SOURCE: nec
Do you have the user manual? You can download it from NEC if you desire. You might check to see if you can get the menu (proceed button on the remote). If you can't get the menu you might be looking at a PNP - means the monitor is bad and you might be looking for a new TV. If you can get the menu you might try resetting the options to the factory default. As well, check you connections for the various inputs - HD/DVD, VIDEO1, etc.
Get to know that menu - it will solve all kinds of NEC issues.
SOURCE: nec px-42vp4a that turns off
Hello. I have the same issue with my px-42vp4a. Did you figure out the problem. Email me with you did. [email protected]. Thank you. Paul
SOURCE: NEC plasma PX-50XM5A with ghosted images
tienes un problema en el plasma de imgenes fentasmas lo que te sugiero que le hagas un buen mantenimiento
SOURCE: No signal with NEC plasma PX-50XM4A
You were right when you called it a monitor, it is a monitor, which means no tuner. To be able to use it as a TV you will need cable box or satellite receiver or something that has a tuner in it.
SOURCE: NEC 42VM2A plasma tv switch to internal speakers
I don't know if you have the owner manual for this T.V. or not but if you need one you can download a manual at www.devicemanuals.com/guide/Television/ Hope this helps!
