Question about Epson PhotoPC 750Z Digital Camera
Can batches of images be verified at the same time?
    Master:
  • 542 Answers
Yes. While opening files within the Epson Image Verification module, merely highlight the group of images to be verified, then verify as usual. All of the highlighted images will be verified at once.
Posted on Sep 13, 2005
SOURCE:
Adjust bunn coffee maker water level
To adjust the brew volume/batch size you will need to access the main circuit board behind the front panel. Isolate the machine before removing panels.
NOTE: Check that the brewer is connected to water supply, the tank is properly filled and a funnel and server or decanters are in place prior to setting or modifying batch sizes.
  1. Modifying batch sizes: To modify a batch volume, first check that the SET/LOCK switch is in the "SET" position on the circuit board. If the brewer has a batch selector switch, position it to the size to be changed. To increase a batch size: Press and hold the START or BREW switch until three clicks are heard. Release the switch (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory) and press it again one or more times. Each time the switch is pressed, 2 secs are added to the brew time period. Allow the brew cycle to finish in order to verify that the desired volume has been achieved. To decrease a batch size: Press and release the START or BREW switch once for every 2 sec interval to be removed from the total brew time period; then immediately press and hold down the START or BREW switch until three clicks are heard. Release the switch. (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory). Allow the brew cycle to finish in order to verify that the desired volume has been achieved.
  2. Setting batch sizes: To set a batch volume, first check that the SET/LOCK switch is in the "SET" position on the circuit board. Press and hold the START or BREW switch until three clicks are heard (this will take approx. 10 secs) and then release the switch. (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory). View the level of the liquid being dispensed. When the desired level is reached, turn the ON/OFF switch to "OFF". The brewer remembers this volume and will continue to brew batches of this size until the volume setting procedure is repeated. Empty server(s), turn selector switch to positions that have yet to be set and repeat batch setting procedure until all batch sizes are set.
    NOTE: When brewing coffee, batch volumes will decrease due to absorption by the coffee grounds.
  3. Setting programming disable feature: If it becomes necessary to prevent anyone from changing brew times once
    programmed, you can set the SET/LOCK switch to the "LOCK" position. This will prevent any programming to be done.
    NOTE: If the clicks cannot be heard, lightly grip the incoming water line to feel when the valve cycles on and off.
Jun 22, 2014 | Bunn CWTF15-TC
Pictures contain a duplicate mirror image
I would use IrfanView. You can horizontally flip any image and you can perform the same action to a number of images using the batch option.
Jan 27, 2018 | Microsoft Digital Image Pro 10
HOW DO I BATCH OUT
GETI CHECK SALE [F2]
PAYROLL/BUSINESS [F3]
MORE VERIFY ONLY [F4] Press the Purple key below the More option. GETI CHECK SCANNER MENU [F1]
BATCH MENU [F2]
REPRINT [F3]
MORE VOID [F4] Select Batch Menu [F2]. ERASE BATCH [F1]
CLOSE BATCH [F2]
HISTORY REPORT [F3]
BATCH REPORT [F4] Select Close Batch [F2]. KEY IN MANAGER PASSWORD
AND PRESS ENTER Press [1] and [Enter]. ARE YOU SURE? CLOSE BATCH [F3]
CANCEL [F4] Select Close Batch [F3]. DIALING . . . The terminal will dial in to close the batch. Once closed, the terminal will print the batch report indicating Batch Accepted.
See example below. BATCH ACCEPTED
EXIT [F4] Select Exit [F4] to return to the menu.
Oct 19, 2011 | VeriFone VX510
PhotoShop CS3 Droplet automation
Try the following steps
  1. Choose File => Automate => Create Droplet.
  2. Specify where to save the droplet. Click Choose in the Save Droplet In section of the dialog box and navigate to the location.
  3. Select the Action Set, and then designate which action you intend to use within the Set and Action menus. (Select the action in the Actions palette before you open the dialog box to preselect these menus.
  4. Set Play options for the droplet:
    a. Override Action “Open” Commands Open commands in the action refer to the batched files, rather than to the file names specified in the action. Deselect Override Action “Open” Commands if the action was recorded to operate on open files or if the action contains Open commands for specific files that are required by the action.
    b. Include All Subfolders Processes files in subdirectories.
    c. Suppress Color Profile Warnings Turns off display of color profile messages.
    d. Suppress File Open Options Dialogs Hides File Open Options dialog boxes. This is useful when batching actions on camera raw image files. The default or previously specified settings will be used.
