High voltage parts are suspect. Need to put a voltmeter on the
input (primary) side to the high-voltage transformer (big heavy iron
thing in there) Should be getting 120Vac when it goes to cook
cycle. Don't touch the other (high voltage) side of this
transformer. If the power is there, you are looking at replacing
high-voltage capacitor and diode. If that doesn't solve it, then
it needs a new magnatron. Its affordable if you do it yourself - buy
the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
either the magnatron or the high-voltage capacitor and diode. Its
affordable if you do it yourself - buy the part on EBAY - lookup
Hope ya fix it!
Is the unit under warranty? If not, you can try to remove the cover and see if there is a blown fuse in the section that powers the Magnetron. How old is the unit? Typically, no heating of food, indicates a bad Magnetron (tube).
High voltage parts: Capacitor, Diode, Magnatron are suspect. Need
to put a voltmeter on the input (primary) side to the high-voltage
transformer (big heavy iron thing in there) Should be getting 120Vac
when it goes to cook cycle. Don't touch the other (high voltage)
side of this transformer. If the power is there, you are looking
at replacing either the magnatron or the high-voltage capacitor and
diode. Its affordable if you do it yourself - buy the part on
Hope ya fix it!
Magnatron is suspect. Need to put a voltmeter on the input
(primary) side to the high-voltage transformer (big heavy iron thing in
there) Should be getting 120Vac when it goes to cook cycle. Don't
touch the other (high voltage) side of this transformer. If the
power is there, you are looking at replacing either the magnatron or
the high-voltage capacitor and diode. Its affordable if you do it
yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
power is there, you are looking at replacing the magnatron. Its
Magnatron is suspect. Need to put a voltmeter and see if the
thing in there) is getting 120Vac. Don't touch the other (high
voltage) side of this transformer. If the power is there, you are
looking at replacing the magnatron. Its affordable if you do it
Magnatron is suspect. Need to put a voltmeter and see if the input
there) is getting 120Vac. Don't touch the other (high voltage) side of
this transformer. If the power is there, you are looking at replacing
the magnatron. Its affordable if you do it yourself - buy the part on
