Question about FIC IC-VG61 (dhicecube) Barebone
Case fan won't come on. pulled it and tested okay.What gives?
My case fan won't come on. I pulled it, put 12 volts to it and fan came on. Is there a thermostat or controler somewhere in the mother board?????
    Scholar:
  • 96 Answers
Yes ...the case fan will no doubt be thermally controlled if it's connected to the motherboard .... and obviously something has gone wrong with the sensor. Have a look round and see if there are any other 2/3 fan connectors on the motherboard you could use. Most times there's the "cpu fn" (we don't want to disturb that one!), "sys fn" and one or more "case fn" connectors, but being a bespoke motherboard in that SFF case you may be out of luck. You've already hooked it to 12v to get it working so it wouldn't be difficult for you to wire it permanently to a spare power connector (you will probably have to cut the cables and rejoin them). However bear in mind that the fan will then run continuously.
Posted on Dec 31, 2008
Asus laptop randomly shuts down
Possibly overheating. I would check the fan and airways are free from fluff.
Oct 06, 2015 | ASUS Computers & Internet
If I pull out battery off polaris magnum will it hurt running of atv?
Without a battery you are putting too much load on the electrical system. The lights are made to run on a 12 Volt system, without the battery you are getting probably 16 or more volts which burnt out the bulbs. The fan also requires 12 volts to run, which it gets from the battery. And finally it won't rev up because of too high voltage. Install a new charged battery and your problems should correct themselves if they haven't been badly damaged already. Then new bulbs can also be installed. Good luck, Daniel.
Nov 04, 2012 | Polaris ATV
Blue screen came on then the computer went off and will not boot up. will re installing windows xp work or what do i do?
Due to your diagnosis, it sounds to me like Power Supply failure.
Weak Voltage power rail.
Not enough power to keep the Processor on.
(In this case, No, re-installing Windows in a Repair, will not fix the problem)
Lights will light, and fans may spin, but there isn't enough power for the Processor.
1) ALL the lights use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power. Depends on what Processor it is.
(For example, if this Optiplex GX260 was ordered with a Pentium 4, 2.26GHz Processor, {Socket 478}, it can use up to 58 Watts,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
If this computer, and Power Supply are dirty inside, it's a pretty sure bet the Power Supply is bad.
Test the Voltages of the Power Supply to see if they are correct. Specifically the 12 Volt power rail.
If it is 11 to 13 Volts, it's okay.
Less than 11 Volts requires replacing the Power Supply.
Test can be done with an inexpensive multimeter, or a power supply tester.
One example of a power supply tester,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471
Jun 10, 2010 | Dell OptiPlex GX260 PC Desktop
Packard bell imedia 1402 will not boot up power button is flashing amber twice every second also amber led right hand corner on motherboard
Sorry, I stepped out. Otherwise I would have answered right away.
Your power supply changes your household, (Residential),or business electricity, into three main voltages. Also converts it from AC to DC electricity.
1) 3.3 Volts
2) 5 Volts
3) 12 Volts
Each one of these voltages is a voltage power rail.
There's more involved than that, but for ease of explanation, we'll let this suffice.
A) Orange wires are 3.3 Volts. ( 3 and 3/10ths Volts. Sometimes the decimal point is hard to see on here )
B) Red = 5 volts
C) Yellow = 12 Volts
The only power cable you're going to be switching around, in my thoughts, is a 4-pin peripheral power cable.
Has a 4-pin Molex connector on the end.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note that there is one Yellow wire, one Red wire, and two Black wires.
If you have a bad 5 volt power rail, or a bad 12 volt power rail, all the peripheral power cables will be effected.
Won't do you any good changing them out.
They all derive their power from the same source.
I understand your reasoning, and it looks logical, huh? But as you can now see, it doesn't affect anything changing peripheral cables around.
The blinking Power On light indicates you have a bad power supply.
I can't find any documentation on Packard Bell's website to give you, to substantiate my statement to you.
Otherwise I would.
To test my claim.
Do you have another power supply of the same style, and has the right amount of power cables? Also should be at least 200 watt.
You're just going to use it for a test, not as a replacement power supply.
No?
You could conduct a voltage test of the power supply, but if the fan doesn't even spin, the power supply is kaput.
Does the power supply's fan spin?
If so we can go on to do a voltage test.
This will require a multimeter.
The multimeter is set to the 0-50 Volts DC scale.
An economical, but decent enough multimeter, can be purchased in a multitude of places.
An auto parts store is one place.
Radio Shack is another.
There are several stores that carry affordable ones.
Average price for a decent enough multimeter for this test is around $10 to $15.
