Question about Mach Speed TRIO Onyx MP3 Player
Volume control I can't get the volume to go any higher than 31. Is there software to increase the volume?
That's the max volume for the unit. It was built that way. The volume setting is a 5-bit value, which is why it comes out to a strange number, but if you count 0, there are 32 settings total. Hence 2 to the 5th power.
But no, that's as high as it goes.
Posted on Sep 13, 2008
  • 3 Answers
Yes, that's as high as it goes. You can use the different EQ's to make it a little louder or quieter, though,
Posted on Jan 13, 2009
How to increase volume on corded speaker phone
Are we talking about an old style phone that you plug into a wall jack. In that case you can only increase the volume as high as the volume control will let you. Going higher may introduce significate feed back (high pitched whine).
If it's the microphone volume you want to increase (sound volume for the other party), that's not possible with out a major hack.
The phone needs to control the speaker volume and the microphone volume, and balance the two so you don't get feedback, yet allow each party to hear the other. This only works within a fixed range, which, if you exceed, will over load the circuit and you will get feedback. You may want to try a different phone, which may have a higher volume.
Sep 06, 2017 | Cell Phones
MAJIC JACK VOLUME IS TOO LOW.
Look into the Majic Jack software for volume controls. You could try increasing the volume controls that are in Windows.
Click Start/Control Panel or Start/Settings/Control Panel and look for Audio or Sound. Open it and increase the volume.
You can also get to the Audio or Sound by clicking the megaphone at the bottom right near the time and adjust the volume.
Jun 01, 2012 | Computers & Internet
How to increase volume of Nokia C5? Is thr any code or software
On the right side you will notice a switch showing you 2 triangles one on top and one on bottom. This is the volume switch. If you press the top triangle thr volume will increase and if you press the lower triangle the volume will decrease. Also you can go to phone settings in the menu and increase the volume by clicking on volume control.
Aug 22, 2011 | Nokia C5 Cell Phone
Where is the volume control on the stupid phone, it is nowhere in the menu and no buttons or slider control
While on a call, press down/CID to decrease or up/DIR to increase the volume. (page 11)
To change the answering machine volume, use the VOL- and VOL+ buttons. (page 31)
To change the ringer style, press PROG, use up/down to select "RINGER". Use up/down to select the desired style and press SELECT. (page 9)
The above page numbers are from the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/606/UserManual/1644/ia5864_manual_bkm.pdf
Jun 21, 2011 | Vtech ia5864 Cordless Phone
Telephone ring is not loud enough. Can I buy a volume enhancer
This depends on the phone you are refering to. Although most phones have setup for increasing the volume to a higher tone. Check settings for your device and check volume control under volume control you should be able to raise the volume. Although i am yet to see a volume enhancer for phones.
Hope this solution has been helpful?
May 25, 2011 | Lands Phones
My volume control is broken and the decreasing/increasing volume thing on my screen wont go away. if i go to the volume control on the taskbar it decreases imidiatly after increasing and this has happed...
uninstall all the audio drivers and software and restart your computer then install athe audio drivers and the software then restart the computer then after instillation of the drivers and the software you will see a speaker icon in the task bar right click it then open the volume control and set the volume to desired level
Jan 17, 2011 | Acer Aspire One PC Notebook
My nokia 5310 fell down and volume control is not working.. i am not able to adjust the volume.. how can i make the volume control work.. or how can i increase or decrease the volume without using volume...
hi
either your volume button get damaged or the software gets corrupted in your phone.. change the volume button and format the phone.this willl fix your phone..
thank you
Dec 24, 2010 | Nokia 5310 Cellular Phone
My samsung star gt-s5233s model mobile volume low what is secret code for increase volume
just type *#8999*8378# & 2:2 then go to melody & put all of them to
31
31
31
31
31
& save it
the volume of the ringer would increase
USE THIS AT YOUR OWN RISK I AM NOT RESPONSIBLE FOR YOUR PHONE MESSING UP,THESE MENU'S ARE FOR SAMSUNG SERVICE ONLY.
Dec 03, 2009 | Cell Phones
The volume of my mp3 player sony E436F is too much low. Can I to high...??? Is there any solution???
Hi rockgfr,
The first way to increase the volume is of course by the volume control on the right hand side of the player. If even at the highest limit (30) provided by this control, the volume seems low, then go to Settings --> Common Settings --> AVLS. The volume limit is probably on, so you can try putting it off and see if you can increase the volume further. Failing these methods, you can always use software like MP3Gain to raise the volume of your tracks.
Nov 04, 2009 | Sony NWZ-E436F MP3 Player
AUDIO
Hey Tex
You are on the right track, sounds like a noisy volume control. Can often be repaired with a squirt of cleaner spray into the potentiometer assembly.But I suggest you use crc2-26 contact lubricant spray, not silicone spray which is a great materials lubricant, but not electrical. Worst case, the Vol Potentiometer, may have to be replaced. Go for the CRC first and see how it goes. Good Luck, happy FixYa
regards
Graeme
Mar 05, 2008 | Audio Players & Recorders
Mach Speed TRIO Onyx MP3 Player Logo
140 people viewed this question
Top Mach Speed Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
