Question about LG LMV1630ST Microwave Oven
LMV1630st sparked and then stopped working.
Last night I was defrosting an item. I open the door to check if it was done. When I pressed clear / stop, a spark came from the right side of the cooking area. The microwave went completely dead. Nothing works now. It tripped the breaker. I reset the breaker and still nothing works.
  • 706 Answers
please use this link to view another servicemans explanaton of what your problem is and hopw to address. In essence, you should ALWAYs press the stop button before opening the door... Hope this helps you...
Posted on Sep 01, 2008
This microwave was working perfectly last night and doesn't even look like it has power today. We have done nothing to it. Please help. It is a Kenmore 721.62624200.
First, check to see if the circuit breaker has tripped. Then check to make sure it is firmly plugged in to the outlet. After that, it is time for a technician.
Feb 24, 2015 | Kenmore Microwave Ovens
How do I unlock the key panel
Opening the door while the oven is cooking will greatly shorten the life of the door switches and lead to failure.
Always hit "Stop" first unless the recipe calls for it.
The instructions for the child lock are in the owner's manual.
To set the lock, press Stop/Clear, then hold the "0" pad for more than four seconds. You will hear two beeps and the display will show "LOCKED".
To unlock, hold the "0" pad for more than four seconds. You will hear two beeps and the display will no longer show "LOCKED".
May 18, 2013 | LG LMVM1935 Convection/Microwave Oven
I was cleaning the outside of the mmv5165ba, after i was done, the sensor control stopped working, after a few times of pressing stop/ clear it was okay, but not all of it is working, thankfully the...
In the future be careful not to use too much liquid in exterior cleaning of the microwave. To recover what has been damaged that depends on the nature of the problem. If you had liquid seep inside the microwave during cleaning the best solution seems to be to unplug and stop using your microwave (to prevent any further shorting or electronic damage to the control panel. Give the microwave at least a couple of days to dry. If you can gently warm the affected area with a heat lamp or regular incandescent bulb of some kind, it may help to evaporate any liquid that remains. Be very careful not to melt anything by getting it too close or getting it too hot.
If this doesn't resolve the problem, it is possible that the control panel has sustained some damage and may need to be replaced... but only as a last resort.
Oct 30, 2010 | Maytag MMV5165 Microwave Oven
When I press the clock button, the microwave turns on and starts counting down from 30 seconds. The stop/clear button will not work to stop it. I have to open the door to stop it. I unplug it but it...
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
good luck .
please rate !
Mar 30, 2010 | Amana ACO1520A Microwave Oven
How do I replace a LG LMV1630ST microwave oven door handle?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Nov 23, 2009 | LG LMV1630ST Microwave Oven
Door panel falling apart
Check for parts on this unit. The door will run you about $121 item #1310935. If you just need the door frame assy. that's about $31 item#1300226. Good Luck.
Sep 25, 2009 | LG LMV1630ST Microwave Oven
Model R-1460, when I shut the door it runs but doesn't heat up. What needs to be done to fix it?
Do you mean that when you close the door, the fan comes on? If so, it sounds like a bad door switch. Probably the secondary interlock switch.
This failure is caused by opening the door when the unit is in cook mode. On ALL microwaves, not just one or two brands.......
Be sure to push the stop button before opening the door to add or stir... Or wait for the cook cycle to end. (This is why microwaves have a two step function on the stop/clear button. Hit stop once to stop cook mode and twice to reset timer).
You should use an ohm meter to check all 3 switches. The switch can be either stuck 'closed' or physically closed but not 'making' electrically.
Sep 13, 2009 | Sharp Microwave Ovens
R-209BK Sharp Microwave buttons inoperable
I had this problem too:
it turns out that it (apparently) just needed some 'warm-up' time!
After being plugged in for about 15 to 30 minutes,
the buttons suddenly "came to life"...
Note that when it's flashing 88:88 you are supposed to _start_ with the 'Stop/Clear' button. After that, set the clock (press "Clock", enter the time with the number pad, then press Clock again).
Hope that helps.
Sep 01, 2009 | Sharp R-1502 Microwave Oven
Microwave continues to run when the door is closed
Did you pressed the stop/clear button? or disconnect the micro.. for a couple of hours and try again?
Apr 04, 2009 | Microwave Ovens
It works even if I open or close the door.
if thats a microwave.. then the sensor of the closed door is broken.. thats why it worked even when open.. and that is really dangerous...
so.. your best bet would be opening it and find the broken thing that tells the microwave when its closed...
that thing is usually the little secures attach to close the oven..
if its not a microwave, the problem might still be something similar to this..
Jan 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
LG LMV1630ST Microwave Oven Logo
178 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
