Question about Kodak DCS 14n Digital Camera
Color Problems I have currently been using a Kodak 14n at my current job and have noticed something rather strange. With every picture I take, the photo has an deep magenta cast. In photoshop 7 I adjust the color either by using autocolor or by manual color adjustment. After getting the color a close as I can, I notice that there are faint sections of color vertically across the picture. One third is slightly green, the middle third is yellow, and the right third is magenta. So basically I have two problems I need help with, the Magenta cast on the original picture, and the color stripes after color correction. If anyone knows what is causing this, or has experienced this themselves, please let me know.
    Sergeant:
  • 255 Answers
I know this contribution might be late, but try to avoid using the auto white balance. Use a tungsten mode and test each of its compensations until you get the desired result. I haven't had a similar problem on the 14n, but my D100 always places a magenta cast on white when shooting auto WB. I learned how to adapt the other WB modes to any situation.
Posted on Sep 13, 2005
SOURCE:
Kodak scanner i3400 error e73
e73 is A USB command failure. Check to see if the scanner is connected to a USB 3 port. A USB 3 port can be identified by the port being Blue in color or have the letters "SS" (Super Speed) near the port. Kodak scanners behave strangely with USB 3. With the unit turned off, please connect the scanner to a USB 2.0 port. Additionally, download and install (as an administrator) the most current drivers from Kodak.com which alleviates 9 out of 10 issues.
Apr 04, 2014 | Kodak Office Equipment & Supplies
Convert a n80 35 mm film camera to digital, can it be done ?
Yes, it can be done. Kodak did it to create the 14n and Fujifilm did it to create the S2. It probably cost them millions of dollars in R&D to do it, and the resulting cameras cost in the thousands.
If you want to do it yourself, it's not going to be easy or cheap. Unless you can make the chips yourself, you'd have to cannibalize another digital camera. Then you'd have to design the internal layout, position the parts properly, and so forth.
It would be a lot cheaper and easier to just buy a new D3200 or D5200, or a used D80 or D90.
Feb 20, 2013 | Nikon N80 35mm SLR Camera
Streaks like little roots or little tree branch on my pictures
is this not a problem with your lens rather than PC - best was to check is to take two separate BLACK (if white marks) or vice versa, pictures and see if the "tree" is on exactly the same place on all pictures
good luck.
Jan 30, 2013 | Kodak DCS 14n Digital Camera
Hello, pleas I need service manual for Kodak DCS
HelloUnfortunately, the service manual for your Kodak DCS 14n is not available anywhere online. The manufacturers of this product did not make it available.
I would suggest you contact Kodak and request for the manual from them. They might give it to you or direct you to a dealer where you can get the manual.
Here is a direct link to Kodak's DCS 14n digital camera support page :
http://www.kodak.com/global/en/service/professional/..
To view the page just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
Jan 19, 2012 | Kodak DCS 14n Digital Camera
Hello! I'm about to get my self a Kodak DCS 14/n. I found one with a slight problem, it won't take any pictures. According to teh description the camera works fine in all menues, focusing and...
Are you serious!!! This camera does not "work fine". It does not have a "slight problem". IT WON'T TAKE ANY PICTURES!!! Do not buy this camera.
May 02, 2011 | Kodak DCS 14n Digital Camera
What is the largest mb sd card the kodak dcs pro 14n will read ??
Hello!
Seems the DCS PRO/n do not handel SD cards with HC capabilitys. So the largest SD cars that there is i 4GB. Problems is to find such a card.
In reallity 2GB is possible.
I recomend You to obtain a CF card instead. I use a 16GB CF and it work like a charm.
I suppose the DCS 14/n work the same way.
Regards PeO
Sep 25, 2010 | Kodak DCS 14n Digital Camera
HD70 DLP Projector: The projector is used and about a year old. It cur...
Did this start occurring after you replaced the lamp?
The reason I ask is I had the same issue after changing the lamp and it was caused because when I took out the old lamp I noticed dust in the lamp housing which I attempted to blow away.
This caused the problem because some dust got further into the projector, specifically around the color wheel. I sorted it out by taking the projector apart following the instructions here:
http://tantht.blogspot.com/2009/02/how-to-remove-dust-blobs-from-optoma.html
(note my HD70 was out of warranty, if yours is not, I would recommend contacting Optoma to get it fixed).
Follow the above instructions to step 14 and then locate the color wheel which is at the front of the projector behind a dark gray, plastic type square shaped cover.
You have to be very careful here, but remove the color wheel (there is one screw holding it in place) - note it
May 18, 2010 | Optoma HD70 DLP Projector
Kodak DCS 14n freezes, capture error, or forgets firmware version
Did you ever solve the problem? I had the same problems; the Kodak is still lyng around since 2-3 years. I bought a Nikon D3 instead but I'm not satisfied about the colours and the brightness of the D3. I'm seriously thinking about either repaairing my Kodak or buyin one again...
Jun 22, 2008 | Kodak DCS 14n Digital Camera
Resolution Problem
If you are shooting with it on Jpeg that is about the correct size for you file. Even on Jpeg it should look way better then the S1 if not someting is wrong for sure. what are you exact settings.
Sep 13, 2005 | Kodak DCS 14n Digital Camera
Kodak DCS 14n Digital Camera Logo
163 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
