Question about Cell Phones
I dropped my phone in water and it want go off car kit car kit
  • petsybar Dec 25, 2008
    my husband dropped his motorola v360 in a sink of CLEAN TAP water today. It will not turn on...any suggestions? Or is it Gone?
    Thanks,
    barbara
  • 18 Answers
Cell phones dropped in water are no good..you will need to get a new one i can guarantee you that..there is always problems with them when they have water in them.
Posted on Sep 03, 2008
SUBARU FORESTER 2004 2.0 XT The water in the expansion tank keep dropping and needs topping up every other day but the water in the radiator remain constant. All the hoses comneection have been checked an...
Get a coolant if dye kit at autozone or similar. Put the dye in tank and run vehicle. When coolant tank is low use flashlight in kit to look for the crack
Jan 10, 2018 | Cars & Trucks
Same problem as this person.
Hello
Im sorry to hear about your problem.
If this problem happened directly after getting water on your phone then it could have been a result of shorting out and putting the phone in car kit mode (the mode for when you are using it along with a car kit) . If this is the case then your phone can't be fixed.
If the problem did not appear after the water damage then you may want to refer to the manual to find instructions on switching the phone off of cat kit mode.
Post back if you have any further questions. Thank you for choosing Fixya!
Jun 23, 2009 | LG VX8300 Cellular Phone
Nokia nk7w wont let me pair with my nokia n95 or n85
what dave said.......some times these kits can play up.....if you see the light on the button on all the time then you need to cut the power to the kit and then reconnect it, this should solve your problems.
Dec 12, 2008 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Car Kit will not shut off
i wiggled a knife in the right side of the charger port like the other guy said and it worked!
Jul 09, 2008 | LG VX5300 Cellular Phone
My lg vx8300 phone
Go to settings and change the normal mode and re staret the phone settings will actvate.
Jun 24, 2008 | LG VX8300 Cellular Phone
Car kit mode
Car kit mode is usually caused by debris in the phone's cable connector (at the bottom of the phone). The debris causes two or more contacts to be electrically connected to each other, causing the phone to think it's connected to a car kit. Remove the battery from the phone and clean the cable connector contacts with some rubbing alcohol and the corner of a towel. Also, try using an opened paperclip to scrape the contacts in the connector, this will remove any corrosion that may have built up.
Feb 17, 2008 | LG VX8300 Cellular Phone
External antenna
try teking the phone and have the antenna replaced or service that should correct any problems that you may have.
Feb 01, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Dropped it into sink
was there water in the sink at the time?
if so check the connections on the base if there is green corrosion on it the the damage is done you will have to find someone who will repair water damaged phones.
If no water and just the drop that caused the prob then try removing the battery while the phone is still turned on this may shock it back
Nov 17, 2007 | LG VX9800 Cellular Phone
Phone says "car kit"
i brought my phone into verizon and they cleaned the charging terminal and it has worked fine ever since. My phone was accidentally dropped into water. if they tell you it can not be fixed use a small brush to gently clean the terminals on the bottom of your phone.
Sep 25, 2007 | LG VX8300 Cellular Phone
Car kit
there is internal damage an easy fix is to plug it into the car charger and it will only work on the charger you should have let the phone sit out and dry with the battery detatched. my phone did the same thing about 3 months ago. if that doesn't work you'll need a new phone
Feb 23, 2007 | LG VERIZON VX5200 Hands-Free Headset...
Cell Phones Logo
130 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
