Question about Saeco Spidem Villa
Seaco spidem villa machine
I was about to start cleaning my machine and I forgot to shut the power off. Now my machine will not power on. How do I fix this?
  • 515 Answers
Take off the top and check the fuse, if you have the old version off your machine you will find the fuse on a wire, if you have a new version then you have to reset the thermostat on the boiler (two pcs).
Hope this will help you.
/Mirran
Posted on Sep 02, 2008
I have a Saeco Spidem Villa. Iâ??ve been
I dont understand what exactly happen when you try to make coffee? Is the coffee comes out or no?
Apr 20, 2017 | Saeco Spidem Villa
The water output on my Spidem Villa was decreasing so I descaled it (I've done this before). No it will not dispense any coffee or water/steam at all. Apparently some of the scale deposits are lodged...
Hi
The first place I would check is the steam wand. Remove the pannarrello (loosen the cap all the way and pull down on the bottom. Leave the cap and seals on the wand). Clean the tip of the wand and check to see if that cleared the blockage.
May 19, 2010 | Saeco Spidem Villa
My Saeco Spidem Villa leaks after it despenses the coffee. Have attempted to clean descale to no avail. Any suggestions?
Take out the grounds box and the brew group. At the back there is an opening. If grounds get in the opening, it can't drain. Get some hot water in a squirt bottle and flush out that opening at the back ... this may end your problem with leaking after dispensing
Apr 05, 2010 | Saeco Spidem Villa
Repair spidem villa
A little spring felt off from the inside part when I was cleaning
Sep 23, 2009 | Saeco Spidem Villa
Broken"ON" button on Spidem Villa by Saeco
see repair shop. It is a ***** to replace,
Sep 19, 2009 | Saeco Spidem Villa
My Saeco Spidem Villa has just stopped working. i have had it 6 months and it has been fine until about 2 weeks ago when it wouldn't always switch on when i pressed the power button. now it has packed up...
Have you checked the power button to make sure it is not defective, if yes then check the capacitor under the pump to make sure it is not damaged.
Jun 28, 2009 | Saeco Spidem Villa
How do you take apart the grinder on Saeco Spidem Villa Household Coffee Machine
There should be screws on the side or the bottom of the unit that will allow you to pull it apart. The problem seems to be that the two grinding wheels have gone bad and needs to be replaced. On this unit you cannot adjust the grinding as far as would need to be to fix the problem when the teeth get to small
Jun 03, 2009 | Saeco Spidem Villa
How do you take apart the grinderon Saeco Spidem Villa Household Coffee Machine
Remove all the beans in the hopper, there are 2-3 screws in the hopper. Remove and then lift hopper, this will give access to the grinder chamber and burrs.
May 29, 2009 | Saeco Spidem Villa
Saeco Spidem Villa not dispencing water or steam. Need Help!
mine just wont heat up... no hot water.. have only had it for a week... what can i do?
Feb 18, 2009 | Saeco Spidem Villa
Power button loose - comes out (cracked)
Contact your reseller or your nearest Saeco Service Center as your machine will have a 2 year warranty.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 19, 2008 | Saeco Spidem Villa
Saeco Spidem Villa Logo
267 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
