Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
How to turn timer on to cook my turkey while I am out
Hi
I inherited a Whirlpool Gold Gas Range Accuvue and don't know how to set the timer so that the oven comes on while I'm not in .
  • 943 Answers
Hi thanks for the question on your timer you have a start time & cooking time or stop time so if you want the oven to come on say at 3 pm then set to 3 pm stop time or cooking time say 5 pm you will then turn on oven at say 350 degrees the oven will then only start at 3 pm and turn off at 5 pm try this once when your at home to see if this works for you thanks the appliance doc
Posted on Sep 22, 2008
Roasting times for a turkey
hi cathy.
For a standard turkey that's around 6kg/13lb, the cooking time will be around 4 hours. It's best to calculate your cooking time at 40 minutes per kg or 20 minutes per lb to get the most accurate time.
Roast timer ' BBC Good Food
https://www.bbcgoodfood.com/howto/tools/roast-timer
Roasting times for turkey Google Search
Nov 18, 2017 | Kitchen Appliances - Others
Is there information on a Whirlpool Gold Gas Double Oven?
Repairs on gas cooking appliance's can only be carried out by someone deemed competent please use a registered gas fitter for this repair.
Sep 06, 2014 | Whirlpool Gold Double Oven Freestanding...
The clock on the stove was flashing and now I can't get time set and the oven buttons don't work to put on broiler or oven. I don't know how this happened or how to correct it
hello,
You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thanks for using fixya
Aug 18, 2010 | Tappan TGF657 Gas Kitchen Range
Breaker flipped on my oven while cooking a turkey
If the oven was still slightly warm to the touch when you came home is probably fine. 45 minutes was not enough time to get the turkey hot down near the bone, so if it was cool I would discard it. But if you were lucky and it was still warm, go ahead.
Sirwriter - (Smoke and barbecue tons of chickens and capons)
May 16, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Dec 02, 2008 | Ovens
Maytag range # MGR5775QDS
gas range, most common issue for extended cook time, long preheats, bad oven ignitor (it works but its slow to refire ) 75 dollar part servicer will get 175-265 depending wher you live
Oct 25, 2008 | Maytag Kitchen Ranges
Setting of clock
You need to examine the timer settings. Perhaps you could turn off the power to the oven for a few minutes - this might reset the timer.
Jun 30, 2008 | Cannon 10476G Dual Fuel (Electric and Gas)...
Help! Trying to speedbake my turkey!! Lost instructions!
you are better off cooking normally unless you want a dried out turkey. besides cook times vary with every range get to know your stove
Nov 22, 2007 | Frigidaire FEF366 Electric Kitchen Range
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
109 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
