Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Whats with my tv?
Hey I have a 52 inch Mitsubishi DLP one day it just decided to just show a screen of little tiny black and white checkers,the sound comes on and for what I can tell the remote works, I have changed inputs, but still the same thing, I even tried resetting the whole tv do you have any idea what could be causing this?
  • xx007xx Sep 02, 2008
    I get the cheker board screen and got talking on a tech forum and most of the
    problems folks are having with them are due to faulty Capacitors, I
    dissassembled the whole tv and found two swollen out Caps on the
    formatting board and the power supply, I am ordering the Caps and also
    I came across a symptom and cure ilustration with a picture(see
    attached) of what to check, of the four things that I checked visually
    two teenee tiny diodes looked like they were fried, it is like they
    barfed some dark brown stuff out, I am in the process of ordering those
    parts too I know that the D8F00 and the D8F01 are diodes, but I dont know what the other two are and if they have a certain way that they are soldered in(is there a certain direction such as pos and neg)
    I have nevered soldered tiney things like this but I am sure that I can if I get a microsoldering tip and watch my heat carefully as I solder
  • jimhubbard10 Apr 02, 2009
    I also have chekerboard screen on wd-52525. How do I order parts , diodes and caps suggest by Big Irish with such little part description. I'm assuming the part numbers listed are Mitsubishi PN's. I cannot find any cross listings on these to order from , say, B & D Enterprises. Can anyone help??
    Thanks,
    Jim Hubbard
    jimhubbard100@gmail.com
    Problem Solver:
I have the same problem, if you still have the problem try to check the signal board too it to can cause the checker block on the screen..ps cal pts corp they said to repair th fmt board is 154.27, the signal board is 227.85, but pts corp said it is best to send all the boards for 309.50......
Posted on Sep 23, 2008
Oooops I posted as a guest.....sorry
Hey those silly diodes and caps were WAY too tiny, I just went ahead and sent the whole board in and am in the process of changing out other capacitor diodes on the power supply that are starting to look like they are bloating out as well, those large capacitors I can handle soldering but those tiny diodes and Caps look like a pain in the but to replace and best left to the professionals.......thanks, James
  • 927 Answers
Good Day;
Replace all caps that are swollen, but resolve your checker pattern:
1. Tile or block pattern replace D8F00 and D8F01 part # 264P828010, also replace C8F26 and C8F29 part # 141P148000 (1 uFD, 25 V) on the FMT PCB (part # 930B924002).
The diodes have a stripe (line) that is the cathode, at one end of the device, the board will reflect that line. Good Luck, big IRISH. PS ; De solder as best as you can, glue is under part, heat one end, while prying up, heat other end. It will come off with moderate to mid high heat.
I have a big screen tv and little tiny white specks are starting to come behind the screen. What is causing this?
There is a fault with the light engine.one of the chips in it is faulty .there is a you tube video showing the fix.unfortunately the chips cost around 150 pound.
Oct 19, 2014 | MITSUBISHI DIGITAL ELECTRONICS MITSUBISHI...
Little white dots in tv modle# wdt657 what are they how can i get them off
Your TV is DLP projection TV. DLP is Digital Light Processing. Digitally processed light coming out of DMD (Digital Micro mirror Device) is projected on the TV screen. This DMD is made of thousands of tiny mirrors & the size is about 0.7 inch. These mirrors are fixed with tiny hinges for its movement. They reflect light as per processed signal. DLP is invented by Texas Instruments. When there are dots on the screen, that means the tiny mirrors representing the dots are stuck in its position. If the dots are few & the viewing is bearable, just leave as it is. If the dots are more than bearable then you will have replace the DMD chip which is quite costly.
Sep 25, 2011 | Mitsubishi WD-Y657 65" HDTV
I have a 52 inch mitsubishi dlp and white dots are popping up on the sceen and stays there a whole bunch of little white dots what is that.
All TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables.
If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen.
Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens.
The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them.
Good luck.
Jul 18, 2011 | Mitsubishi Televison & Video
I have white and black spots on my 65in hd1080p what is it tv is on 2 years old
Hi, I have a mitsubishi 65" DLP model # 65733 that I bought in December 2007 brand new, about six months ago I started spoting white dots on my screen that started blinking and then became permanent, thinking is was dust I cleaned everything inside with compressed air without success.
The stars multiply daily to a point that it was intolerable to watch anything with all the white stars and a few black ones that showed up.
We called mitsubishi but got no where, I was out of warranty. (they still deny having a problem with their DLP's)
I had a service tech inspect the tv and was told it could run about $800 to $1000 to replace the light engine with refurbished parts with 90 day warranties.
Researching on line I came across a DLP chip that is compatible with several mitsubishi and samsung models, so I decided to chance it, and replace just the DMD chip before we trash the tv, it was unthinkable to pay $800 to repair a tv that we could buy now for under $900.
Thanks God the "gamble" paid out and the problem got solve with just $150 DLP chip in about 15 minutes of my time.
If you are not mechanically nor electronically inclined, I recommend you use a technician for the installation, but don't let anyone tell you you need to replace the whole light engine, it is a ripoff.
If your problem is just white or black dots on the screen that do not move.......this will solve your problem!!
P.S. Hope this will help you and for the record..... "I will never buy a mitsubishi product again".
May 15, 2011 | Mitsubishi WD-65733 65" HDTV
Verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP 65 in half of screen is tinted yellow - 3 mth old
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD, DLP & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 26, 2017 | Mitsubishi WS-65857 65" Rear Projection...
Black Screen with White Randomized Pixels
Bad FMT (Formatter) circuit board. No longer available for purchase from Mitsubishi.
The electrical chassis will need to be sent to Mitsubishi for rebuild.
Wait time: 4-8 weeks
Cost (including labor to uninstall it and reinstall it: $800 +)
Nov 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Black/white checker pattern on screen. Sound okay
Sounds to me that the menu is in convergence adjustment mode. Try the menu key on the remote and follow the prompts.
Oct 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
248 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
