Question about Panasonic DVD-LS90 Portable DVD Player
Broken my daughter dropped our dvd player and the joint which attaches the screen broke.  Within that joint was the flat video cable tape which was pinched in the process. I need to get it repaired.  Suggestions? thanks andrew
    Sergeant:
  • 291 Answers
See if there is a break in the ribbon cable.Place a light behind the ' ribbon ' so that you can see the the wires in the tape. If you see a break in the wire inside the ' ribbon ', you will have to ' jump ' the break with a wire soldered to each side of the break. You must strip ( vary carefully ) the plastic on EACH SIDE OF THE BREAK to reach the metel conduct. If you can, strip the plastic or melt it over the break and ' dap ' it with solder to reconnect the break.
Be careful because the ribbon with the electrical cable inside is very thin and fragil
Posted on Nov 07, 2008
How can I watch my video tapes from my sony handycam when touch screen is broken?
you can use the s-video cable for connecting it to tv if the camera has a s-video port.
alternatively you can download the software from sony website for your handycam which can convert the video from the tape into a CD/DVD. You can then watch them on tv using your DVD/CD Player. if you do this you need to ensure that the video is captured in same mode as your TV NTSC or PAL)
Apr 11, 2012 | Sony DCR-HC26 Mini DV Digital Camcorder
I brought my daughter a dora the explorer tv/dvd combo dte313 and she broke her remote so im not able to switch from tv to video or get all the cable channels. what should i do?
Hello and thanks for using Fixya.com ..Most remotes are able to withstand droppage .If remote was dropped and if your kinda handy.You can try to pry open the remote .Lots of remote have simple issues like ,bad solder joints battery terminal bad .If not the other option id to take remote to a local tv shop and ask if they can try to fix it .This will usually cost you a few dollars.But this is better than ordering a new remote.Last option would be to order a remote or try to find a universal remote that will work with your set..Goodluck
Sep 25, 2011 | Emerson Dora The Explorer DVD Player
Sylvania (SRD3900) DVD Player / VCR Combo i can't seem to plug in the red/white/yellow cables into the right places directly to my old toshiba tv to play either tapes or dvds. can you instruct me? thanks.
Greetings - It's very simple so I'll show you how and then I think it may be another problem (nothing broken).
You need to plug the corresponding color cables into to outputs on your player I've circled above and then into the corresponding inputs on the TV. You've probably done this correctly.
PLUS - You have to, using the remote for the player, set the source to either DVD or VCR and then you have to, finally, on your TV set the input (with the remote) to what is called probably VIDEO or VIDEO1. If there is still nothing on the screen keep (with the DVD or Tape playing) hitting the TV remote input button until you see an image or you've come around to where you started.
Unless something is broken (unlikely) you should be able to watch DVD's or Tapes depending on what input you select on the player.
If it's not working you've somehow missed a step or the Video input on the TV is called something else. If that happens come back here and give the player AND TV brand/model info and someone will be able resolve your problem.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 21, 2011 | Sylvania (SRDD495) DVD Player/VCR
I have USB cable attached to tv and DVD player and
Connect the DVD to TV with HDMI or component video, don't use USB, USB on the TV is to insert a flashdrive/thumb drive to display a slideshow or download music.
Good Luck !
Mar 22, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
I have the TruTech LMD-5702RT Portable DVD Player. The auxilary screen has no picture when it is plugged in. It has sound, but no picture. The brightness adjustment will still take the screen from light to...
The cable that connects the two is a 4 pole cable, which means that some of the poles are used for video and others for audio (stereo left and right). My kids broke the cable within a week of having the device and I had to bend the cable back and forth to get a picture to show up. I finally ordered a new cable from here: http://www.techcables.com/6-ft-3-5mm-4-pole-mini-av-to-mini-av-camcorder-a-v-cable-p-36.html
Nov 17, 2009 | TruTech LMD-5702RT Portable DVD Player
Looking for cord to connect main unit to 2nd screen.
go to www,18002526123.com they sell accessories and replacement parts for this system
Jan 07, 2009 | Durabrand Two Screen Car DVD Player
Need to swop lcd screen inside of my nw-hd1 , I have broken off the solders but at the bottom is like tape and don"t know have to remove it from broken screen
1,took case apart
2, broke off solders
nw-hd1.
3, tried to remove screen but (cn5001) is still attached.
from gary tauber
Oct 10, 2008 | Sony NW-HD1 MP3 Player
CyberHome CH-LDV 700B Portable DVD Player
you've probably over extended the the flat wirecable that powers the screen inside the dvd player by opening the screen too far. Open the dvd player as if putting in a dvd, now look in the right hand upper corner and you'll see a white flat wire, this wire is probably your problem. open the dvd player and look at the connection, the wire should be crooked, push the wire into the connection securely and the screen should come on. check it out!! Mr.Fixright.
Aug 08, 2007 | Cyberhome CH-LDV 700B Portable DVD Player
Panasonic DVD-LS90 Portable DVD Player Logo
210 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
