Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Loss of suction
My vacuum still works but it has much less power. I have washed and dried and replaced the filter.
I have had the suction stop completely on the attachments. Call Dyson to troubleshoot. They had me remove (two different times) noodle shaped plastic pieces (once it was purple and the other time silver) from the outside of the vacuum. It took a minute to do. Inside was a bent pen and all sorts of debris that wrapped around it. Removed all, and it worked beautifully again. It had nothing to do with the filter, which I had cleaned several times to no avail.
Posted on Sep 03, 2008
    Brigadier General:
  • 5,158 Answers
Have you examined the hose to see if it is plugged. take a broom handle and gently push it thru the hose if it doesn't have bends in it.
Robert
Posted on Sep 01, 2008
My Dyson Vacuum DC24 suction loss.
You sound pretty savvy in your troubleshooting. Take a look at this video. You may have a split in one of your three suction hoses. I tried to find a video for a DC24 but to no avail. These two models are pretty close and this video should help you out.
Dec 04, 2017 | Dyson Vacuums
Loss of suction and motor seems to be working harder than normal
Debbie,
What type of vacuum do you have? If you put it in, it did not come through with your question. To start with, if your vacuum has any type of filters, I would check those and make sure that they are clean. If they are washable, wash them according to the directions that come with the machine and let them completely dry before putting them back in. Check any hoses and nozzles for any clogs that would cut down on the suction. Hope this helps!
Aug 13, 2015 | Vacuums
There is loss of suction & when handle is locked upright it switches of power
Hi there, it's Jack at Dyson.
If your DC25 doesn't seem to be picking up as well as usual and shuts off in use, it's likely that it's overheating. This can be caused by a blockage - the filters may also need washing. To locate and clear any blockages please take a look at our Support guide:
http://www.dyson.co.uk/support/dc25/dc25-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
In normal use both filters need to be washed at least once every 3 months as shown in the video below. Use cold water without detergent and allow at least 24 hours for the filters to dry before replacing them.
This should resolve the issue but you can reach our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US) if you'd like any further advice.
Best wishes,
JackDyson Online Customer Supporthttp://www.dyson.com
Mar 04, 2013 | Dyson DC25 Animal Bagless Upright Vacuum
Loss of suction in hose
I'm sorry to hear you're having difficulty with your DC24. If there doesn't seem to be as much suction as usual through the hose, there may be a blockage in the wand or hose. You may also need to give the filters a wash.
To locate and remove any blockages in your machine, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
In normal use, the filters need to be washed at least once a month, as shown in the video below. Use cold water without detergent, and allow at least 24 hours for the filters to dry somewhere warm before replacing them.
This should resolve the issue, but if you'd like any further assistance or advice, please call us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Apr 16, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Suction is low, but bucket is not full and filter is relatively clean
The filter may be relatively clean, but if there's a lot of fined dust in your area the pores of the filter will fill and clog fairly quickly. Try replacing the filter and see what happens. If you don't have a spare, consider purchasing one for use while the other is drying out. Then alternate.
A leaky hose could also cause a loss of suction, as could a broke or cracked flex tube (the short piece in the power head).
Aug 05, 2010 | Electrolux Central Vacuum
Having a loss of suction issue. Has some suction but isn't enough to use the power head. Tried to take out the filter to wash it but the pull loop ripped off. How do I get the filter out now without...
You should be able to get a screwdriver or tool under the ring to be able to get ahold of enough to pull it out. Check the suction (a suction gage helps) at the power unit and then at all inlet valves. It could be a leak or clog somewhere in there. You have to check all areas to try to narrow down the problem. Look for a loose hose, tube, valve, fitting etc. Check Vac pans closely if you have them.
Feb 13, 2018 | Beam Industries 2900 Serenity Plus Central...
My vacuum is less than a year old- as a n upright it no longer picks up
check your filters. If you havent changed them, replace.. these filters get clogged putting excess strain on the motors and causing loss of suction
Feb 25, 2010 | Hoover U6630-900 WindTunnel Bagless...
Bissell doesn't work after less than 2 years-no suction power.
replace belt clean / replace the filters especially the one on the front just below the tank and there's another inside the upper tank it twists off
Dec 13, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Dyson suction loss
make sure the filters in the bottom are clean, then remove the canister and you will need to clean it thouroughly, pay close attention to the upper section inside where the "cones" come togetheri have read that they are prone to clog up here and lose suction, google dyson suction loss or how to clean a dyson ect...pay attention to getting the rod that releases the bottom to dump back in the correct place or it will not work right. a few write ups tell about this!
Jan 31, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
70 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
