If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
heatman101
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
heatman101
http://www.appliancepartspros.com/partse...
hey there, i sent you a message earlier, this is Mike. Copy this link above and paste it into your browser. take a minute to look at the diagram and tell me if this is your dryer. I had a lot of problems finding anything with the model number. Tell me if this is it if you can. thanks
