Question about RCA P52926 52" Rear Projection Television
HD56W58 rear projection tv started snapping and popping with a high pitched squeal then went dead
Our TV started making a popping and snapping sound along with a high pitched squeal then went dead. I turned it off and it smelled hot then it turned itself back on and continued with the noises. I had to unplug it for fear it was going to blow up.
Is this fixable or is it dead?
Posted on Sep 03, 2008
    Genius:
  • 2,920 Answers
You have a shorted out power supply and probably some blown resistors
Posted on Sep 02, 2008
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
I can turn the set on but it doesnt put out any picture,and it makes a high pitched ringing sound
Ur high voltage is dead,the FBT the big block of plastic with a red wire hook to a board.That thing is dead.U know how to solders,Website, Tv repair World.com buy the part.
Nov 13, 2009 | RCA HD56W58 56" HDTV
Sony rear proj; kdf 55
If there is no picture but sound is audible then replacing the projection lamp will do otherwise, the TV requires to be diagnosed for any other hardware damages.
Aug 27, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Same problem, high pitched noise over regular sound and no pictur
No guarantees with this diagnosis. But it sounds like an HT ( high tension) leak This is often caused by the lead becoming partly unplugged ( being bumped or moved) and because of dust buildup it arcs making a high pitched hissing whistle.Ther lamp may also have been affected by the HT leak. The safest option for you is to call a service technician to it, as opening it up could cosntitute a a danger to the unskilled.
Aug 12, 2009 | RCA HD56W58 56" TV
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
NO PIC HIGH PITCH SQUEAL COMING FORM BACK BOTTEM PART OF TV?
Squealing sound means you have something shorted in high voltage area around FBT on Power/deflection board.UED has replacement boards & Misc Parts for these sets if in stock call them1- 800-648-6657
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD56W58
RCA HD56W58 Rear Projection TV quit today. Resistor burnt up r14705. Power light goes on and high pitched noise but no picture or sound.
Nov 09, 2008 | RCA HD56W66 56" HDTV
High Pitch Sounds
In this model the horizontal drive coil vibrates and makes a high pitch squeal. Most times it is intermitent. Touching on the coil with something (non electrical, like wood) will make it stop or change it's pitch. The fix my shop uses: It's not to technical, but, we put fingernail polish around the coil. It's a remedy I've used for decades and has always worked. Some shops use a hot glue gun. With the back open you can hear the coil to locate it. When fixing the problem have the set unplugged. When a technician is working on a television while it's plugged in. He uses only one hand and stays away from the high voltage.
Jun 25, 2007 | RCA HD52W59 HDTV Projection Television
RCA P52926 52" Rear Projection Television Logo
139 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
