Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
The router is lit up but my laptop is not picking up the internet
  • vtpeanut Nov 05, 2008
    I lost an internet connection a couple of times a day. This started after using the router for almost one year. I spent 3 hours on the phone with a Belkin rep, and I thought the problem was fixed, but it isn't. Can't bring myself to call again and strain my ears trying to understand the accent.
  • Belkin Master
  • 6,487 Answers
Try first to power cycle the router by powering it down for 30 seconds then after that check if your laptop will be able to detect the wireless signal from that router and try to connect to the wireless network...
Posted on Nov 05, 2008
The internet connection in my area went down yesterday, but i didn't know this and thought the reason i couldn't access internet was a problem with my linksys wrt54g router. So i unplugged and...
The first thing you should do is a proper 'powercycle' for all of your internet equipment.
To do this:
1) Unplug the power to your modem and your router, and power off your computer.
2) Wait a full minute.
3) Plug the power back in to JUST the modem.
4) Wait some more - for the modem to fully connect to your ISP, and the lights to indicate. If you're not sure, just wait about 2-3 minutes.
5) Plug the power back into the router.
6) Wait another minute or two for the router to finish connecting.
7) Then turn the computer back on.
You can bypass the computer turning on and off if you can repair your wireless connection.
If this doesn't work, there is a pinhole sized reset button on the router itself that you will need a toothpick or somesuch to press - press and hold the button for 5 seconds, and then try the steps above again. If you do this, the network id and password will be reset to the default, just like it was when you bought it.
Jul 20, 2011 | Linksys Wireless-G WRT54G Router
D-Link router does not connect to my laptop
remove the cat5 cable end that goes from your internet connected computer to your router; remove the end of this cable from your router ; remove your modem to router cable end from your modem put the internet computer cable into where the router cable was in the modem; unplug then: plug in your modem; wait for the modem to reboot; verify that the internet computer is online then swap the cables back where they were
you should now be able to connect your laptop wirelessly to the internet.
Jul 15, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I have a D-Link WBR-2310 wireless router that has all green lights lit up, but the router doesn't seem to give a wireless frequency. When I perform the command "ipconfig" on my laptop's command prompt it...
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Have laptop with internet but want to share it with xboxs
Yes, simply set up laptop as a mini server (Wireless) at the other end of the house (Where the Xboxes are) and ensure it has the WEP key installed when asked to access the router / internet. Buy a router adapter for each Xbox 360 that connects to them in the RJ45 slot and connect thru the laptop agian using the WEP key that you should have installed in the Router.
Mar 05, 2010 | Computers & Internet
My Laptop and iPod can't pick up my modem
From the laptop try pinging the router IP and then try to ping or or if you get replies the internet connection is fine and your router is connected to internet
As the issue is with 2 different devices it seems that issue is with router's internet connections, also connect the laptop with a cable and check the internet connection if that works fine issue is with the wireless security settings of the router
The user guide of your router is in the link below
Let me know if this help
Nov 30, 2009 | NetComm NB5PLUS4W Wireless Router
Can no longer pick up router signal
Does the wireless light still lit on the router? You can try changing the channel on the router (1 6 or 11) ans moving the antenna. If those things did not work upgrade the firmware of the router and reset to factory default. Do not forget to save the configuration file before you reset to factory default.
Jun 30, 2009 | NetGear WGR614 Wireless Router
How do I get internet on my laptop from my pc not using a cable?
what you would need to get is a wirless router. If you have high speed internet then you can plug the internet modem into the wireless router and then plug your main pc into the router via an ethernet cable and then set up your laptop to pick up the signal wirelessly. If you have dial up internet then you would still need a wireless router but it is a little more complicated. You could hook up the router to your main pc and then set up internet connection sharing so that way your laptop could pick it up wirelessly. hopefully this helps.
Apr 10, 2009 | HP Compaq Presario v3000z Notebook
I have a acer aspire 5315. I bought a D Link dir 615 wireless internet router. The problem I am having is that I can connect to the router, but I cannot connect to the internet. What is the problem?
Hi the router has not picked up your IP address.follow this Turn off your wireless router and internet connection and your laptop aswell for 30secs .Then first turn on your internet (if seperate from the router) if not switch on the wireless router/internet hub and wait untill the lights stop flashing then switch on your laptop and that should work.
Dec 15, 2008 | Acer Aspire 5100 Notebook
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
44 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
