Question about Konica Minolta DiMAGE A2 Digital Camera
Focus Problem Hi, I'm a new A2 owner, and I'm having problems getting pictures in focus especially when using telephoto zoom. Any one out there have an A2 and could give some suggestions that might help.. Thanks
    Brigadier General:
  • 3,006 Answers
The A2 uses contrast detection AF and so is a bit slow, especially in low light. I find that I get best results by setting the AF slider on the left hand end of the camera to "S" (focuses only when shutter button half pressed). The "C" setting for continuous focus is too inaccurate in all but the brightest conditions and also reduces the (already poor) battery life hugely. The very best results are obtained if you delve into the menu and set the autofocus so that the manual focus ring can always override it. You can set the AF slider camera to "MF" (manual focus) instead, but the focus ring is not mechanically coupled like the zoom ring is and so it lacks tactile feedback and can be very slow. if you do as I suggest you get fast but unreliable AF and quick enough correction to what you require.
Unfortunately, my experience of this model and the closely related A1 and A200 is that the AF often hunts around a bit and it took me a long while and many missed shots to get used to it.
Posted on Jun 29, 2009
As stated on page 145 of the A2 manual: "When using this camera with the optional supplementary lenses, the accessory must be specified in section 5 of the setup menu. For more information on the Wide-angle Converter ACW-100 or Telephoto Converter ACT-100, contact your local Konica Minolta dealer. A firmware update is provided with these products to activate this option."
Posted on Apr 01, 2007
Zoom out to how you want the picture to look like and press the button that takes the picture 1/2 way down and look at what the picture will now look like. If still fussy, then back off the zoom a little and try it again. Another solution is to get a digital zoom like a doubler that will screw on with an adapter and then no matter how fast or slow you zoom in on something, it is always clear.
Jamie
Posted on May 08, 2008
I just got a Bower Elite series 4.7x Xtreme high definition AF telephoto lens for my Nikon L810. Installed but it won't focus correctly. Does the camera need to be taken off auto focus, if so how?
It's not actually a telephoto lens, it's a telephoto adaptor. I have used something similar, though not this actual model, and only on MF lenses. Have you tried at all focal lengths of the zoom - it may only operate within certain limits. If it happens constantly, then you may need to switch to manual focus.
Apr 29, 2017 | Nikon Cameras
Why wont my Olympus zuiko 300mm lens zoom to max length?
Most camera's can't focus when the aperture number is above 5,6. Although your tele zoom starts at 4,8, it reaches the 5,6 at about 150 mm. So from there and up it can't auto focus. You still should be able to focus manually, but for wild life or sports pictures, it is useless.
Aug 25, 2014 | Olympus M 75-300mm F/4.8-6.7 ED Zuiko...
Telephoto opteka instructions
There are several reasons why you have to use this lens in manual mode. There is no chip in it and no focus motor. But even if there was a focus motor, your camera could not focus automatically, because the highest lens opening (smallest aperture number is f/1:8 on 1300 mm it is even f/1:16) Your camera only can focus on AF if the aperture is or is smaller than f/1:5,6. For the rest, you should chose the M on your mode dail. and then you can just press the shutter release button. Look on the screen how the histogram looks. If the histogram is to the left, the picture is to dark, so you should choose a longer exposure, if the histogram if far to the right, the picture is to light, so you should choose a shorter time. Have fun.
Nov 24, 2013 | Cameras
My Nikon D40x will not always take a picture when I push the shutter and will not focus whats wrong with it?
I have the same problem and I make this: take out the zoom lens from the body and put it again. The auto-focus comes back. Another my solution: Push autofocus buton to M (manual) and back to A (auto). Then sometimes starts again to work autofocus. But still I know it is not final solution...
Zvonko
Feb 12, 2013 | Nikon D40x Digital Camera
Lens is "searching" for focus at 200mm
Hi Martha,
Many zoom & telephoto lenses start out with relatively small apertures (compared to those fast prime and wide angle lenses) and get smaller as the focal length increases. It is because of this reduction of light that the camera's auto focus electronics is having difficulty determining focus. As a result, it "hunts" for focus near and far, and then gives up.
The only things you can do is provide more light on the subject (if possible), switch to manual focus mode and perform the focusing yourself, or use a lens with a larger aperture.
Of course, all this is assuming that the camera and lens are in good working order. If there is an issue with or the other, it may be contributing to the problem.
I hope this helps & good luck!
Mar 01, 2012 | Cameras
Canon 75-300mm USM III, was initially working fine
Hi
you seemed to have a problem with the camera (auto-focus) mode. I suggest you try shooting in manual focus only but consider taking it to a canon service outlet for proper checks and service as a long-term solution.
Apr 04, 2017 | Canon Zoom Telephoto EF 75-300mm f/4.0-5.6...
Blurry pictuers
First of all, tele-multipliers or tele-converters do not have the greatest optics in the world, and are usually fine for close up images but not much else. Secondly, they do restrict the amount of light coming into the camera which could interfere with the internal metering. Third, you have additional lens surfaces to get dirty. To fix the problem, start with the easy one, and clean all lens surfaces meticulously with a soft lint free cloth. If that doesn't fix it, try shooting non-moving objects in brightly lit areas. If you are still getting blurry pictures, try using the tele-converter on a close-up image within the focal length of the lens combination. If that doesn't work, give the teleconverter to someone you don't like and go buy a good quality 50-135mm zoom lens. Vivitar, Sigma, or other similar lenses are good quality and are very reasonably priced.
Mar 02, 2009 | Digital Optics 52mm Camera/Video 2.0x...
Purchase Zoom Lenses
Canon currently makes super Telephoto lenses from 300mm to 800mm and a number of zoom Telephoto lenses from 28-300 to 100-400. You can also special order a 1200mm lens from Canon at a cost of $99k! (There are only about 20 such lenses made so far.)
You can also get a 1.4 or 2x teleconverter to further increase the power of a telephoto lens. However, the cameras are unable to auto-focus when the minimum f-stop exceeds f/8, which can happen when you use one (or both) of the teleconverters on these longer lenses, so you have to manually focus the lens.
You can also get telephoto lenses from other manufacturers such as Tamron and Sigma that are built to work with Canon cameras. However, the Canon lenses are generally regarded as the best quality.
Dec 21, 2008 | Nikon D70s Digital Camera
Lens
Sorry, the mounts of Minolta manual focus lenses are different than their auto focus series. Sigma, Tokina and Tamron all make compatible zoom lenses to fit the Maxxum series cameras
Dec 30, 2007 | Minolta Maxxum 400si 35mm SLR Camera
Losing focus
Usually this is a back focus problem; also called a flange back adjustment.  If the back focus adjustment is possible on this camera, zoom out wide - open iris all the way - and adjust focus and lock position.
Nov 06, 2007 | Sony Handycam DCR-VX2100 Mini DV Digital...
Konica Minolta DiMAGE A2 Digital Camera Logo
152 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
