Question about Samsung DVD-VR357
Need help setting up DVD-VR375 with compatible SAMSUNG TV
Using HDMI connection- VERY little instruction in user manual
    Problem Solver:
  • 11 Answers
If it has component (red, blue, green) cables, plug one set into dvd player's "in's" and tv sets "out's'. you may have to play with the tv channels to be able to watch movie. you just change channels, go from "3" backward until you find a picture and sound.
Posted on Sep 12, 2008
DVD works but not VCR
There seems to be a compatability issue, run an rca video and audio cables from the output of the vcr to the input of the tv, that should restore the video and sound.
Mar 11, 2012 | Samsung DVD-VR375 DVD Recorder/VCR
Setup DVD&VR375
Check this link
http://in.youtube.com/watch?v=C-i26YB6ttE
Sep 01, 2008 | Samsung Televison & Video
Lost users manual for sumsung P1000
Please click on the link below to be able to access the manual of your samsung dvd-vr375 recorder/vcr combot thi
The exact manual for Samsung DVD-VR375 DVD Recorder / VCR Combo is not available but this is the best manual that fits in for your Samsung DVD-VR375 DVD Recorder / VCR Combo
http://www.samsung.com/africa_en/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=501&prd_mdl_cd=DVD-VR355%2FXFA&prd_mdl_name=DVD-VR355&srchword=DVD-VR355
paste the link in the url position and download the manual.
Hope this helped.
Jun 21, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
Lost instruction maunual
You can download the detailed user manual from the following link.Please rate me as helpful if satisfied
( http://www.retrevo.com/support/Samsung-DVD-VR375-DVD-Players-manual/id/21178bh034/t/2/ )
Jun 05, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
I am trying to record with VHS from TV and not using a cable box. No results. How do I do this?
This unit doesn't have a tuner. So unless your TV can provide video out (not a common feature) to the dvd/vcr recorder, you need a tuner. A set-top tuner box for OTA would work. With a little work, you could also use a tuner (USB or PCI slot card) in a computer. Usually you need a converter box unless your video card can output in a non-RGB format. The manual for this device is available here: http://www.samsung.com/us/support/downloads/DVD-VR375 .
I wish that I could be of more help.
Oct 12, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
I have a samsung dvd recorder, whats the proper way to connect for it to work, do i connect to cable box, tv
How you connect it depends on your system. You need to connect the video out of the recorder to the TV. If you want to record programs, you need to connect the cable box to the recorder's video in. (The unit doesn't have a tuner if you have the unit listed above.)
Place the IR Blaster near the set-top box IR receiver. Connect the RF cable from the wall to your set-top box and then another RF cable from the set-top box to the TV (not to the DVD recorder). Connect a composite A/V cable from the set-top box A/V (composite) out to the DVD recorder's A/V in (AV1) port. (Composite video is a three wire cable - the plugs are yellow (video) and red/white (R/L audio).)
Next you need to connect the unit to the TV. Depending on the TV, you can use an HDMI cable (best results), component video or another composite video cable (labeled AV2 AV out). If you use component video, you'll need a separate cable to carry the audio. (Component video cables have 3 RCA jacks on each end (red, blue and green). The audio cable has the red and white plugs.
You will only get a 480 (SD) signal output if you use anything other than the HDMI cable. (The progressive scan feature is not compatible with all TVs; see the manual for details.)
You can obtain the manual from http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=DVD-VR375 .
I hope this helps.
(you have an additional A/V IN connection as well as a DV In port on the front of the unit)
Sep 12, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
No signal from samsung dvd-vr375 and tv
That means the dvd (I assume you meant dvd not vcr) needs tuning to the stations. Press menu, then select the tool box icon(or setup) and select the tuning option. Select auto tune and press go(centre button).
Give it a few minutes to tune in and away you go.
Jan 02, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
How to connect motorola cable box to samsung dvd/vcr model vr375 to a Westinghouse hdtv with 2 hdmi connections
The DVD-VR375 does not have an HDMI input. The connection should be:
• RED WHITE & YELLOW CABLE from your cable box (AV OUT) should connect to the DVD-VR375 (AV IN 1). Set the DVD-VR375 to AV 1 using the INPUT SEL. button.
• Next, connect an HDMI cable from the DVD-VR375 (HDMI OUT) to the TV (HDMI IN). Set the TV to the proper source.
This connection would allow the recorder to work as a pass through and will let you record TV programs as well as watch your cable channels.
Hope this helps!
Jul 06, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Connection cord problem from VR375 to TV set?
Page 18 of the user manual for your device shows that there are normal video (yellow) and audio (red/white) connectors underneath the A/V out column of connectors - Since your son's TV does not have an HDMI cable (all you would need if that were the case) make sure you connect the A/V out column to the RCA type inputs of your son's TV.
The manual can be found here:
http://downloadcenter.samsung.com/content/UM/200802/20080229102004125_01613A-01-VR375-XAA-ENG-BM-0228.pdf
Dec 31, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
User manual for dvd vr375
No need to buy one. Here is a link to Samsung Support for your model:
DVD-VR375 User Guide
Save it to your computer for future reference.
Dec 15, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Samsung DVD-VR357 Logo
198 people viewed this question
Jerry Greenberg
Jerry Greenberg
