Question about Panasonic KX-T7633 Corded Phone
Line not assigned
HELP!
In trying to reset my phone system, now when I pick up the handset the display says "line not assigned" and all I get through he handset is a busy tone. I can not get an outside line to make a call.
  • Anonymous Oct 09, 2008
    I've 3 not assigned lines!!!! :-(
  • Panasonic Master
  • 2,460 Answers
Somewhere, floating around, is a TDA Users manual. Program 19 and 20 deal with Idle line preference out and in. You could have a couple of things going on, one is that you lost your ILP, or the line assigned to it is no longer there. If it's the former, try this:
PROG 19 0 is no line 1 is Idle CO 2 + a button is that line, and 3 is intercom. Press STORE after the sequence and try it.
Worst case is you do 19 3 and get it to the intercom on idle.
For incoming PROG 20 0 is none, 1 is longest ringing, and 2 plus a line is to prefer that line, used when you have a private or semi-private line that you need to answer. Again, press STORE to save your selection.
HTH
Carl
PROG 19 0 is none 1 is
Posted on Sep 01, 2008
I have a D1680 system with one accessory handset. The hand set on the base is showing Searching although it is on the Base. It rings when a call comes in but when picked up it says out of range. The...
1. Press & hold End and # at the same time until you see the System Reset menu.
2. If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable.
3. To confirm, select Yes. The handset displays "Handset not registered"
Now you want to register the phone again.
1. Place the handset in the base; the display should say Handset
Registering.
2. Wait until the display says Registration Complete (about 30
seconds), then pick up the handset and press Talk/flash.
You should now have a dial tone
Oct 16, 2013 | Uniden D1680 Cordless Phone
I have a PANASONIC KX-DT333 with several handsets. On all handsets we cannot dial out . The message LINE NOT ASSIGNED comes up on all handsets.Also we have had no incoming calls. Callers are all getting a...
I don't know about a handset, since mine doesn't have a dial, but the phone underneath the handset has to have a button programmed with the lines you use in order to work. By default, the system has some number of Single CO buttons assigned in numerical order from the bottom to the top and left to right. You can test that by pressing PROGRAM, press the line buttons in sequence, and reading the display. They will say CO 001, 002, 003 etc. If they don't, you can always dial 0 001 store, 0 002 store etc and get the line appearance back.
This solution works in a small system and is very basic. It doesn't take a T1/E1/PRI or group CO buttons. into consideration. Such a solution is beyond the scope of a free forum.
Carl
Mar 13, 2011 | Panasonic KX-T7633 Corded Phone
I was storing some extension numbers and spead dial numbers and I must have done something wrong as anytime I pick up handset to make a call a 'reorder tone' message comes up on the display- this is before...
So don't pick up the handset :-)
There are some line preference and pickup dial programs that just happen to sit in PROGRAM 1x. My guess is that you have assigned an empty or invalid pickup dial code to the phone.
Try this first. Press PROGRAM and dial 12 ENTER. Is the Hot Line mode ON? If it is, press SEL and ENTER. Wow. That was easy :-)
Didn't work? Let's go for Preferred Line Outgoing next. Dial PROGRAM 19 and 3 ENTER. That makes the intercom prime (0 is none, 1 is idle line 2 (xx) is a specific line).
If you tried both of these, and still no joy, then it's time to reset the phone. The problem with that is you have to dial the code IMMEDIATELY as you're picking up the handset. Good luck with that. The reset code is 79# or 790.
Carl
Jan 25, 2011 | Panasonic KX-T7630 Corded Phone
The line 2 ringer is off (it displayes message "ringer off line 2" on the number 2 remote phone panasonic kx-tg6700 & I cannot figure out how to turn it back on
Please try this first (Reset the phone which requires the ringer to operate again with the main base) Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phone
Jan 20, 2011 | Panasonic Lands Phones
I have a Kx-t7420 panasonic phone system. I have three of my phones that go directly to line 2. no idea why. Can I change this? Also there is so much noise on line 2 that I cannot hear. Is this something...
Actually, you have a Panasonic TD phone system and a 7420 phone, but no matter. The feature you have is probably "idle line preference" or "preferred Line Assignment-Outgoing". In TD systems by default, you select lines from highest to lowest. If you only have 2 lines and PLA is set, you get line 2 then line 1. You can change it to get line 1 first, or chage the trunk access order. The first is something you can do from each phone, the second requires access to system programming. The bad thing about the first solution is if line 1 is busy, you won't get any line. The second will give you the entire trunk group.
