Question about HP Media Center PC 873n (P9875A#ABA) PC Desktop
Hp media center pc 873n
Won't power up soild green light on back of tower small yellow battery light in front thats it Please help
  • 38 Answers
You might need to open the case and make sure that the wires going from the power button are actually connected to the motherboard.
Posted on Jan 31, 2009
I just purchsed a hp 873n pc tower is that wifi ready
No, according to the data below. You can buy a PCI wifi card or a wifi usb from Frys or even Walmart.
Take care WBTech Product Details Discover the ultimate in entertainment with new power and convenience of the HP Media Center PC 873n. Watch or record your favorite TV programs - even pause live TV, instantly replay or skip commercials. Create a slideshow of your family photos, add music and set it to play on your PC during a holiday party. Save your original videos, photos, music or data on DVD+RW/+R or CD-RW discs. Specifications Key Features Operating System Microsoft Windows XP Media Center Edition Form Factor Tower Processor Intel Pentium 4 2.53 GHz Installed Memory 512 MB (DDR SDRAM) Recommended Use Home Use Processor Processor Type Intel Pentium 4 Processor Speed 2.53 GHz Processor Manufacturer Intel Max Processors Qty. 1 Motherboard Bus Speed 533 MHz Video Output Interface AGP 4x Memory RAM Technology DDR SDRAM Installed RAM 512 MB Installed Cache Memory 512 KB Max Supported RAM 2 GB Installed Video Memory 64 MB Hard Drive Hard Drive Capacity 120 GB CD / DVD Optical Drive Type DVD+RW Optical Drive Read Speed 2x (DVD) · 32x (CD) · 8x (DVD) Optical Drive Write Speed 12x (CD-R) Optical Drive ReWrite Speed 10x (CD-RW) · 2.4x (DVD+RW) Other Drives Floppy Drive 3.5" 1.44 MB floppy Audio / Video Audio Output Type Sound Card Video Input Type TV Tuner Modem Modem Type Fax / Modem Networking Data Link Protocol Ethernet · Fast Ethernet Networking Type Network Adapter Dimensions Depth 15.52 in. Height 15.25 in. Width 8.27 in. Weight 35.06 lb. Warranty Warranty 1 Year
Jan 21, 2010 | HP Media Center PC 873n (P9875A#ABA) PC...
My HP Media Center m7330n won't power up... The fan comes on but will not boot.. The LED power light blinks at 3 second intervals from blue to yellow/orange.. What is the diagnosis...
You have to check with your RAM sir, if you know to remove the side cover of your CPU(tower) there will be a green colored chip fixed in vertical position in the motherboard if remove it and then fix it properly means you will get the display in yur screen.i will show you the RAM picture2f70f69.jpg
Oct 29, 2009 | HP Pavilion Media Center TV m7330n...
Hp media center m8000 was freezing so did a manual reboot, now it will not turn on
Try unplugging it and plugging it back in. If then you get no power try plugging it into the wall directly and check the power cord unplug it and plug it back in (From the back of the PC). When you press the power button put your ear to the PC and listen for a metallic click. Most PC's use a small micro switch to tun the power on and off but they do make a small noise if you listen.
If all this does not work the power supply is probably bad. If it is under warranty then send it in. If it is not under warranty you can replace it yourself all you need is a half hour and screw driver. From the picture above it looks like a regular tower so any ATX power supply will do.
But if you are not the get your hands dirty type any pc tech place can replace it for you and should only charge you $40 for labor plus $20 to $40 for the Power supply itself. By the way when shopping for a power supply you do not need that 1000w with the flashing neon lights. Get one that is around 700w look at the fan I personally would spend the extra money to get one with a large 4 inch fan with lots of air flow money worth spent in my book. The large fan can get more air flow for a cooler pc and since the fins are larger it can do it with less RPMs so you have a quiet little box in your corner.
Hope this was helpful
Sep 14, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
I don't remember where all the connections (Power led, sw led, etc.) attach to the motherboard of my HP media center pc 873n. Is there a diagram of the motherboard that shows exactly where everything...
I am not familiar with your exact motherboard, but most commonly, the front panel connectors themselves usually have white print labeling them, and on the motherboard, similar fine white markings will be next to the appropriate pins. This is not always the case, but the front panel pins on the motherboard are usually located near the bottom right hand corner.
Jun 09, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
I reformatted my hp pc and I don't have any audio sound.
here are the drivers for your hp 873n (us)
you will need alteast the sound card drivers to get sound, I suggest you get everything else also to get everything to work properly.
Let me know if you need anything else.
Feb 25, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
How to open up my tower to blow out the dust
Should be screws on the back of tower to take the whole top off or screws down left side back to take the left side off.If one side can come off after screws are taken out you will slide side back to remove.
God Bless Greg
Nov 23, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
HP Media Center PC 873n (P9875A#ABA) PC Desktop Logo
200 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
