Question about Garden
Stalling Briggs & Stratton engine
I have a 2006 Yard Machines riding lawn mower model # 13B771G729
SN: 1C306B70480 502cc (17.5 hp Briggs & Strat engine, single cylinder), that out of the blue started to stall. The engine starts, but stalls as though about to quit then picks up revs again.
Initially, the problem seemed to subside if I engaged the blade. After a while though, it started the stalling while even with the blade engaged.
Most recently, I've stopped using it because the engine started to cough and backfire.
I have checked the fuel (clean, & fresh), removed the fuel line at the carb and it flows unobstructed through the inline filter. All electrical connections seem to be tight. Removed the spark plug and it appears to be burning clean.
Any ideas what the problem may be? Where can I get my hands on a shop manual for this particular riding lawn mower?
Any ideas, help or suggestions will be welcome. I'm stomped!
  • vivomilagro Sep 03, 2008
    babeegirl78: Thanks, I'll tear the carb down, clean and re-set as you said, but It'll be a blindfold job cause I don't have the manual.
    I'll just make sure to take plenty of notes when tearing it down so as to make sure everything is put back in its proper place & sequence.
    I'll let you know how it goes...
  • 3 Answers
First thing to try is drain all the gas and replace with fresh gas . Then change the spark plug and I will bet that takes care of it.....joedog
Posted on Feb 26, 2009
Try taking the air filter off ,start the motor and try it. If this works replace air cleaner element
Posted on Oct 05, 2008
  • 18 Answers
Carbeurator needs torn apart..cleaned and reset.
Posted on Sep 03, 2008
Briggs and Stratton 17 HP Riding Mower
Hi Lawrence.
There should be a few more numbers/ letters to your model number. I added a link to a website for you to check out. Click the link or copy and paste it. Hope this helps.
May 30, 2017 | Briggs & Stratton Garden
20hp Briggs head torque specs
The following site details te Torque Specs for the 20hp Briggs.
Oct 02, 2011 | Yard Machines 155 Torque Briggs Stratton...
You probably have in your area a number of small engine repair shops. You will have to get on the phone and start calling around for a used mower deck. They usually have many old mowers in there yards. If you decide you only want new it could be very costly. GOOD LUCK.
Jun 30, 2011 | Yard Machines 155 Torque Briggs Stratton...
Getting to float
take off the carb, then unscrew that big screw on the bottom. the float is in there
Jun 12, 2010 | Yard Machines 155 Torque Briggs Stratton...
Need to locate lawn mower ID No on a Briggs and Stratton lawn mower
The Model number for the Lawn Mower should be located under the seat or on the underside of the hood. The Model number for the engine should be on the top shroud usually in the front or above the carb.
May 03, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
17 HP Briggs & Str lawn mower engine that is smoking a lot -
compression test it can either rent or buy one should be over 90psi!!!
Jun 28, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
726 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
