Question about Canon PIXMA MP600 all-In-One InkJet Printer
Canon MP600 My Canon MP600 will not print PGBK ink all others work fine. I ran the clean printer head function while still having ink left in the cartriges. Once that was completed it registered that I was out of ink on a couple so I bought all new ones. After installing them today it still will not print the PGBK. I ran another clean printer head, but that did not work either. What could be the issue?
  • Anonymous Sep 06, 2008
    I have the same problem with cyan regarding my canon mp600. My cyan won't print. follow advice given at http://www.ehow.com/how_2078853_clean-cl...
    after a few drops of isopropyl alcohol and some cleaning/deep cleansing my cyan prints again on a color test bar pattern. within one sheet or so the cyan quits printing again. I'm wasting so much ink. If it prints perfectly once why would it immediately quit. After I run another cleanse it prints the test bar. then it quits again. sheesh.
  • Anonymous Mar 31, 2014
    when doing pattern check the PGBK is only printing half. Therefore only printing every other line. Cleaned, alcohol, tired of it.
Manleeroas, not that it will help but try a few drops of isopropyl alcohol. directions given at this link:
http://www.ehow.com/how_2078853_clean-clogged-inkjet-print-heads.html
Posted on Sep 06, 2008
Canon MP640 won't use pgbk cartridge
its maybe air leak to cartrige.check the hole on cartridge must closed.then clean head by printer propertis .cleanhead for 4 or 5 times
Oct 04, 2017 | Canon MP640 All-In-One InkJet Printer
My PGBK ink cartridge is not printing. I just replaced it. Everything else is working fine. I have done several cleaning jobs on it and the test prints that I print don't even show PGBK or the black...
the PGBK ink cartridge might not be getting a good connection you might have to remove it and check the connections or clean the connection bars
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Oct 21, 2011 | Canon Pixma iP4500 InkJet Printer
Hi We have a Cannon MP600 printer. Just replaced the large black cartridge (PGBK 5) as it had run out. The printer is now smearing gaps in the text (in black). Tried 2 cartridges & both produced the...
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged and showing the line gap in printing. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps ... Cheers :)
Jan 08, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Printer won't print
Yes, these machines are designed to only function if all inks are present and meet minimum requirements. Not doing so could result in damage to the print head. The large black ink, the 5, is also a pigment based ink and highly prone to clogging. Letting this machine sit for extended periods of time unused can also cause damage, possibly irreparable, to the print head. We typically recommend people using these style machines always keep a back up set of cartridges on hand to avoid issues.
Mar 23, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I have problem with print-head for PGBK-5. On the test-print it does not appear as the pattern suppose to be (from the top) PGBK, C, C, M, M, Y, and BK. The pattern always appear C,C,M,M,Y and BK. I used...
if the clogging is worst then the deep head cleaning wont help.the head will need to be cleaned up manually and the waste ink pad in the printer should be cleaned too. this is covered normally in printer servicing.give special instructions to clean the head properly while you hand over the printer for servicing to any local tech. head cleaning and servicing will solve the issue
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon ip4300; new printhead and PGBK ink cart but it won't print
call ok canon 800 number..their better than India CAll centres.
Dec 03, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
My canonmp830 printer is not printing in black ink
**Repeat from previous post. Would not print black. I went through all the troubleshooting of cleaning the printhead several times. The Nozzle check (found under Printing Preferences/Maintenance tab) kept coming out without the PGBK section (Black) printed on it. All the colors printed. If your see any of the colors missing, it is probably the same problem---it needs the Print Head replaced.
Part # QY6-0061-010. I was able to find it at Canyon Computer Supplies in Phoenix, but you can also order them via the internet from multiple outlets. Mine cost $59.57 with tax...much cheaper than a new printer. The replacement is very easy...Canon has info on how to do it at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804#SupportDetailAct ...if the link doesn't get you right there, search MP830, Support & Service, then search print head & you should find it. Once you remove all the print cartriges (printer ON), the gray lever on the left side lifts up and releases the print head...which is the unit that houses all the print cartridges. I just put the new print head in, replaced all the ink cartridges, did a nozzle check...and it worked!! I love fixing things myself.
Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
CANON MP600 - NOT PRINTING IN BLACK INK
I have had the mp600 for 3 years - worked fine on a couple of different pcs. I switched to a mac and encountered 2 issues - scanner stopped working and above problem of no black ink. The newest driver (just google mp600 driver) fixed the scanner issue. The ink issue has a work around - select non plain paper in the media quality tab, instead use any photo paper setting. Finding this area in a mac can be tricky - in the mini print options window you have to click the small chubby arrow and you will then be given a list of options including quality and media. Presto, black ink returns but probably uses more ink and takes longer to print. I have not found a more elegant solution as you have to select this non default paper option every time.
Apr 18, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP500 PGPK cartridge wont print
i have the same problem too. This is obviously a product defect. If Canon not fix it, i wont buy Canon printer anymore.
May 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
1,242 people viewed this question
old marine
old marine
