Question about Sewing Machines
Baby Lock 5380ED serger lubrication
I've oiled and greased every possible orifice and point of contact, including a spot that I had to remove a small fiber plug from to put in the oil. I put the plug back, of course. It did not fix the problem. I can sew for about 5 yards, when the machine is totally cooled, and then it just grinds to a halt and the fly wheel won't budge. It makes a squealing, binding noise as it stops that sounds like plastic rubbing on plastic. But other than the fly wheel itself, everything is metal that I can see moving. It did this same thing last year, and oil and grease fixed the problem. What else can I try?
  • Anonymous Nov 26, 2008
    Okay, I'm sorry, but don't have a solution, however I was wondering how you like your serger. I found one that's the same model but it is new in the box for a great deal. Thanks!
    Kristy
  • 3810kat Jan 26, 2009
    How to oil my baby lock serger??
5 Suggested Answers
SOURCE: Starts good, loses steam
Your machine either needs a new motor or belt. How long has it been since you have taken it in for servicing? Sergers are work horses. They get better as they age, so take it in for servicing.
Posted on May 28, 2008
SOURCE: Baby Lock BL 3000 Sewing MAchine Manual
I am trying to find both the Service and User's Manuals for this machine. Is there anywhere these or either of them can be downloaded? Thanks in advance for your help!
Posted on Oct 30, 2008
  • 19 Answers
SOURCE: Bernette 800D seized up
Please don't use WD40 on your sewing machine, WD40 is an alcohol based cleaner and will do the opposite of lubricate. Take your machine to a certified Bernina Repair shop, they will have a look at the timing and lubricate all of your gears. Lubricant will dry out over time, grease turns to putty and oils turn to varnish after several years of non-service. Lint is attracted to moisture, moisture being those key areas of any machine. Lint acts like an oil wick and will draw out your lubricant from key areas. It then begins to attract dust and other nasty things over the years to become grit. Your motor begins to burn out due to stress trying to move all of these clocked gears, cams and shafts. Take your machine in!
Posted on Dec 10, 2008
  • 1116 Answers
SOURCE: do i need to oil my baby lock sewing machine?? Quiter's choice.
I cannot find a manual for this machine except at sew4less.com and the price is $14.95.
Contact Babylock to see if they will provide you with a download of the manual - http://www.babylock.com/contact-us/index.asp
If this is a mechanical machine, use sewing machine oil and the shuttle may be the only place it will need to be oil.
Posted on Apr 30, 2010
hazelgrace
  • 340 Answers
SOURCE: My Singer overlocker is making a squeaking noise
Try contacting Singer, maybe they can email you a diagram for oiling your overlocker.
http://www.singerco.com/company/contact_us.html
Posted on Sep 04, 2010
What kind of grease do I Need to grease my babylock serger
no grease
only sewing machine oil applied at specific oiling points
Jul 29, 2016 | Sewing Machines
Can't lock my cutting blade on my baby lock evolve serger for cover stitch.
99% of all serger problems can be solved by going to the manual, unthreading, cleaning out all lint and 'stuck' threads, pieces of fabric and such. After the visible stuff is removed a blast of canned air is used to get the tiny pieces.
It is possible that there is an obstruction of some sort that is keeping the blade from 'locking' in to place. Check the spring that holds the blade in place and also (carefully) the blade for small damaged areas. If possible you may be able to unscrew and reinstall either the old blade or a new one (should be in the kit that came with your serger).
If none of these measures work the blade assembly may need adjustment by a technician.
Feb 28, 2015 | Baby Lock Sewing Machines
Brother 1034d serger. Seems unusually noisy (mechanically) in needle/cutter area. Not motor or belt as noise is metal parts clacking even after new needles, cleaning, oiling. Is this sound normal for...
in response to all serger, no, after my babylock serger is cleaned and serviced it runs quietly.
as for the brother, it's possible thats normal, try contacting a repair shop in your area and tell them about the serger and see what they say.
it's possible that the serger may need some type of adjustment
or a part may have broken .
Sep 06, 2013 | Baby Lock Eclipse Serger
Baby lock serger motor slows down after sewing 20 minutes. Why?
Call your local service shop. Baby Locks in closets for years usually have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Been there, done that.
Jul 22, 2012 | Baby Lock Eclipse Serger
Related Tags: slow sewing stops lock not sewing Print Email Flag Problem with Baby Lock Eclipse Serger I have a Baby Lock Serger BL-90. When it has been on for a while and I'm sewing, it starts t
Perhaps was same as my problem.
Call your local service shop. Baby Locks in closets for years often have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Jul 02, 2012 | Baby Lock Eclipse Serger
How to replace a broken needle in baby lock serger pro line modle BL450
I use a small screw driver to undo the screw, insert the needle all the way into the needle holder--flat side to the back of the machine, then tighten the screw back
Feb 21, 2012 | Baby Lock Sewing Machines
My Baby Lock Serger model BLE1AT oiling
Baby Lock.com says you have to take it in to a dealer, as oiling requires removal of covers that would void the warranty.
Dec 30, 2009 | Baby Lock Sewing Machines
Babylock Serger loosing power
Your problem is probably the stitch length adjustment cam (located on the left side of the machine) To fix this problem you will need to remove the small plastic cap (with red arrow) covering the screw securing the cam. It is usually also necessary to remove the connecting rod/sleeve that the cam rides in. Once both of these parts have been removed, you will need to carefully separate them and resurface the inside of the sleeve. This can be done with a very fine (500grit or higher) emery paper. Once the cam fits inside the sleeve without binding, reassemble using sewing machine oil or lithium grease and adjust feed dog timing.
Jul 13, 2009 | Baby Lock Eclipse Serger
Omega Serger 15J134
Jill-Marie, I have a manual and will photocopy for you if you like.
e-mail... ma5brown@yahoo.ca
Sep 14, 2008 | Sewing Machines
Apr 05, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
224 people viewed this question
Top Sewing Machines Experts
Bargain Box
Bargain Box
Irene Tulloch
Are you a Sewing Machine Expert? Answer questions, earn points and help others
