Question about HP Office Equipment & Supplies
Im trying to connect my new 6310 HP Office Jet to my computer using my router. I have the Printer pluged into one of the availaple router ports, I have a green light in the printer end of the caple however the error message I get is "Setup was unable to detect any printers on the network"
  • 78 Answers
Is your router a 'print server' router?
Posted on Sep 01, 2008
  • Klutch Davis
    Klutch Davis Sep 02, 2008
    could you tell me your router type. what connections you have at the back of your printer and what os you are using? many thanks, hope i can help soon
Office jet G510-nz won't print says no computer connection
Unplug and plug in. Check cable. Is the printer wired or wireless? Check status in Printer in start menu. Enabled or Disabled? Go to Device Manager check for printer, driver. Is there software for the printer?
Nov 10, 2012 | HP OfficeJet 6310 All-in-One Printer...
Ink jet wireless printer says its printing then it shows an error and will not print.
Hp Office jet 6310 is not a wireless printer. Now if you will tell me that is it connected through Print Server?
Apr 13, 2011 | HP Officejet 6310 All-In-One InkJet...
Have a hp office jet 6310 and i use it wirelessly all the time for printing and have used it to fax. I have never used scanner but would like to. when i click start scan or scan to it show select...
I suggest that you run the scan from a computer and not from the printer, it works tons better. Each computer needs to have the install program run on it, NOT PLUG AND PLAY. Plug and play will make most stuff work, but not everything.
Further, HP printers are fussy about exactly when to connect the printer, get the correct install program for your printer and OS from HP.com, and install following the directions exactly.
Scanning is the one function that never works with plug and play.
Feb 12, 2011 | HP Officejet 6310 All-In-One InkJet...
HP Officejet J4680 Was connected to home wireless network for 8 months. Now won't connect. Tried everything. Router works perfectly with all computers & internet.
Shut down all computers and another devices connected to network. Shut down Router. Wait 3 minutes. Power on Router. Wait. Power on all devices.
Nov 07, 2010 | HP J4680 Office Jet All-In-One Printer
Hello, I lost the software for the hp office jet 6310,and also the manual,and dont know how to make it work wireless.
First download driver from below link. Click here Then install it in computer. Make sure your in printer settings wireless is enable .Also make sure printer ip address and computer ip address of wireless are in same subnet and gateway. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Aug 29, 2010 | HP Officejet 6310 All-In-One InkJet...
I need to install my new HP Officejet 6310 and set it as the default printer . I don't have a Installation CD Rom
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER WITHOUT CD-Rom
STEP 1: In your computer window click the Start button and select the option Devices and Printers.
STEP 2: A new menu Devices and Printers appear on the screen. Then click the option Add a printer.
STEP 3: After clicking the Add a Printer option two options appears on the screen.
Add a local printer
Add a network & wireless or Bluetooth printer.
Select the option that suits to your printer
STEP 4: If your printer is not a wireless then select the Add a local printer and select the option Use an existing port then click next.
STEP 5: Scroll down to select the HP in the manufacturer section.
STEP 6: Select your Hp printer model in the printer section then click next.
STEP 7: If your model number is not present then click the windows update it will automatically add your printer model.
Note: You must need internet connection to update the printer model to your computer.
STEP 8: Then click next and finish.
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER FOR WIRELESS CONNECTION:
Add a local printer
STEP 4: Select the option Add a network, wireless or Bluetooth printer and click your printer name and address.
STEP 5: After the HP officejet 6310 printer installation of your wireless printer next step is to add your printer name and click next.
STEP 6: Set default printer as your HP Officejet 6310 printer and select the option print a test page.
STEP 7: A new popup window appears on the screen, then close it and finish.
Jun 11, 2009 | HP Officejet 6310 All-In-One InkJet...
Won't print checks or anything from quicken but does for every other program. All I get is "spooling" and then nothing.
It won't print you have to save the file on the desktop or in documents or anywhere away from the original and then try to print.all printers have issues with quicken deluxe they will not print from quicken deluxe unless it so happens b fluke
May 29, 2009 | HP OfficeJet 6310 All-in-One Printer...
Jetdirect 170x External Print Server Not Visible over network
it is possiable that a firewall is in the way, but more likely is that you are on a different logical network or subnet.
the HP software relies upon doing a broadcast to find HP printers, broadcast traffice is not normally permitted between subnets, this is why the HP software does not find your printer.
basically you need to creat a new port on the computer in question and then associate a printer to that port.
do so by doing the following on XP pro.
get to the printers folder then click from the menu "File"
click "server properties"
click add port and then double click on the (Standard TCP/IP Port) a new wizard opens click next
in the top box enter the ip address of your printer. and click next. leave the device type as "Standard and as generic network card) click next then finish. then close.
now you have to link your printer to your new port.
install a new printer
making sure that you select local printer... but removing the tick "Automatically detect......" then click next and select LPT port 1.
click next choose HP on the left colum and HP lasterJet III from the right colum. click next give the printer a name of your choosing. and if nesseary choose if you want it to be a default printer or not.
click next and leave do not share selected.
click next
on the "do you want to print a test page " select "No"
then finish.
once done
right click you new printer select properties
then select the "Ports" tab
scroll down the list until you see new Standard TCP/IP port listed, select your port. then click apply
lastly click the advanced tab
using the driver part of this screen you are able to select the correct driver from the dropdown list if it is not avaliable click the new driver button and follow the prompts.
click OK when done.
hope this helps.
selecting the HP Laser Jet III making sure that the
Nov 03, 2008 | HP Jetdirect 170x Print Server
Wireless laptop not printing
Indeed, you don't need the print server. Since your HP 6310 already has an integrated network port, you may setup and use it on your laptop the same way you do with your desktop. If you can browse the Internet wirelessly with your laptop, you should also be able to print.
Jan 20, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
44 people viewed this question
Ben Johnson
