Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi VS-4541 My projection tv will come on for about 3-5 minutes and even up to 20 minutes and then shut off.I turn it back on,it does the same thing.Could someone please advise if this can be fixed ?Thank you.
  • lee777 Sep 17, 2008
    Cleaned out inside the unit and it still does the same thing.When it gets ready to turn off,the screen gets blue and it has some lines in it.
Clean it out it is over heating, use a air hose to blow all the dust out
Posted on Sep 06, 2008
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi vs-4541 won't turn on
if you are a technical person, this is for you
check for IC9A1 and look for any shorts,
that's located in the main board
Apr 22, 2009 | Televison & Video
Completely black screen but has sound.
you probabily need to change the input, find the input button, when you hit it you should get a box on the screen, with inputs, highlight diferent ones and hit select- untill you get pick back, thats what my sugestion would be
Jan 11, 2009 | Mitsubishi VS-45605 50" Rear Projection...
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi VS-4541 too much red
The set is old and the picture tubes are probably weak. you can pop off the front grill, remove the protective panel to expose the picture tube sockets. On the sockets are controls to increase or decrease the intensity of the colors. The red is on the left ,green center and blue right. Go to a B&W picture or turn the color off, then adjust for the best grey screen.
Jan 03, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45607
Do self test first goto www.ctechnicians.com
Dec 08, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source
Jul 28, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
473 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
