Question about Brother MFC 210C All-In-One InkJet Printer
Printer cartridge i simply dont know how to insert the ink cartridge how is it done
  • kohr7 Sep 04, 2008
    I inserted a new yellow cartridge but keep getting the message "cartridge not inserted" and no matter what I do, I can't get it to work. Any Advice?
  • 79 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} See page 143 of the manual for instructions on replacing the print cartridge. http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Posted on Sep 02, 2008
Does not print evenly. Some lines are very faint. Have done calibration and cleaned print head several times. Prints from internet and e-mails okay. But does print from Simply Accounting, tax software...
Welcome to FixYa.
Since you have already performed calibration and cleaned the printhead, kindly verify that the ink cartridges are not damaged and are completely seated in the printhead:
1. Lift the printer access door, then remove the ink cartridges from the printhead.
2. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
3. Verify that the KODAK Ink Cartridges have not been refilled.
4. Insert the black ink cartridge into the printhead, then press down firmly until you hear it click into position.
5. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
6. Close the printer access door.
7. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
NOTE: When the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
8.Reprint the original picture or document that had the quality problem.
Hope this helps. Thanks for using FixYa.
Dec 15, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
My printer says it has an ink system failure. I dont know what to do it tells me to turn it off then back on and thats what i do but the same thing keeps happening. I dont know what to do with it.
This printer has separate ink cartridges and printheads. Below the place where the ink cartridges are inserted is the ink system. It has a small PCB on it that holds optron sensors that can sense whenever a cartridge is empty. If there is a ink leakage from a refilled cartridge, the ink goes on that PCB and literally eat the copper conductors. It make also shortages and burns to SMD mounted electronic elements. This PCB is part of the entire ink system, that includes the plastic holder for the cartridges, a motor that drives the pumps and the pumping mechanics.
Open the printer, take that PCB out and give it a good alcohol clean. Then dry it well with compressed air. Test it whether it works. Replace the entire ink station if it doesn't.
Aug 15, 2010 | Office Equipment & Supplies
Showing Check Ink U051 COL. Have removed the
Hi there
For troubleshooting purposes,
Perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Canon PIXMA MX310 All-In-One Printer
At last changed ink cartridges with make always used now epson are saying dont recognise so now printer not working at all
just try to remove and re-insert the cartridge in a way that you get a click sound in the printer. it means you have done the job completely. (or)
try re-installing the software .
i am assuming you are using the original epson cartridges.
Dec 29, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson printer says "cannot recognize ink cartridges".
Are you using genuine epson cartridges? Many generics simply dont work on the newer printers. Once the printer decides the cartridge is empty, it sends a signal to the chip and that's it. You might hear ink, but if the chip says empty you can't use it. It also has the annoying habit of doing this when there's still 10-15% of the ink left.
I use reusable cartridges from http://www.ccs-digital.com They hold 2/3 more ink and the chips automatically reset to full if you remove and re-insert the cartridge. Instead of replacing the entire cartridge when it's empty, you pop out an internal ink tank and replace just that. So you know the chip has already been recognized by your printer. The ink tanks cost under $3. I think these are a brilliant invention.
Jul 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
Dont know how to change colour cartridges
Turn the printer on and open the lid. After a short while, the printer carriage unit containing the print head and ink cartridges will stop right in the middle of the printer, so you can easily replace the ink cartridges. After replacing them and ensuring they're fully seated, simply close the lid. The printer will run a few quick self-diagnostic checks and run a purge cycle, and it'll be good to go.
May 16, 2009 | Canon Office Equipment & Supplies
I loaded the black ink like I have done so many times before, but a window is coming up saying it does not recognize my color catridge and will not print. I dont even have a color cartridge in the printer.
Some printers will not print while missing either of the cartridges, was the printer working without the colour cartridge before?
Try inserting a colour cartridge and see if that helps.
Dec 09, 2008 | Canon PIXMA iP1600 Printer
Trouble installing black ink cartridge #27.
there are two cartridges, the right side is always the black ink w/c is 27 simply tilt the cartridge while putting it towards the unit, once you have inserted the unit push the ink to latch onto the assembly,this should be easy without any difficulty unless you have inserted on a wrong latch, let me know if you stil have a prob
cheers
Dec 04, 2008 | HP Officejet 5610 All-In-One InkJet...
Bought compatible ink
It's likely the chip. They can evidently get confused like the rest of us! Previous fixes were to replace the driver. No luck with me so I did what I was told by an idependant printer engineer and simply replace the offending colour cartridge. Hey Presto. Fortunately I was using Canons inks and they are going to replace it.
Jan 18, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Incorrect ink level reading
kiwipom, While ink cartridges look like plastic cups that only hold ink...they are not. The information the printer needs to think it has a "NEW" set of ink cartridges is on the cartridge itself. You must fakeout the printer to believe you are inserting "new lexmark" inks. Printer companies make money from the repeated sale of the ink, not the printer itself. I had an old epson that I would refill I would then have to place pieces of tape on the cartridge turn the printer on, remove the cartridge move the tape to another side of the cartridge turn on again etc. Anyway lexmark may need the same. When the new original cartridges show try them first to get the printer "thinking" correctly. Let me know what happens. Good Luck, Tim
Feb 27, 2007 | Lexmark X7350 All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
23 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
