Question about Panasonic Microwave Ovens
I have a 1994 Pannasonic Microwave Model T994sf . The microwave does not heat and somtimes turns off after 20 - 35 seconds. I chnged the fuse and it still does not heat up. Can you help?
  • 706 Answers
When the cost to repair exceeds the cost to replace, it isn't worth repairing. That Microwave is > 14 years old and chances are the Magnetron tube or the filamant power supply is failing after all the use. If I were you, I would consider buying another Microwave to replace it.. Hope that helps..
Posted on Sep 01, 2008
My microwave stops after 3 seconds
Saved me a possible big repair bill. Thank you.
Jun 04, 2014 | Panasonic NN-T994SF Microwave Oven
The turntable keeps rotating when the door is opened - Panasonic NN-T994SF
You probably have a shorted main relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic NN-T994SF Microwave Oven
Turntable will not turn.
1) a very likely thing is that fluids have gone down the stem of the drive and it has now seized the motor.
2) the most usual things are a fault in the bushes etc. This site would be a good place to be looking for advice in that respect. http://www.partselect.com/microwave+carousel-wont-turn+repair.htm
Jul 21, 2011 | Panasonic NN-T994SF Microwave Oven
My Panasonic NN-T994 Microwave oven died today. Would run for a few seconds with a clicking sound and an electrical smell. I removed the cover, restarted and found arcing from the area of what I think is...
From your description it does indicate a magnetron problem, you would be further ahead replacing the microwave oven when you consider the expense of the repair involved.
Feb 23, 2011 | Panasonic NN-T994SF Microwave Oven
It does everything except heatinig up food. Model # JVM 3660 SD 001
The magnetron is not working. This open it and check to see if it has a blown fuse. Some microwave would have seperate fuse for the heating power. If fuse is good. You may be able to get a used magnetron from another microwave. Somtimes pawn shops would sell microwave for 5 or ten dollars just because it doesnt have a turnplate inside.
Jul 07, 2010 | General Electric Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Panasonic NN-T994SF 1250 watt countertop microwave stopping
From my research, this sounds like a fairly new model. Consult your user's manual to see if this is a user, or common issue. If nothing is descibed then I would seek possible warranty service, or dealer replacement
Jun 03, 2008 | Panasonic NN-T994SF Microwave Oven
Micrwave does not heat, and turns off by itself before time
Unplug the Microwave and remove the outer cabinet. Inside the cabinet will be a thermal insulated fuse, looks like the old buss fuses for early model cars but white. Replace that with the correct fuse which can be found at Lowes or Home depot and see if that solves the problem. Be careful not to touch any capacitors if they are in there.
Mar 14, 2008 | Panasonic NN-H664 Microwave Oven
Microwave
Mst likely a blown fuse. You''ll need to unplug the unit, remove the outside cover and follow the line cord and you should find the fuse.
Replace it with the EXACT same value that was labeled on the original fuse. You'll probably be able to find a replacement at any Radio Shack store or hardware store.
Replace the cover and plug the unit back in. Hopefully nothing was damaged and the unit will play again.
Please let me know if I can be of further assistance to you.
- Jim
Mar 03, 2008 | Panasonic NN-T994SF Microwave Oven
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
