Question about Motorola Mobility PEBL U6 Cellular Phone
Problem answering incoming calls on pebl--the flip doesn't work
I lost my last pebl and loved it so much I bought a new one on e-bay. This one, however, won't answer incoming calls when I flip the case open. I have to flip it and then push the green telephone button, which is annoying and takes too long. Any ideas?
    Brigadier General:
  • 7,752 Answers
You need to go to settings on the phone and and active the answer when the flip is open.
Posted on Sep 30, 2008
Droid X phone won't ring for incoming calls.
Found on Motorola Support:
1. Make sure that the "Smart Profile: Face Down" feature is enabled.
2. Hold the phone face up in your palm.
3. Call your Droid X from another phone.
4. As the phone is vibrating, DO NOT ANSWER.
5. Still holding the phone, flip the phone face down as it vibrates.
6. Still holding it face down, hit your volume key to silence the phone.
7. Flip the phone back over so it's face up. You should feel a quick vibrating jolt indicating the ringer is back on.
8. End the call. It shouldn't matter which phone you end the call from, as feeling the jolt is the key.
9. Leave phone face up and call yourself again. If the ringer is now working again, turn OFF "Smart Profile: Face Down" until there's a true fix.
10. If it does not work initially, try all of the steps again a few more times and hope you get lucky.
Jul 29, 2010 | Google Android
Bar some incoming calls
If you want to block some incoming calls, you will have to go through your wireless provider.
Jun 17, 2009 | Motorola Mobility PEBL U6 Cellular Phone
Caller ID
battery weak change ur battery
Sep 23, 2008 | Astra Meridian 9417 Corded Phone
New razr v3
chane the flex cable or try and reflash the phone firmware.
Dec 06, 2007 | Motorola Mobility RAZR V3
Cannot hear when call received
try answer the call and then raise the volume if this does not work return it
Nov 25, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Brand new Motorola PEBL dropping calls
you should try a master reset and clear....then connect back the wireless if the same problem occurs then try upgrading the firmware or have it reflash...that can be done by taking the phone to a mobile service center or mobile professional technician.
Oct 28, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Bluetooth not working on PEBL
you need to make sure that both devices are "discoverable," using the "find me" on the phone, and whatever the car's settings are.
Sep 05, 2007 | Motorola Mobility PEBL U6 Cellular Phone
External display screen problem...picture stuck
Hi, Have you tried removing the battery? If not, remove it, wait a few minutes, refit the battery and reboot the phone, its worked for me before with a different problem. Paul.
Sep 04, 2007 | Motorola Mobility RAZR V3
I lost audio on my pebl ringtones
there is no problem in the cel phone == try to change the profile - = if that does not works then check that the speaker of phone is not damaged,,,it is also possible that the link between your mobil speaker is broken this happen due to small inside wiring ====you can cure this problem by going to any local mobil technician == make sure he will check your cell in your presence GOOD LUCK
Apr 26, 2007 | Motorola Mobility RAZR V3
Motorola Mobility PEBL U6 Cellular Phone Logo
186 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
