Question about Xerox WorkCentre M15i Laser Printer
Jaime arnuero Only funtion in mode printer and not funtion in mode copy
  • 3 Answers
The scanner is locked  for the down is de scanner push bottom green.
Posted on Feb 03, 2009
When we make copies they come out really, really dark. We have the setting as light as it will go. How can we resolve this?
  • try this when a dark image of original.
  • clean the scanner cavity,lenses,mirrors,scaner lamp reflector
  • adjust/increase scaning lamp voltage (on lamp regulater pcb)
  • clean/adjust hight of charging corona wire
  • adjust bais voltage in servce mode (add function then both key2 and 8 saimantaniously then add funtion)
  • adjust/replace cleaning blade
  • replace scanner lamp
  • Try this when zed black copy came out
  • check scanner lamp is working
  • check developing unit connection and contacts
  • check drum earthing contact
Jan 06, 2011 | Canon NP 6230 Copier
A blak line on the copies??
raise the control panel and look for white out and stricks on the mirror or glass. jaime
Jul 08, 2010 | Ricoh FAX2900L Plain Paper Laser
CANON C5030 : set up user box
see your user manual or go to googles.com and see where you can get one. jaime
Jul 02, 2010 | Canon imageRUNNER 5000 Copier
I have a Panasonic DP-4530 How do I wsitch off the Energy saver.
I work on Canon machines and most of the time you will find this in the machine customer funtion on control board. To turn it off compleatly if possible a tech will need to get into a tech mode. My machines have a 4 hour max. And there are about 2 places that need to be checked or increased in time. Hope this may help. Nova Copy is a good company for panasonic. Dallas Texas
Jun 09, 2010 | Panasonic Workio DP-4530 Copier
I HAVE A NAVMAN PIN 570 WHICH ONLY COMES ON WHEN CONNECTED TO A POWER SUPPLY AND SWITCHES OFF WHEN DISCONNECTED. ALSO THE FUNTIONS KEYS AT THE FRONT DO NOT WORK - CAN YOU ASSIST WITH THIS PROBLEM. THANK...
Hello Clariss.-
I think that your problem is Battery, I had same problem and I changed it.
About the front keys, In start -> setting -> buttons, you can solve this problem.
Greetings
Jaime
May 13, 2010 | Navman PiN 570 GPS Receiver
LANIER COLOR COPIER MODEL LD345c Funtional Problem SC541
sc541 means no warm up, press the clear modees the punch in107 then press and hold down the clear stop key untilk it goes into sevice mode then shut main power
Apr 07, 2010 | Lanier 1205 Copier
COPY GETS CUT OFF WHEN COPYING IN COPY RATIO FROM LEGAL TO LETTER SIZE
use the maual reduce and inlare funtion to get the proper coveage
Jan 12, 2010 | Office Equipment & Supplies
Gestetner 5308bt copy printer error after switching on E-01 call service - How can I fix it I am on a ship at present
This is a cutter error. Check the following.
Master cut error occurred
Cutter switch
Cutter motor
Cutter drive mechanism
Open the side the master is loaded. Check that the cutter is in the home possition and that there is no used master stuck in the machine. Check the motor by entering sp mode
Function clear "107" press and hold C/clear
"131" #
"23" Start key
will return cutter to home position.
Press funtion clear to exit.
If the motor is not running you will have to replace it.
Nov 13, 2009 | Gestetner Office Equipment & Supplies
C03FF Minolta bizhub 210
C03FF, is the improper or unmatched model setting code. go to "service mode" In service mode please select "ADJUST"
in "ADJUST" please select "Model Setting" in "Model Setting" select the cpm, (Copy speed) of your machine, for example if you have bizhub 210, then select "21" from the list. if you have bizhub 163 then select "16" from the list and press "yes" button. code will remove.
Jan 29, 2009 | Konica Minolta DiALTA Di183F Copier
Canon Pixma 750, works great, except that it will no longer copy.
Diamond,
You need to be more specific. Does nothing happen when you press the Copy button? Does it give you a blank page, a solid inked page, or no page for the copy? Do you get the same results for Color Copy or Black and White Copy?
Jun 25, 2008 | Canon PIXMA MP750 All-In-One InkJet...
Xerox WorkCentre M15i Laser Printer Logo
113 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
