Question about Epson PhotoPC 650 Digital Camera
Image on screen is too dark.
The image on the screen is too dark.
    Master:
  • 542 Answers
Adjust the brightness of the screen using the Camera SETUP menu. See page 3-14 for instructions. In direct sunlight conditions, you may need to shield the LCD display monitor with your hand.
Posted on Sep 13, 2005
SOURCE:
Screen keeps t going blank but still have power
It may be the internal backlight that is failing. When the display has failed but still has power, take a flashlight and hold it close to the screen, move the flashlight all around the screen and check if you can see anything. The display will be dark, but you should be able to make out the image that is there with the flashlight technique. If you can see an image on-screen, then your backlight has failed and you will need to replace the monitor. Weather or not you see an image is not a critical issue, but a tool to verify if the backlight is off or some other issue is causing the problem.
Note, it may be difficult to detect an image on the un-light display, for example if you have a dark image as your desktop background. So make sure to fully scan your display (top to bottom, and left to right covering the entire screen) with the flashlight technique in order to see any image on-screen.
Mar 24, 2011 | Xerox XG-91D 19" LCD Monitor
Olympus Fe-4000 screen is completely black no image available
Stephan is exactly right. I have a FE-4000 and the LCD screen is most likely dead. As Stephan said, the screen should be replaced by a professional.
Cheers to all
dmklunk122
Dec 16, 2009 | Olympus FE-4000 Digital Camera
Dark area on screen.
i have had the same problem with the dark patch and found out it was because i had a speaker sat too close to the tv!!!
Apr 04, 2009 | Maxent MX-26X3 Television
The screen went dark on jmv 111
Dark as in gone or dark as in the image is still viewable?  How does the onscreen menu look when the image is dark/gone?  If the onscreen menu looks right and the image is still dark, you might want to check the cables or another input.  If another device using different cables and another input looks fine, you may only have a problem with the input/cable you are using to view the movie.  If the onscreen menu is also dark, then I would think there is an internal problem that needs looking into.
Mar 23, 2009 | Jensen Car Audio & Video
Dark unreadable screen
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 13, 2009 | HP Pavilion dv6000z Notebook
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Nov 27, 2007 | Acer Aspire 3000 Notebook
DARK HORIZON AREA AT TOP OF SCREEN
not sure but you could have a bad color wheel i would suggest a service call from your local shop
Jun 07, 2006 | Samsung DLP HL-P5663W 56" TV
Adjust the brightness of the screen using the Settings menu. Make sure the Solar Assist is disabled if you are not in bright sunlight.
Sep 13, 2005 | Epson PhotoPC 850Z Digital Camera
Open Questions:
I just bought an Epson 650 digital camera. I know, it's not new and fancy, but it's all I could afford right now. I bought this one (from ebay) mainly because my daughter has the same one- she bought several years ago, for around$350. I've noticed what big, clear, detailed pictures it takes (she sends to me). She resizes the pictures smaller, but the resolution on hers is 144. she uses one of the "better" settings, not the standard and not the BEST. What I've noticed with mine is, the resolution is 75 and the pictures don' tseem as clear and detailed. This might be partially because the scenery ones I've taken are of SNOW. I've tried using all the settings, even the very best, which only takes 3 pictures. The resolution is still 75. The picture size is big, 15"X 11". They are JPEG. I tried using he HotShots software that came with it, and now use Paint Shop Pro 7, with AQUIRE (Twain). I tried using the memory card in the USB cable that came with it, but it seemed to be clashing with my CD burner, which is in the other USB port. It's just as easy to use the camera and serial port and PSP. My daughter doesn't know much about it, she just takes the pictures and then takes them off. Hers have always been 144 resolution. I'm not saying the pictures on mine aren't good, and they're better than the Kodak DC 3200 I've had for over a year. Just that they don't seem as good as my daughter's, and it's the exact same camera. Could it be the memory (flashcard) that sets the resolution of the pictures? I have the original 8 MB one that came with the camera and my daughter once bought a bigger one. I know I can change the resolution in PSP to something higher if I want. I've been trying to find out what decides what the resolution of the pictures (when taken off the camera) might be? I can't find anything in the directions book about the settings for this. Just the "standard, better, best and extra fine". But, they all take pictures with 75 resolution.
Feb 27, 2017 | Epson PhotoPC 650 Digital Camera
Epson PhotoPC 650 Digital Camera Logo
71 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Terry Herrera
Harrie
Are you an Epson Camera Expert? Answer questions, earn points and help others