If you do not wish to use a multimeter, there is also the option of using a simple to use power supply tester.
This is one example, and an example of where to purchase it,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1647108&CatId=1107
Again, this is if the fan on the power supply spins. There is the rare occasion that the fan on the power supply will fail, and the power supply will work, but this is not one of those rare occasions.
Also, if the power supply fan spins a few times, then stops, the power supply is shot.
What leads to power supply failure?
A) The power supply was a low quality item installed by the computer manufacturer.
Saved the manufacturer money.
50 cents to a dollar saved, times 50,000 computers, or more of that model, adds up in a hurry.
B) The computer is dirty inside. Computers need to be kept clean on the inside, as well as their power supply's, on a regular basis.
Inside a Power Supply is a Heatsink, or more than one Heatsink.
A Heatsink is typically constructed of a flat metal base, that has tall fins protruding up from the base.
The metal base absorbs heat from whatever object is placed against it, and the heat is radiated up into the fins, where it is dissipated away.
Air flows through the fins, and helps carry the heat away.
(There is a Heatsink on top of the Processor also)
A Power Supply also has a fan.
The fan draws air into the Power Supply through the computer case, then pushes the air out of the back of the computer case.
The air drawn in through the computer case, helps to keep the hardware components inside the computer case cool, as well as the other fans that are implemented. (Computer case fan/s, Processor fan)
It also helps to keep the hardware components inside the Power Supply cool.
When the Heatsink fins are clogged with gunk, and the fan's blades, center hub, and surrounding shroud, are clogged with gunk, the cooling capacity of the Power Supply drops tremendously.
The Power Supply hardware components heat up.
Heat = Wasted Energy
The Power Supply tries to keep up with the demand for power, but with the energy loss due to excessive heat, the Power Supply hardware components eventually fail.
Typical SMPS used in a computer. (Personal Computer)
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Mar 05, 2010 | Computers & Internet
Heat ac fan quit blowing fuses ok what next?
Hi. You will need to acquire a volt meter, and test the blower motor for proper voltage(12v). If the motor is registering a 12 volt current(at contacts with the switch activated), simply replace the fan motor. If not, replace the fan relay, or resistor switch.
Nov 26, 2009 | 2005 Pontiac Grand Prix
2005 Caravan blower not working
some quick testing would help. test for voltage at the resistor. if there is voltage at the resistor, check for voltage at the fan. if you have power at the fan, remove the fan and hook it up to 12 volts to see if it spins. watch your fingers in case it does spin as it usually spins very fast.
i've seen brand new parts right out of the box that were defective so you need to rule out the resistor and the fan first. if no power is present and the fan works, test the power going to the switch that controls the fan speed.
incidentally if you are visually checking the fuse, pull it out and use a meter to check if there is indeed continuity.
robert
Sep 02, 2009 | 2004 Chrysler Voyager
2005 Pontiac Bonneville hvac blower does not come on
Start by checking the blower resistor. It should be under the dash on the passenger side near the blower itself. You will need to remove the glove box to access it. It is a small plate that has only a few screws and a group of wires that go to a plug in the center. Unplug it and remove the screws. When you pull it out it should look like a series of small spring shaped coils. Most likely one or two of them will be burned up. Replace it in reverse order and your blower should start working again. If this is not the problem then test the fan motor itself. Hope this helps. Good luck.
Jul 26, 2009 | 2005 Pontiac Bonneville
Where to plug case side fan
Pinout Pin number Wire color Description 1 yellow +12 volts 2 black ground 3 black ground 4 red +5 volts
Jan 27, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
How do i install my power supply fan in and if its a emachine fan is there a diffrence in the year models
The power supply comes with a fan. Therefore I guess you need to replace a bad fan. Remove the power-supply case.
Note which direction the fan spins. There is an arrow on the plastic fan case. You will note that one side of the fan is open. Be sure to put the new fan so it faces the exactly the same way. Remove the screws holding the bad fan and cut the wires leaving enough room on them to solder on to the new fan.
Your replacement is usually a normal 80mm, 12 volt case fan that provides ventilation in most PC cases.
Connect the two wires to the new fan by soldering the red wire to the red wire and black to black. Use shrink tubing or tape to insulate the connections.
A second option is to replace the entire power supply with a new one (containing a new fan). Then there is no soldering involved. If you look carefully enough, you will find them cheaply on line.
Hope this helps. :)
Apr 02, 2008 | Computers & Internet
FIC IC-VG61 (dhicecube) Barebone Logo
305 people viewed this question
Top FIC Computers & Internet Experts
David
David
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
