Question about Casio EXILIM Card EX-S770 Digital Camera
Screen My screen seems to be faulty as I ca turn on the camera and take pictures still, but can only see a tin strip at the bottom of the screen. The rest is just white with a black spot. Can my screen be relaced and if so where and cost? Thanks
  • DLNKLVCH Nov 04, 2008
    There is a large crack in my casio exilim ex-s770 screen. Is it possible to order a replacement screen and how much would it cost?
  • Pat1224 Mar 12, 2009
    Most of the screen is blank. The bottom portion shows the picture.T
  • 71 Answers
Try removing the baterry from the camera for at least 30 minutes and try again. Good luck!
Posted on Oct 30, 2008
Streaks across the pictures and some flickering on screen
the LCD screen may be faulty, or the connecting strip loose or corrosion on it, clean, if necessary change.
Apr 08, 2016 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera screen is black no image appears to view to take a picture??
Time for a new camera perhaps ? Sreen is faulty, most likely and fixing may be too expensive.
Sep 11, 2014 | Kodak EasyShare MD853 Digital Camera
What is the problem when the camera is turned on and just a white screen appears.
I solved this problem by turn the camera off, then apply pressure at the bottom right of the screen(with your finger), press kinda hard, and turn the camera ON while pressing, it should work.
Good luck
Jan 28, 2011 | Sony Cameras
I have easyshare M341 my screen turn white after some pictures
Contact resistance to thin film transistors cause the full voltage on tin oxide LCD cells. Try pat gently on every side of the shift the contavts, it works sometimes. Otherwise you may pay to have it serviced.
Dec 22, 2010 | Cameras
When I turn on my Vizio P42hd I get lines of different colors down the left side of the unit from top to bottom. Is this something that can be fixed? My email is
This problems is not causes by a person or some objects by hitting ur LCD tv picture screen panel?If,yes,by a person or an objects by hitting the picture screen panel.This tv is not repairable only can be by replaced the whole entire LCD picture screen panel only,sorry than this tv is not worth repairing.Because by replacing the tv LCD picture screen panel itself,will cost the same as a new tv.If these colors strips show up by itself,yes,tv it is repairable.The board call the T-Con decoders board is dead.This board sit right at the bottom right in the middle of the LCD picture screen panel.Tries websites like, to buy a refurbish T-Con decoders board for the replacement.
Nov 22, 2010 | Vizio P42HD Television
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
My camera will not take pictures
Whats your camera make / model?
I have found this problem in the past mainly on samsung cameras. All I found was bad connections and poor solder joints.
connection problems with ribbons mainly. Samsung seem to prefer tinned ends as opposed to gold plated ribbon connections and these are just waiting to discolour and then fail.
Bad connections will drain batteries very fast and especially if your using cheap ones
Mar 15, 2009 | Cameras
Viewing Screen White Out
this seems to be a fault with the CCD of the camera
you will have to make a major repair
Sep 17, 2008 | Fuji FinePix A345 Digital Camera
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
Aug 31, 2008 | Kodak EasyShare C315 Digital Camera
Black screen when I turn the camera on
You could be suffering from a frozen Iris. This is the part of the lens which varies the amount of light entering the camera. Or the lens cover may not be opening when you switch on. Have you tried pushing the middle button of the 3 which run vertically on the rear of the camera below the mode switch. I had one on my bench a few weeks back which had an intermittent black screen. It started of as black and when I stripped it, cleaned all contacts and put it back together it the flashed on and off. I then stripped it again and went over every cable associated with the lens, CCD and video board checking them for breaks and recleaning them and bingo, everything came good. I have another 72 at the moment with a similar problem, I fixed the same way but got left with lines running across the picture. P72's aren't the best cameras picture wise and are close to the most troublesome, at least around here. For any of the above faults I'd recommend a visit to your local tech. Good luck. BMW
Jun 26, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
97 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
