Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Kenmore Vacuum model #116.25813508
I'm having the same problem where the canister won't shut off (model #116.25813508). You mention it is probably a relay mounted in the motor compartment sticking in the on position. I can't find a part with that description on the WWW.SEARSPARTSDIRECT.COM website.
Can you help me?
    President:
  • 1,673 Answers
In yours there is a pcb asm, #KC86WBZRZ000 , you probably need to replace it.
Posted on Sep 01, 2008
Sears canister vacuum rear wheel won't stay on
1) test the power cord for open, defective, or break use the VOM
2) test the fuse for open, loose wire use the VOM
3( tes the motor, for open, short, or defective, need repair.
4)test the switch, for open, or loose wires, or short.
see how to do it.
God bless you
Jul 10, 2012 | Kenmore 23612 Progressive PowerMate Bagged...
Bag full vacuum shut off. Is there a reset
You didn't mention the model, but with several Electrolux canister models, I'd say there's probably a problem with the control valve assembly inside the canister. This would need to be repaired at an authorized Aerus Electrolux store. If unsure where the nearest store is, use this link to locate one:
http://www.aerushome.com/storelocator/
The tip on the following link covers other possible causes.
http://www.fixya.com/support/r7367127-electrolux_epic_6500_trouble_shooting
Jan 06, 2011 | Electrolux Epic 6500 Vacuum
Model 116 Kenmore vacuum cleaner. 20+ years old,
Greetings,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Mar 21, 2010 | Vacuums
Vacuum will not shut-off
if it has a foot pedal flick it a few times and see if it goes off.if its a switch unplug the vacuum and move the switch from on to off real fast a few time.if you have any contact cleaner you can try to spray a little into the switch while unplugged and work the switch back and forth a few times .the switch might just be dirty.if you don't hear a click when you turn it ioff and on then the switch is probably bad.please leave feedback.i hope i was some help to you
Mar 30, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Need to know if a replacement part can be purchased and where
Kenmore canisters are privately labeled Panasonic canisters and sometimes panasonic parts will fit them. Any reputable independent dealer should be able to tell you if the part you're looking for is intercharngable with a Panasonic, but he/she will probably need to actually see the unit.
Your other option is to take it to the Sears service dept. They are the only ones who have access to the schematics and "Kenmore" parts. It'll probably be more expensive through them though.
Dec 02, 2008 | Kenmore 22812 Bagged Canister Vacuum
Lid will not snap shut over vac bag on kenmore magic clue
You have probably closed it by now :-) but when this happened to us we found that if we opened the tool compartment on the lid, the main lid then closed on the bag with a tiny bit of jiggling around. I don't know why, but this worked.
Nov 30, 2008 | Kenmore Vacuums
VACUUM WON'T SHUT OFF
Most likely the pcb in the cannister is bad, part # KC86WBZRZ000
Sep 01, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Can't figure out how to replace the bag
Open the hood, bag #20-50557 , the cardboard part goes in the bag holder, will only fit in one direction, then close the hood.
May 03, 2008 | Kenmore 22812 Bagged Canister Vacuum
Kenmore model 116 25615506
The "vacuum won't shut off" problem is caused by a faulty triac (electronic component) on the P.C.B. assembly. You have two choices, depending on your handiness:
  1. Easiest: Replace the PCB: P.N.=KC86WBZRZ000
  2. More difficult: Replace the triac: P.N.=BTA16-600CW (ST Microelectronics): http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00002265.pdf
The PCB costs about $25.00 from Sears, whereas the triac costs about $1.50. Sears will not sell the triac - you'll have to find an electronics parts supplier.
You can sometimes find the PCB from a 3rd-party supplier. For example, this one on EBay: Mel-Co KC86WBZRZ000
Sep 24, 2006 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
317 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