Anyway, from each phone without picking up the handset, press PROGRAM 99 and dial 1301 STORE. That will give you line 1 when you pick up the handset. Just so you know or can change it, 11 is none, 12 is idle line, 13xx is specific line and 1+the intercom is intercom. Pick up the handset and drop it back down to exit programming.
As far as the noisy line, it's probably a central office issue. It's hard to test as that line is the outer pair of the jack that plugs into the phone sytsem (RJ-14 pair 2), but you can probably take a regular phone and test it at the demarc point.
Carl
Jul 14, 2010 | Panasonic KX-T7420 Corded Phone
Panasonic kxt7630 button assignment
I've never heard of the ability to reassign an intercom button as it's a fixed feature, but maybe so. Start by assigning the lower left phone button back to CO1 and let's see what happens. WIthout picking up the handset, press PROG the button and dial 0+01 STORE or ENTER.
Pick up the handset and drop it back in the cradle to exit programming.
Did that work? Making button 1 into CO1 will drop the programming from the intercom button and it should default back to intercom.
Carl
Apr 15, 2010 | Panasonic KX-T7630 Corded Phone
Automated Attendant not on everyone line
The below texts should help you.
**Found on page 9-8 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
Use Line Assignment (#301) to assign all the lines that you want the auto attendant to cover
to extension X.
**Found on page 4-47 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
To assign lines to a specific extension:
1. Press [Feature] [0] [0] [System Program] [System Program] [#] [3] [0] [1] at extension 10 or 11.
2. Enter the extension number to be programmed. For example, to program extension 15, press [1] [5]. The red light next to each button that has a line assigned is on steady; the red light next
to each button that has a pool assigned flashes.
3. To remove all existing line assignments, press [Remove] before selecting a line.
4. Enter the line number to be assigned. For example, to select line 1, press [0] [1].
5. Do one of the following:
■ If you want to assign the line to the first available button with lights, press [Next Data] until the
display reads:
Line Assignment 15 L01
1 Assigned
1 Assigned is the factory setting.
■ If you want to remove a line assignment, press [Next Data] until a display like the following
appears:
2 Not Assigned
■ If you want to assign the line to a specific button, press 3. A display like the following
appears:
3 Select a Button
Then press a button with lights to assign the line to that button. If you use option 3 after a
line already has been assigned, the line moves from the old button to the new button you
select.
6. Do one of the following:
■ To program another line for this extension, press [Next Item] or [Prev Item] until the line number
appears on the display. Then repeat Step 5.
■ To program another extension, press N P and begin at Step 2.
7. Select another procedure, or exit programming mode.
Feb 05, 2009 | Avaya Corded Phone avaparp18d
Pick up handset to answer a call and NOT have to press a line
if your phone had set for ringging assignment, u no need to press any key to answer the call.
check the indicator light,
if green light turn on, u can direct answer the call
if red light turn on, u ned to press the line to answer the call
kindly ask the phone provider the set yr extention for incoming ring assignment
Nov 12, 2008 | Toshiba DKT-2020 Corded Phone
Handset has message Out of Range even though it is fully charged on on the handset.
The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:
To reset the phone:
1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
3. Put the handset in the charge cradle.
4. It may take up to 1 minute for the "Out of Range" to clear from the display.
5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
Sep 08, 2008 | Motorola Mobility SD4502 Cordless...
EnGenius DuaFon 1X
Registration:
a. Press MENU-6 to enter the registration mode
b. Press and hold the base’s Registration (REG)
button for 2 seconds until 4 LEDs light up. (Located on the base where you plug in the phone jack)
c. Press handset key “1”, this completes the
registration process. When you register the
handset to BASE 10, the base will assign a
handset ID between 11 and 19. The assigned ID
will be displayed on the handset LCD, indicating
successful registration.
d. Repeat above steps for all additional handsets.
e. The first two handsets registered will be given ID
11 and 12, which gives them administrator
privileges.
Jan 04, 2008 | EnGenius DURAFON1X DuraFon 1X System Phone
Panasonic KX-T7633 Corded Phone Logo
1,140 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