  5. Choose a destination for the processed files from the Destination menu:
    a. None Leaves the files open without saving changes (unless the action includes a Save command).
    b. Save And Close Saves the files in their current location, overwriting the original files.
    c. Folder Saves the processed files to another location. Click Choose to specify the destination folder.
    Note: You can record an action that saves using a specified file name and folder. If you do this and deselect Override Action “Save As” Commands, the same file is overwritten each time. If you record your Save As step in the action without specifying a file name, the droplet saves it to the same folder each time but uses the file name of the document being saved.
  6. If the action includes a Save As command, choose Override Action “Save As” Commands to make sure files are saved to the folder you specified (or to their original folder if you chose Save And Close.) To use this option, the action must contain a Save As command, whether or not it specifies a save location or file name; otherwise, no files are saved.
    Some save options are not available in the Batch command (such as JPEG compression or TIFF options). To use these options, record them in the action, then use the Override Action “Save As” Commands option to make sure that your files are saved where you specify in the Batch command.
  7. If you chose Folder as the destination, specify a file-naming convention and select file compatibility options for the processed files:
    a. For File Naming, select elements from the pop‑up menus or enter text into the fields to be combined into the default names for all files. Elements include document name, serial number or letter, file creation date, and file extension. Starting Serial Number specifies the starting number for any serial number fields. Serial letter fields always start with the letter “A” for the first file.
    b. For Compatibility, choose Windows, Mac OS, and UNIX to make file names compatible with Windows, Mac OS, and UNIX operating systems.
  8. Select an option for error processing from the Errors pop‑up menu:
    a. Stop For Errors Suspends the process until you confirm the error message.
    b. Log Errors To File Records each error in a file without stopping the process. If errors are logged to a file, a message appears after processing. To review the error file, open it in a text editor after the Batch command runs.
Give it a try.........
Jul 30, 2009 | Computers & Internet
Camera RAW and PhotoShop CS3
To start, before building an action or a droplet to convert from Raw, you need at least either the RAW plugin, or the photoshop lightroom plugin, depending on the version of Photoshop. I assume you have the plugin installed on your Photoshop. See: Adobe - Adobe Photoshop CS4: Digital camera raw file support.
A better choice would be having the Nikon Capture NX , that give you the option to work on the native RAW format from Nikon.
Once you have installed a plugin to manage RAW format files you can record an action or droplet to automate the process. If youj want more automation, you set an action first, as a batch process to do action on a single file, then build a droplet on the action batch file. A droplet will give more automation, since droplets can be activated by dropping a folder of images onto that specific Droplet Process, and they will apply the batch process to all the files contained in the folder.
The way you build the batch action depends much on the version of Photoshop you are using and on the plugin used. Here an example using Adobe PS CS2 and camera Raw plugin: Raw Format Workflow with Adobe Bridge .
The action can be saved using the recorder, so that the procedure will de quite instinctive. See the tutorials below for step-by-step instructions.
See also:
Adobe - tutorial : Lights, camera, action!
Batch Processing Camera RAW images in Photoshop CS
Creating a Droplet : Adobe Photoshop Tutorial
Jul 28, 2009 | Computers & Internet
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Sep 13, 2005 | Epson PhotoPC 700 Digital Camera
Two copies of the same image printed
Batch printing all images in camera memory while the camera's album generator feature is enabled, will cause such duplicate printing. This is because the album generator creates two images in camera memory: the normal image and a preview image. Batch printing all images will result in the camera printing both the normal image and the preview image. What you should do - Use the camera's DPOF settings to specify the images you want to print. Using DPOF is very simple, and it eliminates the problem of double prints. * See the User's Guide for details about DPOF image settings, specifying the number of copies, date stamping, etc. - The album generation feature also has a delete function for deleting generated album data, so you could also delete the album before batch printing.
Aug 30, 2005 | Casio QV-R62 Digital Camera
Epson PhotoPC 750Z Digital Camera Logo
193 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Terry Herrera
Harrie
Are you an Epson Camera Expert? Answer questions, earn points and help others
