Question about Amana Refrigerators
No cooling in refrig, botton freezer forming too much ice
BC20TW is model number. For two weeks excessive ice has been forming in freezer compartment (at bottom on this model). This morning. Labor DAy, the chilling function of refrigerator (at top on this model) stopped. We have taken all the items out of the freezer compartment and are looking for a way to get the refrigerator working again.
I had the exact same problem last month. After reading another article here, we opened up the freezer's back panel, melted/removed the ice and then replaced the DEFROST THERMOSTAT that we got at a local applicance parts house. It works great (actually better) now.
Posted on Sep 13, 2008
  • 725 Answers
Let me know I can help you get it going again..
Posted on Sep 01, 2008
Refrig compartment does not cool on my new Kemore Frig.
Check and make sure the fan in the freezer is running. if not possible bad fan. If fan is running, check to see if you have any ice built up on back freezer wall. Normally frost type ice. If so, you may possibly have a bad defrost bi-metal mounted in the freezer section. Next could be a defrost timer control. Model number usally will help more in getting it right.
Feb 28, 2010 | Kenmore Refrigerators
My freezer works but my refrigerator does not. What the problem?
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Dometic Refrigerators
Unit gets cold when turned on then slowly gets warmer and then does not cool at all
Most probably defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Frigidaire Refrigerators
Freezer compartment has frost buildup
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
Refrigerator isn't very cold- drinks are just slightly chilled
Usually caused by failure of defrost system, Air ports from freezer to fridge blocked by ice
Aug 23, 2009 | Whirlpool Refrigerators
Gets to 35-40 degrees then doesn`t maintain till is shut down and started over again.
Aug 21, 2009 | Refrigerators
I had a huge block of ice on the bottom of my freezer that I got rid of yesterday. Over night the ice started to form again. What could be wrong? The unit is only about 8 years old and we've already had...
Aug 19, 2009 | Refrigerators
Refrig not cooling
Either the fan that blows cold air from the freezer compartment to the fresh food compartment is burned out or the door/flap that seperates the compartments is stuck or the linkage connecting it to the fresh food temperature dial is stuck or broken.
The evaporator coils are in the freezer compartment and air is blown from the freezer compartment to cool the fresh food compartment. For some reason, air is not moving to fresh food compartment.
If the fan is running, it could be something as simple as Ice blocking to door between the freezer and fresh food compartment. I know modern refrigerators are self-defrosting, but that's only the evaporator coils, which are defrosted by a timer and a heater.
Ice can form on passageways inside the refrigerator, like the exit of the ice maker and in this case, on the door and 'tunnel' between the freezer and fresh food compartment. It's free, and doesn't take a lot of time, so try completely defrosting the unit before doing anything else.
BE SURE to keep the doors open, as odors can form as particles of food are allowed to defrost that may have been frozen in an ice pack for months or even years. Clean the interior of the refrigerator while you have everything out and reset the controls to normal settings.
If this doesn't help, there may be a mechanical problem with the air transfer control flap/door that will need to be fixed.
Hope this helps.
Jun 10, 2009 | Refrigerators
Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Jan 19, 2009 | GE GSH22JFR Side by Side Refrigerator
Freezer is freezing
common problem is part number 67003375 adaptive defrost control. also reccomend replacing part number 67003964 at same time. control located in refrige behind left upper panel. def therm clipds on evaporator behind panel in freezer.
Feb 06, 2008 | Amana ASD 2624 Side by Side Refrigerator
Refrigerators Logo
179 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
