Question about Meade DS-2114 ATS (325 x 114mm) Telescope
Cant see a thing!!!!
I am 12 yrs old and a future astronaut This is my first "Real" teliscope. PLZ HELP!!!!. I have recently built my new teliscope (Meade DS-2114) And this morning 2:52am I had for the first time alligned it. Averything seemes to work just fine. Then when I observe the north star. I see nothing but blackness.. :( . I checked everything. Removed lense cap, I re-allind the WHOLE thing according to date time daylight savings and the direction 'NORTH'. But I cant see anything! Then I relized that there was no light inside the teliscope? .____ Do I need a light? Or does it use reflecting light?___
  • gabby1560 Dec 26, 2008
    HI...just got this new telescope for Christmas and was going to use it but after I got everything aligned ok, I went to look through the lens and see absolutely nothing, just complete darkness. I looked at the front of the lens and noticed that the huge glass lens is covered by some sort of shield. How do I remove this..do I take a screw driver and remove the whole thing? Please help!!!!! Thank You!!!!
    Problem Solver:
  • 5 Answers
Use the laser pointer that you put on the telescope when you were putting it together. or take the whole front cover off and look at the reflector and see if you see anything if you do try it again and see if this info helps please respond thanks and your welcome
Posted on Nov 11, 2008
Taotao 125 12 volt atv brand new. Will not stay cranked. HELP 9 year old having fit
You might check the battery charger.... Some of these smaller foreign built ATV's have a battery charger that comes with them. I am not sure what the real problem is tho... Does it crank at all? Does it produce a clicking sound instead of turning the engine over?
Dec 30, 2014 | ATVs
Our GE Profile is'nt cleaning like it used to. 5 yrs old. We have well wanter. Could a filter etc. be plugged?
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 01, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
Have a 12 year old kitchenaid Superba stainless steel built in microwave. I suddenly stopped and "door' lights up on display. Door is shut hear clicking by left side may be a latch issue. How do you fix?
Hi - it is 12 yrs old so parts may not be available for it.
If its a door problem, then its really a door latch switch or switches that has failed. Time involved in removing case, then switches then checking them all then finding replacements at ?? cost is uneconomic.
Please consider getting a new machine - probably use less power, have more features and work a darn sight better than this old one.
Jun 08, 2010 | Microwave Ovens
Bought Proview at future shop or best buy don't remember rx276 model 2600 27 '' .. built 2005 .. the antiglare wore off 2 yrs ago so it looks as if something was burnt in .. will not shop best buy or...
try a tv repair shop if not too expensive get them to fix it if it is too expensive put it on ebay and get what u can out of it and we learn from our mistakes and cut our losses
Feb 24, 2010 | Televison & Video
My card XFX Nvidia 8600GT DDR3 256MB was working fine, recently it started to get heated up very quickly & burning like anything, now it wont even let my pc boot, i removed it & my pc boots up fine...
There is no need to go for another card just keep you pc well ventilated. and try to install some cooling fans in it. but if you want real cooling solutions then just purchase a coolermaster gpu coolers from the shops and i tell in the whole world that, they are the best company in producing CPU and GPU Coolers.
Feb 05, 2010 | XFX NVIDIA GeForce 8600 Graphics Card
I have 3 compressors, all of them refuse to stop compressing until i manually shut them down,husky 26 gallon upright 5 yrs old, porter cable pancake 2 yrs old. and a master elite? came from home depot as...
the regulator/switches are either rusty, clogged, or need to be replaced. if you have some machanical aptitude and common sense this should be easy, if not have a pro or someone some knowledge of this type of thing handle it for you. in the future drain your compressor DAILY to avoid this problem
Nov 13, 2009 | Porter Cable Air Tools & Compressors
Ge dishwasher is 12 yrs old. water doesnt drain, checked trap, its clear..
check the pump and motor to see if it is working the motor might run but the pump could be to weak to move the water, and the opposite the motor could be to weak. if you hear the motor run then its a fairly simple test put a small rag in front of the intake to the pump and carefully move it close to see if the pump tries to pull it in dont let it suck it in that will cause lots of problems.
Dec 09, 2007 | GE 24 in. GSD3620Z Built-in Dishwasher
Meade DS-2114 ATS (325 x 114mm) Telescope Logo
179 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
