Question about Toshiba 50HP66 50 in. Plasma Television
No power to toshiba plasma tv
Today, my wife was watching tv and suddenly, it went black. now the tv does not even turn on. the red power light does not even come on. it is not an outlet issue. other devices work on the outlet.
how do ficx the problem without spending a lot of money on it? i think i'm pretty handy so i cna replace the damage parts myself. however, i do not know the parts i hsould replace.
  • kimlong Sep 05, 2008
    Our 50 HP Toshiba turned off today and the red power light on the front is blinking. The TV will not do anything unless you unplug it and the light goes off. Plug it back in and the light starts blinking again.
Actually, I replaced the main power supply board and the tv is working now. I paid $140 for a new board and replaced the fuse. The tv turned on right away.
Posted on Oct 08, 2008
We were first told it was the power suppy source and after waiting 2 weeks to get the power supply source that did not fix it they think it is the Sein Board...$900 problem on a TV that is less than 3 years old. The Sein Board was ordered 3 weeks ago and the repair man said it is on back order and will not be in until the end of October....If there are enough Toahiba 50 plasma's with the same problem Toshiba should help out with the repair!
Posted on Oct 07, 2008
    Sergeant:
    Champion:
  • 223 Answers
This answer is for sjmhan: It sounds like you have a fault on the power supply board of the tv. Please before you open up your tv find out how to take basic precautions against electrical shock and how to discharge capacitors safely. First check if there is a glass fuse inside of the set and if it has blown replace it with one of the same rating. If you replace the fuse and it blows straight away or it still does not come on then it could be quite a few things. Either a faulty resistor or diode or voltage regulator or even the mains transformer itself. One word of warning: NEVER toucch any of the pins of the transformer as this cannot be tested directly without specialist equipment. If you find that it all is too complicated for you then dont feel like you have failed just re-assemble it and find a competant technician. Good luck.
Kimlong: I think you have a faulty component on the power supply board most likely a faulty diode. If you can check this for yourself otherwise find a competant technician. Hope this helps.
  • Paul Oct 07, 2008
    Kimlong my friend that would mean Toshiba ADMITTING liability for a known fault on that particular model and somehow I think they will keep very quiet on that one :-) Good luck but in defence of the technician he can only go on what faults present themselves and the problem is so many faults mimic other faults that sometimes it takes a lifetime to get a tv up and running. Good luck with it.
Panasonic Plasma 50 TH-P50U30A blacked out with no sound
Appears to be a power supply issue with everything being so dead.
Jan 22, 2017 | Panasonic Televison & Video
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Blinking red light
I am in the same boat as you are. My wife and I had watched the Steeler MNF game yesterday evening and today when I went to turn on the Pens game, all I got was a blinking red light and a "power on" sound...wtf...Can anyone help? I'm definitely not a techie nor have I ever soldered anything...
Sep 29, 2009 | Toshiba 53H71 53 in. Rear Projection...
Plasma tv just blanked out on me
Y SUS and Buffers are usual culprit.
You can get it from guy at
plasmatech@gmail.com
He has everything for Dell TVs
May 31, 2009 | Dell W4201C 42 in. Plasma HDTV
TV suddenly shut off, blinking red light in power button
The TV's power supply capacitors probably went bad.
Check with a mobile tv repair co. to see if it is worth fixing.
Dec 20, 2017 | JVC GD-V502U 50 in. Plasma Television
Power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
Aug 15, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Toshiba Plasma TV Green and Pink (Diffusion?) Problem
I could be wrong but sounds like your plasma display is going bad. What is your model number?
Dec 28, 2007 | Toshiba 42HP66 42 in. LCD Television
Toshiba 50HP66 50 in. Plasma Television Logo
512 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
