Question about Sakar Kidz Cam Digital Camera
Connrction error I get the folowing message when I click to download the pictures: There is a connection error. Please check the trobleshooting section in your manual but therei s no troubleshooting section. I have check the conection to the camera and to the PC and they are both ok.
  • hdowding Nov 28, 2008
    I can't download the pictures from the camera ... it comes up with connection problem and check the troubleshooting guide... which I cant find
  • 684 Answers
1. Connect the camera to a diffrent USB port and try to download Pics....... 2. Goto My Computer Device Manager see if u find any yellow exclamation or question marks under Imaging Devices if yes right click on it click on update drivers choose to update the drivers from the CD and it should work if u don see any imaging devices that states that the USB cable is defective get it replaced................
Posted on Dec 15, 2008
When i my pc on it show me generic host problem after this msg windows stop network services?anyone tel me
You may occasionally get an error message that reads "This connection has limited or no connectivity. You might not be able to access the Internet or some network resources." It indicates that your PC is having a problem trying to access your network device to connect to the Internet. Very often, a bug that typically affects Windows XP Service Pack 2 causes this error message. This bug causes a loss of your network connectivity in workstations that use Microsoft's L2TP-based VPN (virtual private networking) client to connect to the NAT-based networks. You can fix the "Limited or No Connectivity" problem in a few steps. (If your connection works but you still get the error message, go to Section 2 to learn how to disable it.)
Review the following symptoms and determine if you experience any of them after you install the Windows XP Service Pack 2:
You get the error message "Limited or No Connectivity" when you attempt to connect to your network.
You have a problem connecting to your local area network or to the Internet.
You keep on receiving an error message: "Acquiring IP Address" message. If you experience these symptoms after installing Windows XP Service Pack 2, then this bug is causing the problem. In this case, go to Step 2; otherwise, skip to Section 3 Download the Microsoft patch (KB884020) from the Microsoft website. Run this update to install it. Create a registry fix by launching Notepad and typing: [HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services\\IPSec] "AssumeUDPEncapsulationContextOnSendRule\"=dword:00000002 Save the file as FixReg.reg to your desktop. Double-click the saved file to install it into your registry. Restart your computer and the error message will likely be gone. If you still see the error message, follow the steps in Section 2. b> If Your Connection Works But You Still Get the Error Message b> Navigate to the "Start" button and select the "Control Panel." Double-click on the "Network Connections" icon. Right-click the "Local Area Connection" icon and select "Properties" from the popup menu. Click on the "General" tab. Uncheck the option that is labeled "Notify me when this connection has limited or no connectivity." Click "OK." b> If the Patch Doesn't Fix the " Limited or No Connectivity" Problem b> Check your DSL router for any malfunctions. Re-configure or power cycle your router. Check your computer's network card configurations and network cabling to ensure that the problem does not lie here. Check your firewall to determine whether it is blocking you from connecting to the network or to the Internet. Disable the firewall and attempt connecting to the network or Internet while with the firewall is disabled. If the firewall is causing connection problems, then reset or uninstall and re-install the firewall. Reduce your connection speed to 10 Mbps and test this to determine if it fixes the problem. To do so, navigate to the "Start" menu and select the "Control Panel," "System" and "Device Manager." Review the properties of your network card. Click the "Advanced tab." Locate the "Link Speed and Duplex" section. Change the settings from "Auto Detect" to "10Mbps/Full Duplex." Hope this helps.
Dec 24, 2012 | Computers & Internet
I need a useers manual for an IBM T41 Thinkpad
Thanks for your trust
1. IBM T41 manual download from here
IBM ThinkPad Download Drivers & Software or
(Open link using Internet Explorer web browser)
http://www-307.ibm.com/pc/support/site.wss/product.do?doctypeind=9&template=%2Fproductselection%2Flandingpages%2FdownloadsDriversLandingPage.vm&sitestyle=lenovo
2. Click Download Drivers & Software (image 1)
3. Click Run Auto-Detect, only available in Internet Explorer (image 2)
4. Example: ThinkPad T41 (2378). Click User Guides & Manuals (image 3)
5. IBM provides a lot of manuals that can be downloaded. You can download the manual you need. Example: Service & Trobleshooting. Select language to download (image 4)
6. You can download all the manuals you need.
Thanks.
Dec 03, 2011 | Computers & Internet
I have an HP Pavilion a1510n it is giving an error message that it is missing EZAR.msi
folow these instructions hopefuy this works
start > all programs > HP Application Recovery
When the Application Recovery console comes up, Choose Application Installation then click NEXT.
When the list comes up, highlight Roxio DigitalMedia Archive by clicking on it, then click the "Install" button.
It will re-install Digital Media Archive, and fix your EZARC.msi search issue.
please vote if this was helpful thank you.
Feb 18, 2011 | HP Pavilion a1410n (ER890AA) PC Desktop
Hi REGGSVR32 Mssip32.dll cant be found how to
open run menu and type these one by one and press enter , then check
a. REGSVR32 softpub.dll
b. REGSVR32 wintrust.dll
c. REGSVR32 initpki.dll
d. REGSVR32 Rsaenh.dll
e. REGSVR32 Mssip32.dll
f. REGSVR32 Cryptdlg.dll
g. REGSVR32 Dssenh.dll
h. REGSVR32 Gpkcsp.dll
i. REGSVR32 Slbcsp.dll
j. REGSVR32 Sccbase.dll
Apr 26, 2010 | Microsoft Windows Live Messanger
Yahoo messenger is not open
Hello rasirajini
your yahoo messenger might be old or new version available download a new copy of yahoo messenger and log in again this will sure help you
Click here to Download
Regards
Manish
Apr 08, 2010 | Yahoo Messenger
Aspire one notebook wireless connetion there one day gone the next! have updated atheros drivers to no avail. just wont connect, gives me the WZC service error msg
Hi
Thank you for your query
Please try the folowing
Hi
The error message indicates that you have corrupted system files
Please try the following
1) Start Laptop
2) Continuously press the F8 key until a startup menu is repsented
3) Choose safe mode from the menu
4) Once safe mode has loaded up click on Start>Programs>Accesories>System Tools>System Restore
5) From system restore choose 'restore my computer to an earlier time'
6) From the calender presented please select a date in bold lettering back a few weeks before this fault was seen
7) Choose the date and click next..............follow the instructions through
Feb 22, 2010 | Acer Aspire One PC Notebook
Trobleshooting when i sign in yahoo messenger???
the sign in did not connect in  time basicly the internet connection was not active that's way you get a window that say troubleshooting or cancel.
Feb 01, 2010 | Yahoo Messenger
Donwload of the fotos
1. Insert the Motorola Phone Software CD in the CD Drive.
2. The setup will launch automatically.
3. Select the appropriate software (PC Suite / Phone Software) to install.
4. Folow the instructions that appear and complete the installation.
5. Restart the system.
6. Start the PC Suite / Motorola Phone Solution software.
7. Click on 'Connect to phone', and follow the instructions.
8. Connect the cable between the phone and PC when asked.
9. The PC will detect the phone automatically.
10. Now, you can download the pictures from phone to PC easily by selecting the appropriate option!
please rate this advice if it hepls...tc! :)
Jan 19, 2010 | Motorola Mobility W375 Cellular Phone
Error message
Use a separate card reader to download your pictures.
Sep 23, 2009 | Fuji Finepix Z20fd Digital Camera
Sakar Kidz Cam Digital Camera Logo
90 people viewed this question
Top Sakar Cameras Experts
Robert
Tony
Are you a Sakar Camera Expert? Answer questions, earn points and help others
