Question about Epson PhotoPC 700 Digital Camera
Can images be renamed without causing them to fail the verification test?
    Master:
  • 542 Answers
Yes. Changing file names will not cause images to fail the verification test.
Posted on Sep 13, 2005
Profile service service will not allow me to logon
First of all start your computer in safe mode. This can be achieved by pressing F8 during the start-up of your computer. If this is done correctly you'll get a menu where you can choose to start your computer in safe mode.
After it is booted in safe mode follow these steps:
  1. Click Start, type regedit in the Search box, and then press ENTER.
  2. In Registry Editor, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
  3. In the navigation pane, locate the folder that begins with S-1-5 (SID key) followed by a long number.
  4. Click each S-1-5 folder, locate the ProfileImagePath entry in the details pane, and then double-click to make sure that this is the user account profile that has the error.
    • If you have two folders starting with S-1-5 followed by some long numbers and one of them ended with .bak, you have to rename the .bak folder. To do this, follow these steps:
      1. Right-click the folder without .bak, and then click Rename. Type .ba, and then press ENTER.
      2. .bak, and then click Rename. Remove .bak at the end of the folder name, and then press ENTER.
        [img src="http://support.microsoft.com/Library/images/2493039.png" alt="2493039" title="2493039">
      3. .ba, and then click Rename. Change the .ba to .bak at the end of the folder name, and then press ENTER.
        [img src="http://support.microsoft.com/Library/images/2493040.png" alt="2493040" title="2493040">
    • If you have only one folder starting with S-1-5 that is followed by long numbers and ends with .bak. Right-click the folder, and then click Rename. Remove .bak at the end of the folder name, and then press ENTER.
      1. .bak, and then click Rename. Type .ba, and then press ENTER.
        [img src="http://support.microsoft.com/Library/images/2493038.png" alt="2493038" title="2493038">
  5. Double-click the folder without .bak in the details pane, double-click RefCount, type 0, and then click OK.
  6. Click the folder without .bak, in the details pane, double-click State, type 0, and then click OK.
  7. Close Registry Editor.
  8. Restart the computer.
  9. Log on again with your account.
Dec 24, 2013 | Computers & Internet
The user profile service failed the logon. user profile cannot be loaded
Anyway.. If you can, follow these steps. They might help! If not, give me a bell! It looks complicated, but it's very easy.
Also, before this happened, did you trying doing a Windows Update? If so, that was the cause, especially if it failed. I don't know why it locks the account, however.
1. Open the Start menu.
2. In the white line (Start Search) area, type regedit and press Enter.
3. If prompted, either click on Continue or enter the password for the Administrator account.
4. In regedit, go to: (See screenshot below step 5)
5. In the left pane, look for the S-1-5..... folder (SID key) with the long number that has .bak at the end of the numbers.
(See screenshots below steps 6A and 7B)
NOTE:
A) In the right pane, look at the ProfileImagePath to verify that this is the user account profile that has the error.
B) You may have another S-1-5..... folder (SID key) above it with the exact same number without the .bak at the end of it.
6. For Two S-1-5..... folders (SID key) with the same Number -
NOTE: This is if you have two S-1-5..... folders (SID key) with the exact same numbers, but the second (below) one has the .bak at the end of the numbers.
A) In the left pane, right click on the first (top) S-1-5..... folder (SID key) that does not have .bak at the end of the numbers and click Rename. (See screenshot below)
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.2803d1221837039-user-profile-service-failed-logon-user-profile-cannot-loaded-repair.jpg
B) Add .bk to the end of the numbers. (See screenshot below)
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.2804d1221837039-user-profile-service-failed-logon-user-profile-cannot-loaded-repair_bk.jpg
C) In the left pane, right click on the second S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot above)
D) Remove only .bak from the end of the numbers and press Enter. (See screenshot below)
E) Now go back and Rename the first one with .bk to .bak now at the end of the numbers and press Enter.
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.2805d1221837039-user-profile-service-failed-logon-user-profile-cannot-loaded-repar_bak.jpg
F) Go to step 8.
7. For Only One S-1-5..... Folder (SID key) with .bak -
NOTE: This is if you only have one S-1-5..... folder (SID key) for your user account with .bak at the end of the numbers.
A) In the left pane, right click on the S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot below)
B) Remove only .bak at the end of the numbers and press Enter. (See screenshot below and below step 10)
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 836x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 836x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 836x303.2737d1221837039-user-profile-service-failed-logon-user-profile-cannot-loaded-repair_reg2.jpg
8. In the right pane of the one without .bak now, right click on RefCount and click Modify. (See screenshot below step 10)
NOTE: If you do not have RefCount, then right click on a empty space in the right pane and click New and DWORD (32 bit) Value, then type RefCount and press Enter.
A) Type 0 (number) and click on OK. (See screenshot below)
2738d1202983360-user-profile-service-failed-logon-user-profile-cannot-loaded-modify_refcount.jpg
9. In the right pane of the one without .bak now, right click on State and click Modify. (See screenshot below step 10)
2739d1202983366-user-profile-service-failed-logon-user-profile-cannot-loaded-modify_state.jpg
10. The registry will now look like this for the one without .bak now. (See screenshot below)
11. Close regedit.
12. Restart the computer.
13. See if you can logon now.
Mar 14, 2013 | HP Computers & Internet
DirectSound test results: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)
Run the dell diagnostics on the sound card .
1. Restart your computer
2. tap on the f12 key slowly five times
3. select the option Boot to utility partision or diagnostics
4.select dell 32 bit diagnostics
5. Select customer test and test sound
If the test pass, try system restore , probably the problem is with the sound card drivers
if the sound test fails , shutdown the system again and remove the cmos battery and start the system without it once.Check sound again .
Thanks
proton
Apr 28, 2009 | Creative Labs SoundBlaster Audigy 2 ZS...
Sep 13, 2005 | Epson PhotoPC 850Z Digital Camera
Sep 13, 2005 | Epson PhotoPC 750Z Digital Camera
Editing epson-protected images
No, if an IAS image is edited it will fail the verification test. If you need to edit an image, a copy of an unaltered Epson-protected image can be made for editing purposes, keeping the original image unaltered.
Sep 13, 2005 | Epson PhotoPC 700 Digital Camera
Epson PhotoPC 700 Digital Camera Logo
162 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Harrie
Thomas Stauber
Thomas Stauber
Are you an Epson Camera Expert? Answer questions, earn points and help others
