Click start control panel
administrive tools ,computer management ,device manager look through all
of your devices if you see a yellow question mark?or exclamation mark
! or red x
right click to reinstall
drivers or
if you can see your usb but
its not working
ports(com&lpt)right
click update driver
sometimes the wires inside
the cable will be damaged due to bending or stretching or placing heavy
equipment upon the cable,
just replace the cable of
the hard disk, when you plugged the external disk drive you got that
windows could recognize the USB device change the cable everything should work
fine again,
check the USB leads that
attach to the motherboard usually red-white-green-black make sure they are
securely seated and have no dust build up on them dust will cause static and a
lot of unforeseen problems
hope this helps
