Question about Microwave Ovens
Won't heat Tried hard reset-no good. You are correct. The microwave is mmv5186aa. Any other thoughts or solutions?
  • landallgis Sep 04, 2008
    my micro wave all of a sudden not working only light is on
  • Bob Schulken
    Bob Schulken Oct 07, 2008
    Very happy with the results. The new board did the trick. A bit more expensive than I expected though. The technician, William Miller, was very helpful. He always followed up on my emails and didn't rush me off the phone when I had questions.
    NYBob
  • Microwave Ovens Master
  • 9,098 Answers
Then it may be a bad board, and we repair these for customers nationwide for $39.95 in most cases.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 02, 2008
When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
Sep 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The readout is reading like hyroglifics?????/
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If this scrambling is occurring a few seconds after you begin
a microwave heating cycle, see this FixYa solution even if your model number is different.
Jun 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Intermittent reminder beeper won't shut off
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
May 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Maytag over the Range Microvave MMV5186AAS does not heat.
You have a bad secondary interlock (top door switch) or its mount is bad.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 30, 2008 | Maytag MMV5207A Microwave Oven
Ge profile microwave doesn't seem to be heating food real hot. during the last bag of popcorn we tried to pop it never even started popping it, and the microwave stopped and said on the screen...
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Otherwise, your sensor may have failed.
Nov 22, 2008 | Microwave Ovens
Oven doesn't heat
Did you or the the repair man do a hard reset?
Thefirst thing I would suggest is a hard reset. Unplug the unit for aminute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Plus, I'm assuming your model is actually MMV5186AA, right?
If it turns out to be a bad board, we actually repair those for customers nationwide for $39.95 in most cases.
William E. Miller
prototech@usa.net
Sep 01, 2008 | Microwave Ovens
HEAT Message and continuously beeps
Aug 21, 2008 | GE JVM1430 Microwave Oven
Slow Heating
Water is always called for in standard microwave heating tests.
By design, water molecules are what are targeted by the microwave cooking process.
If your line voltage is correct and it is slow to heat, then almost certainly your magnetron is failing.
If it's within the magnetron portion of the warranty but out of the original full warranty, then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 23, 2008 | Maytag MMV5186A Microwave Oven
LG microwave no longer heats!
It sounds as though you may have run the microwave while empty, which can damage the magnetron.
Not that I'm optimistic, but the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise it likely needs a new magnetron.
Apr 06, 2008 | Microwave Ovens
Maytag Microwave model#MMV5186AA
Typically, no heating of food, indicates a bad Magnetron (tube) or associated components. The oven can be repaired. Magnetrons are not hard to replace and can be ordered online through MCM electronics www.mcmelectronics .
However, due to the dangers of high-voltage within the unit, I would recommend taking the unit to a repair center.
Look in the manual to see what the warranty says. See if there is any information regarding the magnetron or parts. You may be able to get it repaired for free parts, less labor.
Please let me know if I can be of further assistance to you.
Good Luck,
- Jim
Mar 20, 2008 | Maytag MMV5186A Microwave Oven
Microwave Ovens Logo
71 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
