Question about MTX SW2 Subwoofer
Blown fuse?? no sound from sub. noticed fuse was blown. when i replace fuse and plug into the wall it blows right awway. what gives? this sub is less than a year old.
  • gidel75 Feb 22, 2009
    The red light is on but there is no sound, and the fuse seems to
    be ok. On the "auto or on" position makes no difference. It just will
    not work. I tried a different sub and that one works.?? Any suggestions
    Brigadier General:
  • 5,158 Answers
There is an underlying cause for the fuse to blow. if something shorts out you would rather a 40 cent peice goes then the unit causing a fire. disassembly is require... look for obvious burnt parts first.
Robert
Posted on Sep 01, 2008
Call MTX speaker department at 1-800-556-2888 and order the amplifier. It cost 123.00 plus shipping. i love this subwoofer and the same thing happened to me.
Posted on Feb 10, 2009
Thanks for the reply. im pretty sure there is something really bad here. i know its not the smart thing to do, but i was desperate so i took one of the bad fuses and wrapped it in aliuminum foil! it made a loud humming noise. i think the amp has gone bad time to replace. subwoofer in questions is a MTX sw2 12" cant find any on the net that has replacement amp. if any ideas please reply thanks.
Posted on Sep 02, 2008
  • 34 Answers
I suggest replaceing the fuse once again with one with higher resistance(a smaller one could be sensitive to high current power) or, probably a very good thing would be to try a different wall plug!
Keeps blowing fuses when unplugged from the wall
you need to replace the outlet your plugging it into or go to a different ciruit in the house n try again.
Jul 19, 2013 | Televison & Video
I have a gale 3070 sub woofer. When I connect it to the power with no audio connection being made, the inner fuses blow. can anybody help
if a fuse keeps on blowing there is a problem with the amp, Take it in to be repaired, Or just get a different one, It will probally cost you less just to get a different one,
Nov 29, 2012 | Gale Audio Players & Recorders
I have a Sony Xplod 800w Amp running a 10' Sony Xplod Amp....i unhooked the amp to do some moving and i tried to put it back in today and it didnt have any sound coming from it! I did notice the power...
it sounds like it could be a blown channel in the amp. if the sub was blown it would still work just sound horrible. i have blown many subs and amps. you can bring it to an audio shop near you and they can fix it. i just got one of my channels fixed for 35$
May 11, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
A few days ago the subwoofer stopped working. Yesterday I turned the system on and it wouldn't work at all. I discovered the fuse had blown. I replaced the fuse, couldn't find a slow blow fuse so had to...
Try removing the wires to the subwoofer and then hook a "aa" battery to it and see if it makes a pop sound..this will tell you if speker is ok...if it is then I think the amplifier sectionj for the sub is what is blowing the fuses...you are probably right..it looks like it's a 1 A fuse...but if it's blowing right away..it may be circuitry related
Jan 04, 2011 | Altec Lansing VS3251 Speaker
Sub-Woofer blowing fuses.
You should open it up and look for a short. Usually, an exposed wire is touching metal. Wrap the wire with electrical tape and look for a ground wires that are loose. That will blow fuses too.
Feb 15, 2010 | Harman Kardon HKTS 7 System
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
Phoenix Gold Xenon 1200 mono not pushing subs and making noise.
This sounds like a problem with the head unit output to the sub amp. Are you using a Pioneer head unit? If so, you may have a problem with some surface mounted fuses inside the radio on the main board. Certain Pioneer head units have a common problem with these fuses blowing. They are fuses for the ground on the RCA outputs.
Let me know if this is the case, and if it is I can give you the part number of these fuses and tell you where they are located, but you would need good soldering skills to replace them. Also let me know what model number your head unit is.
Thanks,
Dave
Sep 08, 2008 | Car Audio & Video
Subwoofer issues
The fuse blows when the current that passes through it are beyond its rating. This could be brought about by excessive consumption of the load, in this case the amplifier powering the sub-woofer.
Repairs would involve component level and require that you be familiar with electronic components and circuitry, use of a DVM and a soldering iron. Often it is just the finals that needs to be replaced. Of course we cannot discount the possibility of other components or section such as the power supply.
The smoke indicates something heating up such as a resistor or diode or a capacitor.
Should you be uncomfortable opening the unit and doing a DIY (do-it-yourself), then perhaps you need to seek the services of a qualified professional.
Should the downtime and cost of repair be no longer economically reasonable, purchase of a new unit might save you further trouble.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 23, 2008 | Onkyo SKW-200 Subwoofer
MTX SW2 Subwoofer Logo
669 people viewed this question
Top MTX Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MTX Audio Player and Recorder Expert? Answer questions, earn points and help others
